Old 06-16-2012, 08:22 PM   #1
percyng
Drives: White BRZ 6MT
Help!! No sound when connect my ipod/iphone with cable
Hi all, I am new to the forum and just got my BRZ today (I am in Canada).
However, I connect my iphone use USB cable but has no sound. The deck shows it is playing (the time bar is moving) but no song.
When I use Bluetooth stream it has no problem.
I already tried:
1. different ipod & iphone (iphone 4, old ipod video, newer 8GB nano) still no sound
2. I use 3 different cables and it is not defect cable
Is my deck defected?
Any suggestion, comment is welcome. Thanks
percyng is offline   Reply With Quote
Old 06-16-2012, 08:28 PM   #2
8987846
Drives: BRZ MT SWP
both the usb and the aux need to be connected, you did that right?
8987846 is offline   Reply With Quote
Old 06-16-2012, 08:34 PM   #3
percyng
Yes I did plug in both but no sound. Then I found out I also need to set the 'AV1' to 'Ipod' and it works now.
Thank you so much for the suggestion
Old 06-16-2012, 08:40 PM   #4
8987846
Drives: BRZ MT SWP
you're welcome.
may i ask when did you place your order?
i placed mine on may 4th, but mine didn't show up in the first batch.
Old 06-16-2012, 08:41 PM   #5
86_ZN6
86_ZN6's Avatar
Drives: 86 ZN6
it should play with only either one connected.
i preder usb since it charges the the iphone/ipod
86_ZN6 is offline   Reply With Quote
Old 06-16-2012, 08:43 PM   #6
percyng
Not sure if Canadian model is different, but our deck need to use the cable that comes with the car. And both 3.5mm & usb need to plug in to make the ipod works.
Old 06-16-2012, 08:44 PM   #7
percyng
you're welcome.
Place my order Dec 22, 2011.
First one order on the list at Subaru Calgary.
Old 06-16-2012, 08:45 PM   #8
86_ZN6
86_ZN6's Avatar
Drives: 86 ZN6
o wow! yeah i guess canadian cars have a different setup.
too many wires!!! arrrgghh
Old 06-16-2012, 08:45 PM   #9
8987846
Drives: BRZ MT SWP
wow....no wonder you got the car so early....
Old 06-16-2012, 08:51 PM   #10
percyng
BTW, except for mine. I also saw one white and one black waiting for PDI at that dealership.
Wonder if those two owners are member of this forum
Old 06-16-2012, 09:18 PM   #11
sharky
Drives: Infiniti G35
Did you double check if your iphone is stream through bluetooth still?
I had a similar problem with our Acura, sometimes even with the cable plugged in, the iphone is streaming to bluetooth and the car's stereo is trying to get it through the cable. When that happens, I need to change iphone's output by touch the following icon:
sharky is offline   Reply With Quote
Old 06-17-2012, 02:08 AM   #12
Enemies
Drives: '13 SWP Sport-Tech (Limited)
Percy, did you first try maxing the volume on the ipod?
I had nothing happening on my Android until I raised up the volume on it to max.
Enemies is offline   Reply With Quote
Old 06-17-2012, 10:38 AM   #13
sdiver68
sdiver68's Avatar
Drives: 2013 BRZ Limited
I had to update the firmware on my iPod using iTunes.
Now it works great USB only.
sdiver68 is offline   Reply With Quote
Old 06-17-2012, 10:54 AM   #14
ashtray
As Seen On The Internet
Drives: 2003 WRX, 2013 BRZ, 442
Mine only worked after I unsynced the Bluetooth.
ashtray is offline   Reply With Quote
DIY Nav unit in FRS with e-brake bypass and iPhone cable by cupholders Nitro DIY (Do-It-Yourself) Guides 42 07-02-2016 11:10 AM
Subaru iPod Connector Cable? Kimsey47 Audio/Visual, Electronics, Infotainment, NAV 25 07-05-2012 02:49 PM
ipod/iphone music control via usb? 86_ZN6 Electronics | Audio | NAV | Infotainment 20 06-17-2012 04:44 AM
iPod/iPhone connectivity? Tomcat9700 Scion FR-S / Toyota 86 GT86 General Forum 9 01-08-2012 06:45 PM
