Old 11-26-2012, 08:06 PM   #1
developer
Drives: BRZ Limited
TechStream Error Code B14A1
I just got my Chinese TechStream from ebay and hooked up to my BRZ Limited to adjust a couple of settings. I did a diagnostics and I got a B14A1 Open in Solar Sensor Circuit for my AC unit. I assume this ups the AC when there is a lot of sun going into the car. Has anyone else seen this error code on their BRZ with TechStream?
It is going to be interesting explaining to the dealer how I know about a code that only someone with TechStream would know about. Torque did not show this code.
developer is offline   Reply With Quote
Old 11-26-2012, 10:42 PM   #2
neutron256
neutron256's Avatar
Drives: '13 GBS Subaru BRZ
Since you're using the knockoff cable I'm not sure I would trust this. They're not all that reliable, and do have some compatiability issues. Are you actually having a problem, or just concerned because you got the error?
Old 11-27-2012, 01:15 AM   #3
developer
Drives: BRZ Limited
Yeah, it could be the cable, but everything else is working as normal with the TechStream software and cable. I had noticed when I first got the car during summer that it always felt like the AC system was blowing air hotter than it should. Now I think I know why. I will have the dealer check it out the next time I have it in for something else.
Old 11-27-2012, 07:32 AM   #4
NRGBalanced
NRGBalanced's Avatar
Drives: '13 Subaru BRZ Limited WRB
Yes, I have seen it as well. From a little research it's nothing to worry about.
http://www.justanswer.com/lexus/1jq9...purchased.html
Apparently it's very common on Toyota-sourced vehicles with auto climate control. It's just a nuisance or ghost code. The ECU is registering an open circuit when there is so little light that the sensor reads 0 anyways. Mine went away the next day when I checked again in sunlight instead of nighttime.
NRGBalanced is offline   Reply With Quote
The Following 2 Users Say Thank You to NRGBalanced For This Useful Post:
.Kyle (12-09-2018), developer (11-27-2012)
Old 11-27-2012, 11:35 AM   #5
developer
Drives: BRZ Limited
I live in Oregon. I may not be able to find out if it works until July 5th!
Old 11-27-2012, 01:20 PM   #6
developer
Drives: BRZ Limited
Confirmed. The sun peeked out today. Error was gone!
Thanks again.
Old 05-09-2013, 03:46 PM   #7
Sarlacc
/dev/null
Sarlacc's Avatar
Drives: Uphill
I got this code as well. Thanks for the info, now I know not to worry
Well, if it works, it works. I don't think any cable would start inventing error codes?
Old 04-20-2016, 04:32 PM   #8
JF86Red
Drives: GT86 C7P
Same error code but checked in garage so I don't need worry.
Thanks for information
JF86Red is offline   Reply With Quote
The Following User Says Thank You to JF86Red For This Useful Post:
FRSBRZGT86FAN (04-21-2016)
Old 04-21-2016, 03:49 AM   #9
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
Moreso effects you as well, as you have a GT86 with dual climate controls
Old 04-26-2016, 12:33 AM   #10
Jmonty
Realtor/ Principal Broker
Drives: JRSC BRZ GBS LTD 2010 LTD Outback
Thanks again.
PM sent do you still have the tech stream in the PDX area?
Jmonty is offline   Reply With Quote
Old 10-21-2016, 09:53 AM   #11
Rinzler_ft86
Rinzler_ft86's Avatar
Drives: 2013 brz limited edition
What was the fix i popped the same code but came seem to find a fix anywhere online.
Sent from my SM-G935T using Tapatalk
Rinzler_ft86 is offline   Reply With Quote
Old 10-07-2018, 02:50 PM   #12
gpvecchi
gpvecchi's Avatar
Sorry to re-up, is the solar sensor the same for automatic headlights that is on the dash near windshield vents?
gpvecchi is online now   Reply With Quote
Old 10-08-2018, 01:28 AM   #13
FRSBRZGT86FAN
You need to double check a wiring diagram for the car, but they are most likely not the same.
Old 10-08-2018, 07:22 AM   #14
gpvecchi
gpvecchi's Avatar
Do you know where it should be located?
Toyota Techstream xjohnx Engine, Exhaust, Transmission 206 08-20-2023 04:01 PM
Paperwork error Rob_g Scion FR-S / Toyota 86 GT86 General Forum 4 05-24-2012 11:38 PM
error when attaching pdf to post dude04 Site Announcements / Questions / Issues 0 05-21-2012 08:53 PM
Driver error Midship Runabout Off-Topic Lounge [WARNING: NO POLITICS] 5 07-14-2010 07:25 PM
