Old 04-12-2016, 07:07 PM   #239
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
Originally Posted by jvincent View Post
For those of you who haven't checked in RomRaider yet, there are 12 tables that have changes when you compare the OTS tunes to the OFH optimized tune. They are:
Primary open loop fueling
Engine Load Limit B Maximum (RPM)
Engine Load Limit C Maximum (RPM)
Base Timing B
Knock Correction Advance Max A
Timing Compensation (IAT)
Timing Compensation Per Cylinder A
Timing Compensation Per Cylinder B
Intake Cam Advance Angle Safe AVCS
Intake Cam Advance Angle Normal AVCS
Exhaust Cam Retard Angle Safe AVCS
Exhaust Cam Retard Angle Normal AVCS
What does all of this mean? Just that the tunes are different. When you look at the areas you'll see that the changes are designed to go together since many of them are in the same general RPM/load area.
Using these with a different header will clearly be a YMMV situation. If you are looking to try them out just go ahead and log the data.
What data channels do we log for specifically?
Old 04-12-2016, 07:11 PM   #240
jvincent
jvincent's Avatar
I can't remember the list off the top of my head, but it's in @steve99's tuning thread.
Old 04-12-2016, 07:32 PM   #241
B-R-Z
I love peanut butter
B-R-Z's Avatar
Drives: 2013 SWP BRZ Limited
Does anyone have any butt dyno numbers yet on these new tunes?
B-R-Z is offline   Reply With Quote
Old 04-12-2016, 07:39 PM   #242
Wayno
Wayno's Avatar
Drives: Toyota 86 GTS
Originally Posted by Shiv@Openflash View Post
Hi guys,
The VVT tables are optimized specifically for the OFH. I cannot predict how it will work with other headers. I wouldn't say that they are incompatible with other headers. All I can say is that they may not be optimized. These maps are pretty aggressive so please don't treat them like any other OTS map.
The AVCS maps fell much better than the old maps. As a bonus they also make AFR better behaved around the 3700rpm mark. I've had them included in my examples for all UEL since about a week after you sent them to testers.
Old 04-12-2016, 07:42 PM   #243
HLHachiRoku
Drives: 2015 HL FR-S
So can I use this new tune and change the VVT that you posted shiv for JDL UEL headers? or will this cause issues? @shiv@openflah I'm in love with this OFT, thank you again so much for putting out such a great product and support!!
Been hard to find the time to get to changing my tune =(
HLHachiRoku is offline   Reply With Quote
Old 04-12-2016, 08:13 PM   #244
iJeff
iJeff's Avatar
Drives: 2016 Raven FR-S
Do it at your own risk. He wouldn't recommend it.
iJeff is offline   Reply With Quote
Old 04-12-2016, 08:14 PM   #245
FRSBRZGT86FAN
IAM
commanded afr
LTFT
STFT
maf voltage
Thats about it
Old 04-12-2016, 08:43 PM   #246
Stealthy
Drives: 2014 WRB Bravo Romeo Zulu
Originally Posted by Jyn View Post
I understand supporting your product first (OFH) and have no problem with that. I also understand that there's an exponentially large amount of aftermarket setups, but my question is: are there plans to have similar optimizations for other headers such as JDL, Borla, Tomei?
They offer custom tuning services if you want more optimization
Stealthy is offline   Reply With Quote
Old 04-12-2016, 09:32 PM   #247
ML
ML's Avatar
Drives: 13 White MT FR-S
Top end feels a little more peppy. Nice job shiv!
The Following 2 Users Say Thank You to ML For This Useful Post:
Shiv@Openflash (04-12-2016), Yoshoobaroo (04-12-2016)
Old 04-12-2016, 11:41 PM   #248
tdotBRZ
tdotBRZ's Avatar
Drives: 2014 BRZ Limited SWP 6MT
anyone with Tomei UEL tried these new tunes out yet? Any knock or issues? Any feedback appreciated
tdotBRZ is offline   Reply With Quote
The Following User Says Thank You to tdotBRZ For This Useful Post:
Ahsila (04-13-2016)
Old 04-13-2016, 12:16 AM   #249
Jyn
Noob
Jyn's Avatar
Drives: FR-S Mammogram
Will just go EcuTek if I'm gong to do an optimized tune. My request is more of a curiosity thing than a request - I completely understand it'd be at the goodwill of OFT.
Jyn is offline   Reply With Quote
Old 04-13-2016, 12:54 AM   #250
phrosty
Important note for AT owners who've added a soft RPM limit -- the Base Timing B table in the AT roms has 7600 at full timing. Be careful if you're copying tables over
phrosty is offline   Reply With Quote
The Following User Says Thank You to phrosty For This Useful Post:
FRSBRZGT86FAN (04-13-2016)
Old 04-13-2016, 09:06 AM   #251
cawith
Drives: Toyota GT86 6M/T
Say I want to try those new maps on my european GT86 running A00G, would I just have to change the following 12 tables @jvincent ?
Base Timing B
I find it quite hard to compare the new stage 2 map with my current one because Shiv states that those should only be edited with their supplied XMLs, and usually I use Kodename's template. Therefore a lot of tables are missing or placed somewhere else...
Hope somebody can help me
cawith is offline   Reply With Quote
Old 04-13-2016, 09:14 AM   #252
jvincent
jvincent's Avatar
@cawith, when you compare your current ROM with the new ROM using Kodenames XML, what other differences do you see?
You should be OK just copying over those tables though.
Just how noticeable is OFT+OFH and stage 2 tune? BBYZILA Software Tuning 58 03-20-2018 11:56 AM
OFT 2.0 Stage 1 93 Tune MurderRider Software Tuning 57 03-21-2016 12:30 AM
Top Gear Solutions| OpenFlash Tablet Tune| Stage 1 Tune, Stage 2, Custom and E85 TopGearSolutions Engine, Exhaust, Bolt-Ons 90 04-14-2014 08:15 PM
FA20club.com Turnaround Times On Modified Tune Files FR-S Matt Software Tuning 103 11-13-2013 01:48 PM
So whate does stage 3 tune do? I already have 2 Frsexxxy Engine, Exhaust, Transmission 17 05-14-2013 06:30 AM
