Northern California NorCal
Old 04-16-2016, 02:05 PM   #1
LANWarlordII
LANWarlordII's Avatar
Drives: 15 BRZ
Will 18X9.5 with 45 offset fit on brz?
I'm deciding to get new wheels and am looking at the enkei tenjin 18X9.5 with the 45 offset. Anyone know if these will fit on all four corners of a brz?
LANWarlordII is offline   Reply With Quote
Old 04-16-2016, 02:21 PM   #2
sdemo
sdemo's Avatar
Drives: '13 SWP ZC6 R
There are literally hundreds of posts about this, and all of them say "it depends."
sdemo is offline   Reply With Quote
Old 04-16-2016, 02:56 PM   #3
LANWarlordII
Drives: 15 BRZ
Depens on what tho. camber? I've got about 2 degrees of it, if needed i can get a camber plate or something. Im just looking for yes or no answer.
Old 04-16-2016, 04:44 PM   #4
Bach415
Bach415's Avatar
Drives: Whiteout FRS
If you are on springs, you will def rub, even with camber. If you are on coilovers, you are getting awfully close to rubbing
Bach415 is offline   Reply With Quote
The Following 2 Users Say Thank You to Bach415 For This Useful Post:
LANWarlordII (04-17-2016), MisterSheep (04-20-2016)
Old 04-16-2016, 05:44 PM   #5
HachiRo
Drives: 2013 White-Out FRS
Depends on camber
Tire size
Springs vs coils (coils are smaller in diameter)
And overall height.
90% of the time it'll rub.
I live my life one quarter-pounder at a time.
HachiRo is offline   Reply With Quote
The Following User Says Thank You to HachiRo For This Useful Post:
Old 04-20-2016, 01:41 AM   #6
Legionsk88
Legionsk88's Avatar
Drives: 2015 WRB Limited BRZ
I run 18x9.5 +40 and I have a good 5-10mm roughly of clearance between the wheel and spring.
This is OEM suspension, I have no rubbing whatsoever at full lock and have had these on for a good 1-2k miles.
Legionsk88 is offline   Reply With Quote
Old 04-20-2016, 10:15 AM   #7
byun
byun's Avatar
Drives: 2015 BRZ CWP
I'm on 18x9.5 +45 w/ 255/35 on KW V3's and have room from the wheel/tire to the spring. -2.4 camber up front.
byun is offline   Reply With Quote
Old 04-20-2016, 10:57 AM   #8
driftartist
Kurenai Samurai
driftartist's Avatar
Drives: Red and manual
as sdemo said about the many posts about the wheel fitment, now would be a terrific time to do your detective work and read those posts....just like i did when i bought my wheels! happy hunting!
not all the answers will come to you, sometimes you gotta go to the answer.
driftartist is offline   Reply With Quote
Old 04-20-2016, 11:01 AM   #9
Rifle
EX-86 Supercharged God
Rifle's Avatar
Drives: '16 Series.HyperBlue BRZ
Weddsport SA10 18X9.5+45
Lowered ~3inches
-1.5deg camber front
-2.9deg rear
Sprintex 210 Supercharged HyperBlue BRZ "HI MOM"
295WHP/220TQ
Rifle is offline   Reply With Quote
Old 04-20-2016, 03:52 PM   #10
djdnz
1337
Drives: 2013 BRZ WRB S/C
Needs coilovers for sure.
djdnz is offline   Reply With Quote
Old 04-22-2016, 12:32 PM   #11
LANWarlordII
Drives: 15 BRZ
Yea I'm on ST coils so I should have more room vs the stock suspension. Are you running square set up on your wheels?
Old 04-22-2016, 12:41 PM   #12
[YOYO]
Amazing Member
[YOYO]'s Avatar
Drives: 2014 Whiteout FR-S
Har Har Har
MY 86 BUILD
[YOYO] is offline   Reply With Quote
Old 04-22-2016, 02:08 PM   #13
sdemo
sdemo's Avatar
run it square, with coilovers. 255 is your max width tire due to fender liner rubbing. don't use camber bolts, instead adjust camber with top hats.
3mm spacer will fix rubbing issues and may allow you to run some extra camber with bolts.
if any of the above is confusing, SEARCH
Old 04-22-2016, 02:53 PM   #14
nzer
nzer's Avatar
Drives: 2012 Grey TRD GT86, 2015 VW Golf R
Here's an article about mine by my wheel supplier with 18x9.5" +45
http://www.prosportauto.co.nz/blog/p...SA10R-Fitment/
With +45 offset you will need coilovers. I found no fender rub with 255/35 or 265/35 tires but chassis rail rub at full lock. I put steering stops in so full lock was a little less angle preventing the rub. I'm lowered about 20mm.
nzer is offline   Reply With Quote
zedd sl5 18x9.5 35 offset diggy_digz86 Wheels and Tires 2 01-22-2015 04:14 AM
M7 18x9.5 5x100 UNKNOWN OFFSET JamesBond000 Wheels and Tires 1 01-05-2015 11:38 PM
18x9.5" (45) offset up front, anyone? OICU812 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 11 12-11-2013 07:46 PM
FS: XXR 531's (18x9.5" +35 offset) - $700 OBO husker741 Wheels and Tires 2 09-04-2013 11:07 PM
Lowest possible offset for 18x9.5? and 255's? Cheeseballs Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 04-22-2013 10:04 AM
