Old 04-19-2016, 11:01 AM   #1
BRZBYE
BRZBYE's Avatar
Drives: 2014 Subaru BRZ (Limited, Black)
Can I get this flush?
Hey everyone, I am looking to get my front wheels flush with the body. I want to know if it's possible with this wheel, and if so, what I need to do it.
Currently:
- stock struts
- eibach black lowering springs (not prokit... The other one with less drop)
- wheels are 9.5"x18 with a +38 offset I believe
Camber is currently around -1 degrees.
Can I even get a flush look with these wheels? I am worried that it could contact the fender if I bottom out.
I plan to buy the ST coilovers so that I can set it up with a more negative camber setting which should help with the poke.
Will the front suspension suck the wheels in the more I lower it (similar to what the rear suspension does when you go low)?
Thanks for advice and help!
Eric
BRZBYE is offline   Reply With Quote
Old 04-19-2016, 11:11 AM   #2
NyC Zn6
NyC Zn6's Avatar
Drives: 10 Series #974 6m/t
Currently:
- stock struts
Eric
Answered your own question Once you lower the car it will start to tuck with those sizes 18x9.5 +38
Old 04-19-2016, 12:54 PM   #3
kch
Senior Misanthrope
kch's Avatar
Post baleeted because I was wrong (for once).
Old 04-19-2016, 01:04 PM   #4
Cole
Not a troll
Cole's Avatar
Originally Posted by kch View Post
Just as an FYI, the ST coilovers themselves won't help one bit with camber. They don't include camber plates (or any sort of top mount, actually). If you want camber with the STs, you'll need either camber plates or the camber bolts (or both).
Edit: unless you mean that you'll be able to have more camber without rubbing once you get coils. In that case, you're correct.
Uh, yes they do. They have slotted lowers.
The spread of false info on here is so silly sometimes.
Cole is offline   Reply With Quote
Old 04-19-2016, 01:36 PM   #5
kch
Senior Misanthrope
kch's Avatar
My bad. Forgot about those.
Old 04-22-2016, 09:13 AM   #6
Ashikabi
Ashikabi's Avatar
More camber. Camber bolts will do it for you
Old 04-22-2016, 09:22 AM   #7
ZionsWrath
Thanks
ZionsWrath's Avatar
If just barely tucking the top of the rim under the fender is your definition of flush, then yea I guess you could get that with coils.
In general 9.5 up front is not gonna be flush and kind of meh unless you are looking for stance.
Good luck and post your results.
Old 04-22-2016, 09:29 AM   #8
Ashikabi
Ashikabi's Avatar
I had 9.5s at +36(I think) and they were pretty damn flush. Didn't touch the fender either but I had -2.5 camber up front
Old 04-22-2016, 10:01 AM   #9
ZionsWrath
Thanks
ZionsWrath's Avatar
Here is a good example. 9.5 +40
The top can be considered "flush" with the lowered and camber but you see the rest of the wheel still sticks out.
If that is the OP goal, then yes it can be "flush"
Old 04-22-2016, 04:09 PM   #10
djdnz
1337
Drives: 2013 BRZ WRB S/C
If you go with camber bolts to bring it in more flush, you might end up rubbing the tire to the stock strut perch. Once you go to the ST coilovers you will probably be able to add enough camber to bring it back into flush.
djdnz is offline   Reply With Quote
Old 04-22-2016, 04:19 PM   #11
Toyarzee
Shibby!
Toyarzee's Avatar
Drives: '14 White FR-S, '01 turbo mini taco
Agree with @ZionsWrath that the term "flush" is thrown around a lot... and ironic that it now usually means poke with camber lol
Toyarzee is offline   Reply With Quote
Old 04-22-2016, 04:43 PM   #12
sdemo
sdemo's Avatar
Drives: '13 SWP ZC6 R
You people and your semantics
sdemo is offline   Reply With Quote
Old 04-24-2016, 01:34 AM   #13
BRZBYE
BRZBYE's Avatar
Thank you everyone who posted! Tons of help! So it sounds like more negative camber or different wheel offset are my only options to get "flush" (which for me, poke with negative camber is fine).
Also, yes I do plan to get some coilovers with top mount camber plates like the ST XTA or if I go cheap and get the XT, I will pair it up with the Raceseng CasCam top mounts. With these wheels, I am about 1/4 of an inch from contacting the OEM spring perches. So currently maxed out at the natural negative camber (about -1 for my ride height).
Now a little off topic.. maybe someone can chime in with advice for additional suspension parts I should consider. I noticed some coilover sets include some adjustable toe arms. Is this a must have item or just makes the car easier to align?
Old 04-24-2016, 01:45 AM   #14
swarb
Those aren't toe arms. They are sway bar end links which are usually for the front.
Not flush panels FRSure Issues | Warranty | Recalls / TSB 9 02-20-2016 01:27 AM
FlushBrz's Flush FR-S. lol FlushBrz Member's Car Journals 40 02-08-2014 08:35 PM
RPF1 most flush? goshem Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 11-27-2013 10:34 AM
Flush +/- DarrenDriven Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 22 08-13-2012 11:37 AM
Help with DIY transmission flush. ahausheer Other Vehicles & General Automotive Discussions 0 06-26-2012 03:51 PM
