Old 04-11-2016, 09:18 PM   #785
Sojhinn
Lightning McQueen Driver
Sojhinn's Avatar
Drives: Limited Red 6MT BRZ
Phantom FTS Electric Supercharger Owners Thread
Originally Posted by Algreen View Post
Hi All,
I started my ESC install this weekend too. A couple of questions came up.
1. With the soldered fuse, are people using an add-a-fuse, or replacing the radio 10amp fuse for the voltmeter? I've never seen a wire soldered right to the fuse like this. Is it Necessary for the voltmeter to be fused?
2. I'm using 2 PC680 for the dump pack per Rob's recommendation. Curious if anyone else has had success with this configuration.
3. Is anyone running an AFR gauge and what type of AF ratio are you shooting for, for best /safest performance? Somewhere between 11-12?
Thanks!
1) the soldered fuse is the setup for the new systems. It works great. Look at my install video for where you install it at. But I believe it 5 slots from the front of the car closest to the center of the vehicle.
2) if rob is suggesting the pc680s use Em. Make sure you get them with the metal jackets.
3) I use the oft to keep track of my afr. I sometimes hit the 11s but I'm running An aftermarket intake.
Installed Mods:
Old 04-11-2016, 10:54 PM   #786
Urmyson
Procede Maps
I just finished installing the Procede Controller. Can some one link me some maps to try out?
Urmyson is offline   Reply With Quote
Old 04-11-2016, 10:55 PM   #787
Sojhinn
Sojhinn's Avatar
Manual or auto?
Installed Mods:
Old 04-11-2016, 10:59 PM   #788
Sojhinn
Sojhinn's Avatar
Just post it anyway:
Both tested on a manual car:
Smooth like butter:
https://drive.google.com/open?id=0B1...kxNcUdvWGtqMG8
Sport:
https://drive.google.com/open?id=0B1...G43aUtZTFBNOTQ
Installed Mods:
Old 04-11-2016, 11:03 PM   #789
Urmyson
Smooth like butter:
Sport:
Mine is an auto, will these work for me?
Old 04-11-2016, 11:04 PM   #790
Sojhinn
Sojhinn's Avatar
They will but they wouldn't be as fine tuned. It will be way better then what's loaded.
Feel free to try them out and if you don't like them let me know. I can modify it and try to suit your needs as long as you can tell me at what rpms and how much throttle you are having issues at.
Installed Mods:
Old 04-11-2016, 11:09 PM   #791
Urmyson
Thanks, I'll give it a shot
Old 04-11-2016, 11:12 PM   #792
Gums
Drives: SWP BRZ
Originally Posted by TM View Post
About 5 months in with the pc680 starter battery. I think it's starting to fail. 1-2 weeks ago, I left the dome light on and completely drained the battery. Car started fine the week after when I drove it every day. Didn't start my car for a couple of days, and it didn't hold enough of a charge to start my car. A couple of days later, I turned my car to accessory on for about 15 minutes, and battery couldn't turn over the engine.
If the PC680 is like the stock battery (which I suspect it is) once it is completely flat the battery won't charge above 8 volts or so using the cars alternator.
Get a battery tender type charger (you'll have to ask, not sure of the correct name, paid around $40 for mine, some over $100) keep it connected overnight and battery should come back up to 12-14 volts in a few weeks max.
Gums is offline   Reply With Quote
Old 04-11-2016, 11:57 PM   #793
Urmyson
I drove around with the sport map on and its way better than the stock one. Question though, the volt meter never dipped below 26.0. Even when I was WOT through 1-4 gear, is it supposed to do that? When I was using the pedal switch it would hit 21 or 22 almost instantly and drop from there.
Old 04-11-2016, 11:58 PM   #794
Sojhinn
Sojhinn's Avatar
That means the throttle is not mapped correctly.
There's a way to do that in the procede app.
Installed Mods:
Old 04-12-2016, 12:01 AM   #795
Urmyson
Is there a guide for that?
Old 04-12-2016, 12:27 AM   #796
Sojhinn
Sojhinn's Avatar
Not sure I haven't seen it. I could mess with the software to find it. But I haven't actually ever done it.
Installed Mods:
Old 04-12-2016, 03:56 AM   #797
Gums
Drives: SWP BRZ
Check the 3 connections to the compressor motor.
My voltmeter wasn't dropping below 26v yesterday. Noticed the black connector wasn't connected properly and black deposit on the terminals.
Red connector, whilst fully connected, was getting hot enough to melt the cable cover.
Will see how it goes tomorrow.
The Following 2 Users Say Thank You to Gums For This Useful Post:
keen as (04-14-2016), Sojhinn (04-12-2016)
Old 04-12-2016, 10:11 AM   #798
rhythmM
rhythmM's Avatar
Drives: 2014 Subaru BRZ Limited MT - White
Hey guys, what tune is everyone running on their cars with this kit? Just wondering because I recently took mines off to take my car into warranty. Hoping to reflash back with something someone thinks is better.
Edit: or most efficient
Phantom Super Charged - 2014 BRZ
rhythmM is offline   Reply With Quote
Jackson Racing Supercharger Owners Thread enivid Forced Induction 6041 11-28-2025 08:08 AM
Full throttle Electric Supercharger Build Thread fenton Forced Induction 11315 04-07-2025 06:42 PM
Kraftwerks Supercharger Owners Thread projek_01 Forced Induction 4310 04-07-2025 01:12 PM
phantom supercharger restrictions? Shinigunz Forced Induction 12 05-13-2014 03:28 AM
Drift-Office : Phantom Supercharger - Tuned! Drift-Office Forced Induction 67 10-25-2013 09:51 AM
