Old 03-03-2016, 08:30 PM   #337
Deep Six
Deep Six's Avatar
Drives: 2013 FRS / 2013 427 Vert
Originally Posted by xsnapshot View Post
Were you on E85? 93? 91? Just curious.
E85 with flex fuel kit. Actual ethanol at the time was 82.
[SIGPIC][/SIGPIC]
2013 FR-S Asphalt BC Coils/Rev Works UEL header/HKS Front Pipe/Racing Brake BBK/Shorai LW Battery/ACT 6 Puck Clutch/FBM Radiator & Oil Pan/JR Oil Cooler/Jackson Racing High Boost C30/Rev Works Built Motor
2016 Audi TTS APR Tuned
Deep Six is offline   Reply With Quote
Old 03-03-2016, 08:39 PM   #338
Deep Six
Deep Six's Avatar
Those who are asking me who tuned the car are missing the point. This tuner has dozens of cars doing fine with higher power levels than I was making.
Motors are machines and are not infallible, shit breaks. Everyone I know who tracks their car regularly has broken something, actually several things.
[SIGPIC][/SIGPIC]
The Following 4 Users Say Thank You to Deep Six For This Useful Post:
Bykov (03-03-2016), FRS Justin (03-03-2016), Icecreamtruk (03-04-2016), totopo (03-03-2016)
Old 03-04-2016, 08:06 AM   #339
Andew727
Drives: Scion FR-S
Originally Posted by xkalelx View Post
Ugh. Well, that should make it an easy decision for most people then to go ahead and upgrade to aftermarket pistons. Im not an expert by any means, but paying extra money for an extra operation that inherently weakens (you know what I'm saying, dont argue with me) the small end of the rod to retain a stock piston seams so crazy to me. Just apply the cost of modifying the rod towards better pistons and have a more bulletproof setup.
i wanted to maintain the 12.5 to 1 cr. i hevent been able to find anyone who stocks this CR. id have to get the made.
Andew727 is offline   Reply With Quote
Old 03-04-2016, 11:51 AM   #340
blueap2
Drives: '14 FR-S
@Andew727
Contact Outfront Motorsports. I believe Jeremy has some custom CP pistons for our engine in 12.5:1 CR
blueap2 is offline   Reply With Quote
Old 03-04-2016, 12:00 PM   #341
CSG Mike
CSG Mike's Avatar
We do 12.5:1 CR pistons
DriftinFRS (04-16-2016)
Old 03-04-2016, 02:23 PM   #342
Andew727
Drives: Scion FR-S
price? and you have them in stock? i know they can be made but ive already been waiting for 4 months on parts. not looking to wait around for another few weeks on pistons. ill just machine the new rods down if thats the case.
Old 03-04-2016, 03:15 PM   #343
CSG Mike
CSG Mike's Avatar
Built to order; I don't think we've ever had anyone ask for pistons without wanting a host of other options (WPC, Ceramics, etc.).
Andew727 (03-04-2016)
Old 04-14-2016, 09:53 PM   #344
SPCorBUST
SPCorBUST's Avatar
Looking like the San Andreas fault line on the top of my motor...
I'd like the next motor to be 12.5:1 CR, 7.5k redline (maybe slightly higher if it can be managed safely), C38, HBP, E85, I'm exploring what the motor needs to be safe under those conditions.
Setup 3: JR C30, DW 700, Grams 265, 3bar, FlexFuel, Moto-East
Setup 4: JR C30 HBP, DW 700, Grams 265, 3bar, FlexFuel, Church
Setup 5: JR C30 HBP, DW 700, DW 300, 3bar, FlexFuel, Delicious, Built Motor
Setup 6: JR C30 HBP, DW 700, DW 300, 3bar, FlexFuel, Delicious, Closed Deck Built Motor
SPCorBUST is offline   Reply With Quote
Old 04-14-2016, 09:58 PM   #345
SPCorBUST
SPCorBUST's Avatar
Originally Posted by Deep Six View Post
It can happen to anyone which is not the same thing as saying it will happen to everyone. More track days, adding power, especially forced induction simply increases the likelihood that something will break and it will probably a rod.
Mine popped recently after about two weeks of forced induction. I went with the "safest" supercharger system, had it conservatively tuned to 20 degrees of advance and a 7K limiter, have the JR oil cooler and a full blown radiator but it still threw a rod accelerating onto a freeway which cut a trench across the top of the block.
Moral of the story is that blame is not an issue, understanding the potential risk and how modifications will change the odds is. You can not bet your motor that having a good tune and cooling provides any guarantee, they just change the odds a little more in your favor. I will be starting a new thread soon focused on the choices to be made when replacing a blown motor, Thankfully I have the resources to do what I want and I really expected to eventually have a built motor or a V8.
BTW there are 4 other cars with blown motors at the same shop in Orlando as I write this so yes there is an issue.
Did you already start that thread?
Old 04-15-2016, 04:48 PM   #346
Deep Six
Deep Six's Avatar
I haven't, been very busy with work and recuperating from a Chump car crash. I have laid out a build for the car but had to fund a new daily driver for my wife first. That's now done so now it's time to make the FRS much more track focused.
I will begin a thread soon or join yours if you want to get one started. The damage to your block looks remarkably similar to mine. Wonder if the rods are breaking at a specific point in the stroke ?
I am starting with a new oem block, going to forego having it sleeved and plan to use Wise Co 11.5 pistons.
[SIGPIC][/SIGPIC]
The Following User Says Thank You to Deep Six For This Useful Post:
SPCorBUST (04-15-2016)
Old 04-15-2016, 05:57 PM   #347
SPCorBUST
SPCorBUST's Avatar
I've also sort of laid something out but I'm admittedly a noob when it comes to building motors. I found a couple threads on building motors here on the forum as well as a couple shopping lists but nothing that runs through the available part options, why to pick one vs another based on manufacturer and failure point, what you can reuse vs what you absolutely want new, and other factors. At least, I'm curious about those things.
Old 04-15-2016, 10:00 PM   #348
Kiske
Kiske's Avatar
Drives: RX-7 / BRZ
I'm in the same boat of looking for options to build. I'm having a hard time though justifing a DIY on this engine though. I can't really find much money to be saved vs buying a block from Full Blown or MAPerformance... at best I'm saving $500 when I fully finish my shopping cart and thats not getting some of the benefits the short block packages have such as being balanced and blueprinted... :/
The Following User Says Thank You to Kiske For This Useful Post:
Luftwaffel (04-16-2016)
Old 04-16-2016, 12:26 AM   #349
Luftwaffel
Boost Creep
Luftwaffel's Avatar
Drives: 2016 HyperBlue BRZ
Yeah, I have a hard time grasping how the actual fuck the individual components and a DIY rebuild are almost the same price as just ordering a short block and then getting the core charge back. It really makes no sense and even seems a little shady to me, actually. Some price fuckery going on IMO.
SBD400X Turbocharged 2016 Series.HyperBlue BRZ
Luftwaffel is offline   Reply With Quote
Old 04-19-2016, 08:33 PM   #350
SPCorBUST
SPCorBUST's Avatar
if you're looking to retain stock 12.5 CR, is there any reason to upgrade from the OEM pistons?
kill brain cells, not facts
FlexFuel and Facts Shiv@Openflash Software Tuning 74 05-07-2025 04:28 AM
Anyone Else? Hearters Blowing when off. Kiske Issues | Warranty | Recalls / TSB 7 04-09-2014 05:22 PM
How cold is your a/c blowing? jermyzy Issues | Warranty | Recalls / TSB 68 08-18-2013 03:29 PM
Supra Blowing Up radroach Off-Topic Lounge [WARNING: NO POLITICS] 2 07-21-2013 09:14 PM
Facts you may or may not know about your GT86/BRZ/FR-s FiRStsc10n Scion FR-S / Toyota 86 GT86 General Forum 41 07-09-2013 03:05 PM
