Old 04-07-2014, 09:06 PM   #1
Kiske
Kiske's Avatar
Drives: RX-7 / BRZ
Anyone Else? Hearters Blowing when off.
2013 BRZ Limited, Dual Climate/Digital Controls.
When digital controls are off and nothing lit up slight air movement can be felt at all times as if the controls aren't completely off.
Testing.
1. Turn Car on, Heater on "HI" setting (max) then turned off. Drive for 10+ addition minutes and hot moving air can be felt from the center and driver side vents.
2. Turn Car off, then back on. Leaving the climate controlls off. Still slight hot air movement.
3. Turn climate control back on, change the setting from "HI" to 65 degrees and the fan all the way up. Turn the control off. Drive 10+ min. Still blowing cool air.
Acting as if the mode door or vent isn't completely closing. It does seem to be affected by the vehicles speed. So I'm guessing it is just air moving into and through the system. Not really a issue, just a bother.
The Following User Says Thank You to Kiske For This Useful Post:
ZionsWrath (04-07-2014)
Old 04-07-2014, 09:08 PM   #2
vroom4
Turn on the recirc.
vroom4 is offline   Reply With Quote
The Following 2 Users Say Thank You to vroom4 For This Useful Post:
Kiske (04-07-2014), ZionsWrath (04-07-2014)
Old 04-07-2014, 09:09 PM   #3
husker741
It's the crickets farting.
husker741 is offline   Reply With Quote
The Following 4 Users Say Thank You to husker741 For This Useful Post:
AznBRZer (04-07-2014), kuhlka (04-10-2014), supramkivtt2jz (04-08-2014), ZionsWrath (04-07-2014)
Old 04-07-2014, 09:14 PM   #4
ZionsWrath
Thanks
ZionsWrath's Avatar
Close vents, put temp control to all the way blue, problem solved. The car will still get warm because it is so small and the transmission and drive shaft are right next to you.
Old 04-07-2014, 09:18 PM   #5
mike the snake
With the system OFF, push the RECIRC button, it still works with the system off.
This stops any and all air from blowing when the system is off.
Mine blows warm air otherwise, with the system OFF and temp to cold. RECIRC ON and no air blows at all.
The Following User Says Thank You to mike the snake For This Useful Post:
Kiske (04-07-2014)
Old 04-07-2014, 09:54 PM   #6
Luis_GT
yep, turn recirc on, that should stop outside air from coming in.
Old 04-08-2014, 11:41 PM   #7
BagOfArms
Drives: 2013 Scion FR-S (Asphalt)
You can use this property to your advantage, too. If you're driving on the highway (~70mph), the airflow is about the same as having the fan on the lowest setting. If I'm on a road trip and it's cold outside, I'll put the windows up, leave the fan speed at "0", turn "recirc" off to let the air blow in from the outside, then I adjust the temperature control knob until it's comfortable.
BagOfArms is offline   Reply With Quote
Old 04-09-2014, 06:22 PM   #8
fistpoint
Drives: Supercharged Golf Cart
My last 5 vehicles including this one "leak" air out the vents even when all knobs are OFF, but recirculate is NOT on...this is normal.
What isn't normal(for any vehicle I've owned over the last 24 years, all Hondas), is the air being warmer than it should be regardless of where the temp setting is. This is just poor design and found in numerous other vehicle brands, but not all.
fistpoint is offline   Reply With Quote
How cold is your a/c blowing? jermyzy Issues | Warranty | Recalls / TSB 68 08-18-2013 04:29 PM
Supra Blowing Up radroach Off-Topic Lounge [WARNING: NO POLITICS] 2 07-21-2013 10:14 PM
Passenger side HID Ballast keep blowing CharlieChaos Cosmetic Modification (Interior/Exterior/Lighting) 3 04-13-2013 01:13 PM
Did the issue with the air vents blowing hot ever get resolved? fiveoneoh Scion FR-S / Toyota 86 GT86 General Forum 25 09-05-2012 02:21 AM
A/C Compressor blowing hot? Is this normal? SocalBurt Engine, Exhaust, Transmission 3 08-22-2012 08:10 AM
