#57 | |
Custom User Title
Drives: Spaceship
Unfortunately, I don't have any more detailed photos. |
| The Following User Says Thank You to alexand3r For This Useful Post: | yomny (01-18-2015) |
#58 |
Drives: 2013 FRS Whiteout
Thats alright man, you've been plenty helpful. I was going to tackle this without removing the TB only to find out it was probably necessary then have nightmares on whether i needed to run to the dealer to grab a gasket. You saved me all that. I just got myself plenty of clamps and port caps to block off and clamp anything necessary.
GTX2867R, moto-tuned , tomei op , motiv fp , Invidia Q300 ti , Rota titan 17x9 +42 , nt555 255/40 , ST coilovers w/cascam , Hotchkis sways
#59 | |
Custom User Title
Drives: Spaceship
Glad I could help. I found that the hoses required different sized clamps to get a tight fit, as well. I can't remember the exact sizes, but a little trial tug on each will let you know for sure. I believe I used a stainless core zip tie (as well as the clamp) on one for peace of mind, but the Dorman clamps that I used were pretty crappy so ymmv. |
#60 |
I got a box with pretty much ever size available lol and some regular ss clamps as well as some that look like they're for fuel lines. Lol after making me go through all this trouble these suckers ain't going anywhere.
#61 |
Drives: 2014 BRZ Limited [6MT/SWP]
Insane how easy these hoses come off, I had my wastegate line secured to one of these EVAP lines not realizing it pulled it right off. Just finished mine this morning, didn't have to remove anything besides the A/C though.. figured out that if you attach the corbin clamps to the hoses then you can manage to shove them back on the plastic nipple with out the use of pliers. Just some patience with it and all 5 are now snug.
#62 |
Drives: Toyota GT86 2015 Black Aero Kit.
i managed to clamp both sides of mine down by removing the throttle body. haha i pulled on the lines just a bit, and it slipped right off. Should of been clamped down from factory!
#63 |
Drives: 2013 BRZ black
The throttle body has a rubber o-ring gasket so it is reusable. No need to replace, just re-torque TB bolts to reseal.
Can we make this a sticky thread @Hachiroku?
#64 |
Drives: White 2014 BRZ
Should do this even at 5psi or less (ESC)?
JDL Turbo kit - Ecutek, HRI tuned.
#66 |
Ned flanders
Drives: 13 BRZ, 16 Hellcat, 22 Ram 2500
you people are crazy pulling the ac compressor off and all...I literally unbolted the bracket for the evap solenoid and pulled it out and clamped the hoses. 5 minute job
797Performance.com
| The Following User Says Thank You to nickmerronesucks For This Useful Post: | DAEMANO (02-07-2016) |
#67 |
Any pics to help? I'm about to do this soon.
#68 | |
I Love custom Turbo kits
Drives: Limited BRZ
| The Following 2 Users Say Thank You to Sportsguy83 For This Useful Post: | nickmerronesucks (02-09-2016), xkalelx (02-09-2016) |
#69 |
Ned flanders
Feel arouns the back of the intake manifold there is a 10mm nut or bolt. Unbolt it. Then shove hand in through front and pull and itll come out. Install clamps and shove back in and try to bolt it back in
Sent from my SPH-L720T using Tapatalk
797Performance.com
#70 |
Drives: 2015 FR-S Release Series 1.0
Found a few pics showing how to remove the evap solenoid assembly in the factory service manual, seems like it can be done without removing the ac compressor.
| The Following 2 Users Say Thank You to avishenoy1 For This Useful Post: | halfwaytobedlam (01-01-2024), stevo585 (04-15-2016) |
| DIY clamping the evap vacum ports under the manifold!! | charged86 | DIY (Do-It-Yourself) Guides | 9 | 04-08-2015 06:56 PM |
| Intake Manifold | Bu-Tang | Engine, Exhaust, Transmission | 29 | 12-06-2014 01:43 PM |
| Aluminium intake manifold? | Hempo | Engine, Exhaust, Transmission | 18 | 06-27-2013 01:19 PM |
| WTB: intake manifold | carlitosway6891 | Engine, Exhaust, Bolt-Ons | 0 | 06-22-2013 02:24 PM |
| Custom Hello Kitty Intake Manifold Cover (seriously?) | Hancha Group | Cosmetic Modification (Interior/Exterior/Lighting) | 6 | 04-01-2013 01:36 PM |
