Old 11-15-2014, 08:07 AM   #1
acro
Drives: GT-86
Help Error code C1241
Hi i got a check engine light. Used Ecutek to check the engine code and got
error code C1241 from the ABS ECU, what does that mean. I have seen that code listed as a low battery problem from some toyota forums but why did it come from the ABS Ecu. Brake pads where changed the same day BTW
Can the dealership read and Clear error codes with my ecutek tune on board or should i just flash back to the stock ROM
acro is offline   Reply With Quote
Old 02-06-2015, 07:20 PM   #2
acro
Drives: GT-86
Any ideas
Old 02-06-2015, 07:27 PM   #3
SteveIsBored
Drives: 2013 subaru brz
Battery and alternator test to start based on code description. Sometimes people damage wheel speed sensors when installing brake pads but that would be a different code such as rf wheel speed sensor output high. Traction control modules such as abs can be really sensitive to voltage changes and fluctuations since they depend on electrical signals to save ur life and such
SteveIsBored is offline   Reply With Quote
The Following User Says Thank You to SteveIsBored For This Useful Post:
acro (02-12-2015)
Old 04-19-2016, 12:51 AM   #4
Rio
Rio's Avatar
Drives: 2014 Scion FR-S ハチ
C1241 Also
What resolved your issue?
Rio is offline   Reply With Quote
TechStream Error Code B14A1 developer Issues | Warranty | Recalls / TSB 13 10-08-2018 08:22 AM
Error code P0171 P0170 and P171b came up Astroboy Forced Induction 27 04-26-2014 05:29 PM
Error code B14A1... wth is it? SirBrass Software Tuning 4 04-24-2014 06:37 PM
Unichip Error Code Ingeberger Engine, Exhaust, Transmission 5 12-29-2013 02:09 PM
Paperwork error Rob_g Scion FR-S / Toyota 86 GT86 General Forum 4 05-25-2012 12:38 AM
