04-12-2016, 07:07 PM | #239 | |
What data channels do we log for specifically?
04-12-2016, 07:11 PM | #240 |
I can't remember the list off the top of my head, but it's in @steve99's tuning thread.
04-12-2016, 07:39 PM | #242 | |
Drives: Toyota 86 GTS
04-12-2016, 07:42 PM | #243 |
Drives: 2015 HL FR-S
So can I use this new tune and change the VVT that you posted shiv for JDL UEL headers? or will this cause issues? @shiv@openflah I'm in love with this OFT, thank you again so much for putting out such a great product and support!!
Been hard to find the time to get to changing my tune =( |
04-12-2016, 08:13 PM | #244 | |
Drives: 2016 Raven FR-S
04-12-2016, 08:14 PM | #245 | |
commanded afr LTFT STFT maf voltage Thats about it
04-12-2016, 08:43 PM | #246 | |
Drives: 2014 WRB Bravo Romeo Zulu
04-12-2016, 09:32 PM | #247 |
Drives: 13 White MT FR-S
Top end feels a little more peppy. Nice job shiv!
The Following 2 Users Say Thank You to ML For This Useful Post: | Shiv@Openflash (04-12-2016), Yoshoobaroo (04-12-2016) |
04-12-2016, 11:41 PM | #248 |
Drives: 2014 BRZ Limited SWP 6MT
anyone with Tomei UEL tried these new tunes out yet? Any knock or issues? Any feedback appreciated
The Following User Says Thank You to tdotBRZ For This Useful Post: | Ahsila (04-13-2016) |
04-13-2016, 12:16 AM | #249 |
Noob
Drives: FR-S Mammogram
Will just go EcuTek if I'm gong to do an optimized tune. My request is more of a curiosity thing than a request - I completely understand it'd be at the goodwill of OFT.
04-13-2016, 12:54 AM | #250 |
Important note for AT owners who've added a soft RPM limit -- the Base Timing B table in the AT roms has 7600 at full timing. Be careful if you're copying tables over
The Following User Says Thank You to phrosty For This Useful Post: | FRSBRZGT86FAN (04-13-2016) |
04-13-2016, 09:06 AM | #251 |
Drives: Toyota GT86 6M/T
Say I want to try those new maps on my european GT86 running A00G, would I just have to change the following 12 tables @jvincent ?
Primary open loop fueling Engine Load Limit B Maximum (RPM) Engine Load Limit C Maximum (RPM) Base Timing B Knock Correction Advance Max A Timing Compensation (IAT) Timing Compensation Per Cylinder A Timing Compensation Per Cylinder B Intake Cam Advance Angle Safe AVCS Intake Cam Advance Angle Normal AVCS Exhaust Cam Retard Angle Safe AVCS Exhaust Cam Retard Angle Normal AVCS I find it quite hard to compare the new stage 2 map with my current one because Shiv states that those should only be edited with their supplied XMLs, and usually I use Kodename's template. Therefore a lot of tables are missing or placed somewhere else... Hope somebody can help me |
04-13-2016, 09:14 AM | #252 |
@cawith, when you compare your current ROM with the new ROM using Kodenames XML, what other differences do you see?
You should be OK just copying over those tables though. |
Similar Threads | ||||
Just how noticeable is OFT+OFH and stage 2 tune? | BBYZILA | Software Tuning | 58 | 03-20-2018 11:56 AM |
OFT 2.0 Stage 1 93 Tune | MurderRider | Software Tuning | 57 | 03-21-2016 12:30 AM |
Top Gear Solutions| OpenFlash Tablet Tune| Stage 1 Tune, Stage 2, Custom and E85 | TopGearSolutions | Engine, Exhaust, Bolt-Ons | 90 | 04-14-2014 08:15 PM |
FA20club.com Turnaround Times On Modified Tune Files | FR-S Matt | Software Tuning | 103 | 11-13-2013 01:48 PM |
So whate does stage 3 tune do? I already have 2 | Frsexxxy | Engine, Exhaust, Transmission | 17 | 05-14-2013 06:30 AM |
