Old 04-21-2016, 05:19 PM   #869
fenton
The ESC really isnt intended for track use. Most track applications will push the ESC past its design goals(street performance). Autocross is usually fine as those sessions are short and there are breaks after each run. For track use it would be recommended to remove the ESC and replace with the stock intake, especially if it is a long track with lots of straights.
Originally Posted by rdub-S View Post
I have a track day coming up in a month. This will be my first time at the track with the ESC. I have the most recent version of the ESC, a procede controller and plan to pick up an aux charger.
From my experience at this track, I expect I'll run out of boost with this system or trigger the thermal protection. So what then? Will it hurt anything to shut it off and stay out there unboosted? Am I OK to run on the same OFT tune with the system shut off or should I remove it and flash back to a Stage 2 tune?
I don't want to damage the system. I bought the ESC primarily for street use, but I don't want it to be a liability at the track, and would be prepared to uninstall for a day if recommended.
fenton is offline   Reply With Quote
The Following User Says Thank You to fenton For This Useful Post:
brzaapi (04-21-2016)
Old 04-21-2016, 05:37 PM   #870
TM
TM's Avatar
Drives: DGM BRZ 6MT
My starter is dead and I don't have an outdoor area where I can trickle charge it, so I'm going to order another one.
Should I get the PC680 or PC680MJ?
TM is offline   Reply With Quote
Old 04-21-2016, 08:24 PM   #871
rdub-S
Drives: 2013 FRS
track day
Thanks again for the input. This is not a competitive event - just a few friends that rent the track for the day. My "sessions" and breaks are as long or short as I choose them to be.
I plan to run it with ESC installed and see how it goes, at least for a couple laps. If it seems like it isn't keeping up or it's getting very toasty, I'll just pull it and put the stock intake tube on for the balance of the day just to save it from the abuse. It won't put a damper on the fun to do so.
The greater unknown to me was, if I remove it, whether it is critical to flash back to a Stage 2 tune. Sounds like that won't be necessary as I won't be looking for every last hp possible. Will have my OFT with me and will probably try it both ways if I end up pulling it.
rdub-S is offline   Reply With Quote
Old 04-21-2016, 09:07 PM   #872
Sojhinn
Lightning McQueen Driver
Sojhinn's Avatar
Drives: Limited Red 6MT BRZ
Pc680mj
Installed Mods:
The Following User Says Thank You to Sojhinn For This Useful Post:
TM (04-21-2016)
Old 04-21-2016, 09:33 PM   #873
Algreen
Guest
Posts: n/a
For those familiar with history of the kit, are there different generations of PROcede units? I have a v3 ESC kit (not yet installed), and I'm curious if I need a specific PROcede box? Or can I adapt the output of the proceed wiring to the input plug to the controller...
The Following User Says Thank You to For This Useful Post:
Sojhinn (04-22-2016)
Old 04-22-2016, 12:56 AM   #874
Sojhinn
Sojhinn's Avatar
Wiring is all the same. Difference is if it has a usb port or serial.
Installed Mods:
DAEMANO (04-24-2016)
Old 04-28-2016, 11:28 AM   #875
Algreen
Guest
Posts: n/a
Thank you sir.
Old 04-29-2016, 01:13 PM   #876
l0aded
Addicted
l0aded's Avatar
Drives: 2013 Asphalt FR-S 6MT
Pc680mj
What's the difference between the pc680 and the pc680mj?
Phantom Supercharger | Tsudo Cat-Back Exhaust | K&N Drop-in Filter | Winjet Headlights | Opti-coated | 35/20 Tint | Radar/Dashcam Hardwired | OFT tuned | OEM Audio+ Reference 400CF | Uber Sound Deadened | LED DRL strips | JPM Coachworks Kneepads
l0aded is offline   Reply With Quote
Old 04-29-2016, 01:25 PM   #877
Sojhinn
Sojhinn's Avatar
Comes with a metal jacket around the battery. Strongly recommend this as it lessens the issues with heat.
Installed Mods:
The Following 2 Users Say Thank You to Sojhinn For This Useful Post:
CxG (04-29-2016), l0aded (04-29-2016)
Old 04-30-2016, 02:16 PM   #878
FingR-S
I got sucked into boost..
FingR-S's Avatar
Drives: Whiteout FR-S & Supercharged BRZ
Would a variable geometry turbo benefit the ESC?
For sale: 2013 BRZ Vortech Supercharged with nice updates.
Vortech Supercharger - Perrin exhaust - 245 RS3 on RPF1's
FingR-S is offline   Reply With Quote
Old 04-30-2016, 10:10 PM   #879
Algreen
Guest
Posts: n/a
Finally got my ESC installed today! Can't wait to test and tune tomorrow. Thanks all for your help! This is a great community and resource.
The Following 2 Users Say Thank You to For This Useful Post:
DAEMANO (05-01-2016), FingR-S (04-30-2016)
Old 04-30-2016, 10:25 PM   #880
Sojhinn
Sojhinn's Avatar
Woot let us know how it goes.
Installed Mods:
Old 05-01-2016, 12:45 PM   #881
Algreen
Guest
Posts: n/a
It was a glorious maiden voyage. Totally wakes up the car.
I noticed my voltage never went above 28.0 if it matters.
Old 05-01-2016, 01:37 PM   #882
Sojhinn
Sojhinn's Avatar
Where was it at?
Installed Mods:
Jackson Racing Supercharger Owners Thread enivid Forced Induction 6041 11-28-2025 08:08 AM
Full throttle Electric Supercharger Build Thread fenton Forced Induction 11315 04-07-2025 06:42 PM
Kraftwerks Supercharger Owners Thread projek_01 Forced Induction 4310 04-07-2025 01:12 PM
phantom supercharger restrictions? Shinigunz Forced Induction 12 05-13-2014 03:28 AM
Drift-Office : Phantom Supercharger - Tuned! Drift-Office Forced Induction 67 10-25-2013 09:51 AM
