Old 04-22-2016, 03:13 AM   #477
cawith
Drives: Toyota GT86 6M/T
Originally Posted by freerunner View Post
Yeah, it's a bug in vgitool for everyone whose system locale is not English.
If you want to keep your currently used system locale settings, you can use per-app locale setting as a workaround:
Edit your run.bat. After javaw.exe add two variables:
Code:
-Duser.language=en -Duser.country=us
If you're using Romraider, you'll want to run it like that, too. Else you might not be able to copy&paste table values.
yes change the ol/cl voltage to 3.2 not 32
the min load is probably ok at 0.2 but you could try 0.1
Thanks, guys. I just changed to English settings, that fixed it
@steve99 , at idle LTFT is usually 0% or sometimes 0.78%, so I guess it would be fine just to leave minimum load at 0.2.
I understand that while doing the highway logs I should try to keep the throttle as steady as possible or keep a very mild acceleration between 100 and 140 km/h, but for city driving I can't stop logging for every time I have to stop at a light or need to brake. Is that acceptable? I guess all the irrelevant data will be removed as the ECU goes in too OL on deceleration..?
cawith is offline   Reply With Quote
Old 04-22-2016, 04:02 AM   #478
steve99
Drives: FT86
It ok to stop and start, but you just dont want to be in heavy traffic where intake temps will change significantly. or sitting idling for long periods.
just drive smooth , mild acceleration, your just trying to get as much closed loop time as possible at varing rpm, just dont drive like racer X and you will be fine.
Old 04-22-2016, 04:27 AM   #479
cawith
Okay, thanks for clarifying!
Regarding the 15 minutes driving around a car park, would you say that should be with stop & go, or should I try to keep the clutch engaged at all times and just drive around at low rpm in both 1st and 2nd gear?
Old 04-22-2016, 04:33 AM   #480
steve99
Drives: FT86
Nah no need to do that stuff
just do 15 mins or so normal driving then 10 on the highway or open road, or some backroads where you can do 100k or so legally
cawith (04-22-2016)
Old 04-22-2016, 05:55 AM   #481
freerunner
freerunner's Avatar
Drives: GT86
In addition to that, I always do some closed-loop runs with low load at higher rpms.
Cruise-control driving for a bit of time with 4.0k, 4.5k, 5.0k, 5.5k,6.0k on the highway/autobahn.
Very helpful for nailing down your 3v/3.2v maf value, since it should be calibrated in close loop.
If you've done this properly, you will have a good base for applying load limits when calibrating open-loop.
freerunner is offline   Reply With Quote
The Following User Says Thank You to freerunner For This Useful Post:
cawith (04-22-2016)
Old 04-26-2016, 03:18 PM   #482
Ondreiko
RWD addicted
Ondreiko's Avatar
Drives: BRZ 6MT OFT OFH
need advice
Guys!
I seem scald my maf as the car drives much better now than before, but:
there is the spike of AFR at 3800 rpm.
http://datazap.me/u/ondreiko/1007-wot?log=0&data=1-6-11
My load engine table is as follows:
800.0 1000.0 2000.0 2200.0 2400.0 2500.0 3000.0 3800.0 4000.0
1.00000006144 1.00000006144 1.00000006144 1.00000006144 1.07000738996 1.1099854197599999 1.09997565352 0.9500122653999999 1.40002450008
as it was proposed by Wayno.
What do you suggest me to do in order to eliminate that spike (FLKC = 0 and IAM = 1 at that point anyway) and do i need it as the car drives very good (comparing to the same before i did MAF scaling).
Sorry for bothering stupid questions of the dumb guy, but i seem to be not in charge to find the right way myself at this point and need your kind guidance.
It is OFT/OFH setup and front pipe is catless as well
Thank you in advance,
PS: i've read the entire thread from beginning to the end but still need guidance. sorry again
Ondreiko is offline   Reply With Quote
Old 04-26-2016, 06:58 PM   #483
Wayno
Wayno's Avatar
Drives: Toyota 86 GTS
Just raise the 3800 value to 1.
The Following User Says Thank You to Wayno For This Useful Post:
Ondreiko (04-27-2016)
Old 04-27-2016, 03:04 AM   #484
Ondreiko
RWD addicted
Ondreiko's Avatar
Thank you, man, will upgrade and see what happens
Old 04-28-2016, 02:15 PM   #485
Ondreiko
RWD addicted
Ondreiko's Avatar
Guys,
Does this one look right now?
http://datazap.me/u/ondreiko/v1008-w...=0&data=1-6-11
i changed engine load limits at 3800 RPMs by +0.5 and it looks better now.
Should i leave it as is or does it need further tweaking (of what)?
Here is another log of the same day,
http://datazap.me/u/ondreiko/v1008-w...=1&data=1-6-11
but there was bit less flat surface in second case.
Old 04-28-2016, 06:35 PM   #486
freerunner
freerunner's Avatar
Drives: GT86
Looks better. Should be safe for now.
If you're certain that your mafv 3.20Via cell has been calibrated correcty in closed-loop, try raising load-limit for 3800 rpm slighly further and see if it gets better. Else adapt scaling value for 3.20V (increase slightly so more fuel is added).
This will probably set scaling off for mafv >= 3.44V
Make one change a time and examine what happens.
Will take some time and trial and error to get everything perfect.
Ondreiko (04-29-2016)
Old 04-28-2016, 07:53 PM   #487
Wayno
Wayno's Avatar
Looks fine
Old 04-28-2016, 10:54 PM   #488
Dru670
Drives: 2016 Scion FR-S
do you put the city driving and highway driving logs together in the Closed Loop in the MAF Scaling app?
Dru670 is offline   Reply With Quote
Old 04-28-2016, 11:29 PM   #489
steve99
Drives: FT86
yes you can put it all in one log the maf scaling utility will sort it out.
Old 04-29-2016, 11:38 AM   #490
Dru670
Ah okay thanks. Is there anything else that must be done after scaling the MAF? Also, if I wanted to rescale the MAF again do I load the previous ots rom and log my drive and scale maf or do I use the current rom with the newly scaled MAF and log and adjust that one? Sorry just not sure because one instruction says to log tons and tons of data and repeat while another says just do 15 min normal and 10 highway 2-3 WOT and done.
AFR in Closed Loop Toyota John Software Tuning 39 07-07-2019 08:26 AM
BRZedit Fuel Trims, Closed to Open loop transiton mad_sb Engine, Exhaust, Transmission 32 08-06-2015 03:14 AM
Notes on injector / maf scalining using full time open loop mad_sb Software Tuning 40 03-03-2014 05:49 PM
Screencast: closed loop boost control with RaceRom jamesm Software Tuning 2 02-10-2014 02:23 PM
Screencast: experimenting with full-time closed loop fueling jamesm Software Tuning 2 12-27-2013 10:19 AM
