#337 |
Drives: 2013 FRS / 2013 427 Vert
E85 with flex fuel kit. Actual ethanol at the time was 82.
[SIGPIC][/SIGPIC]
2013 FR-S Asphalt BC Coils/Rev Works UEL header/HKS Front Pipe/Racing Brake BBK/Shorai LW Battery/ACT 6 Puck Clutch/FBM Radiator & Oil Pan/JR Oil Cooler/Jackson Racing High Boost C30/Rev Works Built Motor 2016 Audi TTS APR Tuned |
#338 |
Those who are asking me who tuned the car are missing the point. This tuner has dozens of cars doing fine with higher power levels than I was making.
Motors are machines and are not infallible, shit breaks. Everyone I know who tracks their car regularly has broken something, actually several things.
[SIGPIC][/SIGPIC]
The Following 4 Users Say Thank You to Deep Six For This Useful Post: |
#339 | |
Drives: Scion FR-S
#340 |
Drives: '14 FR-S
@Andew727
Contact Outfront Motorsports. I believe Jeremy has some custom CP pistons for our engine in 12.5:1 CR |
#341 |
We do 12.5:1 CR pistons
The Following User Says Thank You to CSG Mike For This Useful Post: | DriftinFRS (04-16-2016) |
#342 |
Drives: Scion FR-S
#343 |
Built to order; I don't think we've ever had anyone ask for pistons without wanting a host of other options (WPC, Ceramics, etc.).
The Following User Says Thank You to CSG Mike For This Useful Post: | Andew727 (03-04-2016) |
#344 |
Looking like the San Andreas fault line on the top of my motor...
![]() I'd like the next motor to be 12.5:1 CR, 7.5k redline (maybe slightly higher if it can be managed safely), C38, HBP, E85, I'm exploring what the motor needs to be safe under those conditions.
Setup 3: JR C30, DW 700, Grams 265, 3bar, FlexFuel, Moto-East Setup 4: JR C30 HBP, DW 700, Grams 265, 3bar, FlexFuel, Church Setup 5: JR C30 HBP, DW 700, DW 300, 3bar, FlexFuel, Delicious, Built Motor Setup 6: JR C30 HBP, DW 700, DW 300, 3bar, FlexFuel, Delicious, Closed Deck Built Motor |
#345 | |
#346 |
I haven't, been very busy with work and recuperating from a Chump car crash. I have laid out a build for the car but had to fund a new daily driver for my wife first. That's now done so now it's time to make the FRS much more track focused.
I will begin a thread soon or join yours if you want to get one started. The damage to your block looks remarkably similar to mine. Wonder if the rods are breaking at a specific point in the stroke ? I am starting with a new oem block, going to forego having it sleeved and plan to use Wise Co 11.5 pistons.
[SIGPIC][/SIGPIC]
The Following User Says Thank You to Deep Six For This Useful Post: | SPCorBUST (04-15-2016) |
#347 | |
I've also sort of laid something out but I'm admittedly a noob when it comes to building motors. I found a couple threads on building motors here on the forum as well as a couple shopping lists but nothing that runs through the available part options, why to pick one vs another based on manufacturer and failure point, what you can reuse vs what you absolutely want new, and other factors. At least, I'm curious about those things.
#348 | |
Drives: RX-7 / BRZ
I'm in the same boat of looking for options to build. I'm having a hard time though justifing a DIY on this engine though. I can't really find much money to be saved vs buying a block from Full Blown or MAPerformance... at best I'm saving $500 when I fully finish my shopping cart and thats not getting some of the benefits the short block packages have such as being balanced and blueprinted... :/
//2018 Crystal White Pearl BRZ Ts 2.2l Harrop Supercharged |
The Following User Says Thank You to Kiske For This Useful Post: | Luftwaffel (04-16-2016) |
#349 | |
Boost Creep
Drives: 2016 HyperBlue BRZ
SBD400X Turbocharged 2016 Series.HyperBlue BRZ
#350 |
if you're looking to retain stock 12.5 CR, is there any reason to upgrade from the OEM pistons?
Tags |
kill brain cells, not facts |
FlexFuel and Facts | Shiv@Openflash | Software Tuning | 69 | 10-16-2019 01:08 PM |
Anyone Else? Hearters Blowing when off. | Kiske | Issues | Warranty | Recalls / TSB | 7 | 04-09-2014 05:22 PM |
How cold is your a/c blowing? | jermyzy | Issues | Warranty | Recalls / TSB | 68 | 08-18-2013 03:29 PM |
Supra Blowing Up | radroach | Off-Topic Lounge [WARNING: NO POLITICS] | 2 | 07-21-2013 09:14 PM |
Facts you may or may not know about your GT86/BRZ/FR-s | FiRStsc10n | Scion FR-S / Toyota 86 GT86 General Forum | 41 | 07-09-2013 03:05 PM |
