#239 | |
What data channels do we log for specifically?
#242 | |
Drives: Toyota 86 GTS
#243 |
Drives: 2015 HL FR-S
So can I use this new tune and change the VVT that you posted shiv for JDL UEL headers? or will this cause issues? @shiv@openflah I'm in love with this OFT, thank you again so much for putting out such a great product and support!!
Been hard to find the time to get to changing my tune =( |
#244 | |
Drives: 2016 Raven FR-S
#245 | |
commanded afr LTFT STFT maf voltage Thats about it
#246 | |
Drives: 2014 WRB Bravo Romeo Zulu
#247 |
Drives: 13 White MT FR-S
Top end feels a little more peppy. Nice job shiv!
| The Following 2 Users Say Thank You to ML For This Useful Post: | Shiv@Openflash (04-12-2016), Yoshoobaroo (04-12-2016) |
#248 |
Drives: 2014 BRZ Limited SWP 6MT
anyone with Tomei UEL tried these new tunes out yet? Any knock or issues? Any feedback appreciated
| The Following User Says Thank You to tdotBRZ For This Useful Post: | Ahsila (04-13-2016) |
#249 |
Noob
Drives: FR-S Mammogram
Will just go EcuTek if I'm gong to do an optimized tune. My request is more of a curiosity thing than a request - I completely understand it'd be at the goodwill of OFT.
#250 |
Important note for AT owners who've added a soft RPM limit -- the Base Timing B table in the AT roms has 7600 at full timing. Be careful if you're copying tables over
| The Following User Says Thank You to phrosty For This Useful Post: | FRSBRZGT86FAN (04-13-2016) |
#251 |
Drives: Toyota GT86 6M/T
Say I want to try those new maps on my european GT86 running A00G, would I just have to change the following 12 tables @jvincent ?
Primary open loop fueling Engine Load Limit B Maximum (RPM) Engine Load Limit C Maximum (RPM) Base Timing B Knock Correction Advance Max A Timing Compensation (IAT) Timing Compensation Per Cylinder A Timing Compensation Per Cylinder B Intake Cam Advance Angle Safe AVCS Intake Cam Advance Angle Normal AVCS Exhaust Cam Retard Angle Safe AVCS Exhaust Cam Retard Angle Normal AVCS I find it quite hard to compare the new stage 2 map with my current one because Shiv states that those should only be edited with their supplied XMLs, and usually I use Kodename's template. Therefore a lot of tables are missing or placed somewhere else... Hope somebody can help me
#252 |
@cawith, when you compare your current ROM with the new ROM using Kodenames XML, what other differences do you see?
You should be OK just copying over those tables though. |
| Just how noticeable is OFT+OFH and stage 2 tune? | BBYZILA | Software Tuning | 58 | 03-20-2018 11:56 AM |
| OFT 2.0 Stage 1 93 Tune | MurderRider | Software Tuning | 57 | 03-21-2016 12:30 AM |
| Top Gear Solutions| OpenFlash Tablet Tune| Stage 1 Tune, Stage 2, Custom and E85 | TopGearSolutions | Engine, Exhaust, Bolt-Ons | 90 | 04-14-2014 08:15 PM |
| FA20club.com Turnaround Times On Modified Tune Files | FR-S Matt | Software Tuning | 103 | 11-13-2013 01:48 PM |
| So whate does stage 3 tune do? I already have 2 | Frsexxxy | Engine, Exhaust, Transmission | 17 | 05-14-2013 06:30 AM |
