Old 04-22-2016, 01:32 AM   #1135
jawn
jawn's Avatar
Drives: 2015 CWP BRZ Limited
Originally Posted by Wayno View Post
Since when is 0.6g/rev high load?
You're right. Wasn't seeing the forest for the trees.
jawn is offline   Reply With Quote
Old 04-22-2016, 01:54 AM   #1136
Wayno
Wayno's Avatar
Drives: Toyota 86 GTS
Easier to just learn to read from left to right.
The Following User Says Thank You to Wayno For This Useful Post:
jawn (04-22-2016)
Old 04-22-2016, 04:40 AM   #1137
cawith
Drives: Toyota GT86 6M/T
Don't bother logging FBKC.
Can you explain why not? I thought FBKC and FLKC were very important to look at...
cawith is offline   Reply With Quote
Old 04-22-2016, 10:09 AM   #1138
oldgunfan
oldgunfan's Avatar
Drives: 2014 BRZ sterling silver
Originally Posted by tha_alkaholiks View Post
Yeah, they've been heaps helpful. Actually running Wanyo's UEL 98ron tune. Which is super smooth, just starting out with alerts and logging, so lots of learning to do still.
Cool, they have helped me bunch too. listen to them they know what there talking about.
oldgunfan is offline   Reply With Quote
Old 04-22-2016, 10:26 AM   #1139
oldgunfan
oldgunfan's Avatar
If you don't have the knock correct I gess you could tell by the adv multiplier dipping. other than that i don't know. school me please. (not being an asshole i really like to know) by the way why does everyone log the fuel sys status??
Old 04-22-2016, 07:11 PM   #1140
steve99
Drives: FT86
I still like to log both fbkc and flkc especially if your getting iam drops as it can be due to either. You can also used KCLearned to determine flkc knock and iam but its much easier with flkc, but usefull if the device doescnot log flkc or iam or as a cross check
Fuel system status tells you if your in open or closed loop fueling mode usefull for maf scaling, you can also generally pick open loop fueling mode as stft will go to zero
their is some good suff on the romraider forums on subaru knock and i thunk i linked to it in the knock link below or the flashing reset learning l
oldgunfan (04-22-2016)
Old 04-22-2016, 07:52 PM   #1141
Wayno
Wayno's Avatar
If the fbkc is bad or often enough to drop iam, it will transfer to flkc.
As i said before, unless you have fuel dialed in already, have a flat kca map to reference and have lots of miles on the car followed by hundreds of miles of logs, all you will do by pulling timing for every minor knock event is detune your car.
The Following 3 Users Say Thank You to Wayno For This Useful Post:
cawith (04-23-2016), oldgunfan (04-22-2016), steve99 (04-23-2016)
Old 04-22-2016, 08:40 PM   #1142
steve99
Drives: FT86
Best explaination of knock correction here although its pretty heavy reading, its for 16 bit ecu, but appears to apply to our 32 bit ecu code as well, the main difference is on 32 bit ecu iam is 0 to 1 and on 16 bit iam is 0 to 16.
http://www.romraider.com/forum/topic1840.html
http://www.romraider.com/forum/topic5371.html
the ecu operates in two different modes fine correction and coarse correction, the ecu switches between these modes , and can do so very quickly but never in both modes at same time
Feedback correction FBKC only negitive not storred but used to drop iam
Fine learning correction FLKC stored in feedback correction table can be +or-, can only be + if iam is less than 1
IAM coarse correction
IAM is considered coarse correction but drops can be triggered by flkc or fbkc or likely a combination of both fed into some weird algorythm that takes into accout size duration and how often it occurs.
IAM returning to one, also likely due to some weird calculation that takes into acount how knock free rpm\load area have been for a period of time.
The Following 2 Users Say Thank You to steve99 For This Useful Post:
Old 04-22-2016, 10:01 PM   #1143
oldgunfan
oldgunfan's Avatar
I see now if you get to know these engines well enough you can tell that if you have a load of 1.2 and total advance say 45 and AFR of 14.5 there should knock unless the fuel is good enough. just as example. I don't know what those thresholds are yet. I'll give those links a read thanks steve.
Old 04-22-2016, 10:21 PM   #1144
Gliderx
Drives: 2014 BRZ Limited
Hey guys, been lurking for awhile learning as much as I can. New to OFT and just wanted to post my datalog to see if there's anything standing out I should look at. Let me know if I need to add any other variables and such. Thanks in advance
Here are 2 runs:
http://www.datazap.me/u/gliderx/log-...1?log=0&data=1
http://www.datazap.me/u/gliderx/log-...1?log=1&data=1
Gliderx is offline   Reply With Quote
Old 04-23-2016, 12:11 AM   #1145
steve99
Drives: FT86
Here are 2 runs:
its fine have a read of the logging links below if you want to know what too look for
Old 04-23-2016, 01:35 PM   #1146
eSOLOR
eSOLOR's Avatar
Drives: Subaru BRZ
Got the new OFH tune. Only mods are OFH, drop in filter, and catback. How does my log look? I tried doing a 3rd gear redline pull but I ran out of room on the road.
http://www.datazap.me/u/ernesteaux/l...5-6-7-11-12-13
eSOLOR is offline   Reply With Quote
Old 04-23-2016, 02:59 PM   #1147
oldgunfan
oldgunfan's Avatar
At about 4500 and 3.5v at on your MAF scale at WOT it starts to go a little Rich other than that looks good.
The Following User Says Thank You to oldgunfan For This Useful Post:
eSOLOR (04-23-2016)
Old 04-23-2016, 04:26 PM   #1148
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
Yeah, just a smidgen rich. I personally wouldn't worry about it as it's not costing much power and your trims look reasonable and 0 FLKC.
The Following User Says Thank You to DocWalt For This Useful Post:
eSOLOR (04-23-2016)
RGM Supercharged 86 performance data TheGooseman AFRICA 14 12-13-2014 01:15 AM
Interpreting Ecutek Data Logs? cuddefred Software Tuning 3 09-02-2013 12:55 PM
VIR - Impressions/Pics/Logs/Video (Track Daze) swift996 Tracking / Autocross / HPDE / Drifting 39 08-30-2013 09:21 AM
Noise tube delete air/fuel logs? jm1681 Engine, Exhaust, Transmission 13 10-17-2012 04:57 PM
ECU Data Logger Motordyne Engine, Exhaust, Transmission 5 07-18-2012 09:27 AM
