Old 04-03-2016, 01:58 PM   #57
Scenic Driver
Drives: 13 Subaru BRZ, 02 Audi TTQ
Originally Posted by gravitylover View Post
If you can get a ratchet in there why can't you get a torque wrench in too? I ask because I will most likely need to do this before the end of the summer.
It may be a problem on the drivers side but keep in mind that even if it does fit if you have to use an extension or u-joint the torque wrench isn't going to be accurate.
I've been working on cars for over 20 years and have never found the need to use a torque wrench with spark plugs. For 12.5 ft-lbs just snug them down until they are tight, if you're the type to muscle everything down then you shouldn't be working on delicate things like spark plugs.
I'm not against using a torque wrench, just not for everything.
Scenic Driver is offline   Reply With Quote
The Following 2 Users Say Thank You to Scenic Driver For This Useful Post:
86kahl (04-03-2016), humfrz (04-03-2016)
Old 04-03-2016, 02:21 PM   #58
gravitylover
Oh I agree, was just commenting on the mention of using one.
The Following User Says Thank You to gravitylover For This Useful Post:
Scenic Driver (04-04-2016)
Old 04-03-2016, 03:34 PM   #59
Tt3Sheppard
Tt3Sheppard's Avatar
Drives: Whiteout FR-S
Just make sure its more tight than not, I had an issue when I did mine the car was not firing all cylinders correctly.
2013 Ford Focus St
2013 Scion FR-S
2007 Honda Civic Si
2003 Acura RSX Type-S
1998 Ford Escort ZX2
Tt3Sheppard is offline   Reply With Quote
The Following 2 Users Say Thank You to Tt3Sheppard For This Useful Post:
ddevl_86 (02-26-2021), FRSToyota86 (04-11-2016)
Old 04-03-2016, 04:39 PM   #60
Norville Rogers
Drives: Subaru BRZ
Originally Posted by MrDinkleman View Post
For those of you who have changed plugs, how worn were they at 60k? Did they look like they needed replacement?
60k seems a little short... the Iridium plugs in my Yaris (RIP) were scheduled for 100k. I never did change them, even after 140k (when it was totaled).
Slightly more on my Peugeot 107 and it still starts first turn
Norville Rogers is offline   Reply With Quote
Old 04-11-2016, 12:13 AM   #61
zeal86
zeal86's Avatar
Drives:
Changed out my OEMs to HKS today...I'm in the middle of a bunch of installs so I had removed a lot of what was necessary to do the FSM method anyway... so I went with it. Well, kind of... there were a few things I did different but close enough..
Here are some pics from my install...
The Bottle Jack was great for this swap. My 86 is currently on jacks (14" off ground) so I was able to place the bottle jack on the ground... Luckily I hoarded a bad axle from the landing gear of a C550 because I used it to extend the jack while maintaining a solid jacking point.
This is a high as I raised either side...
I was able to torque the plugs and coil packs... the FSM method really made the swap almost frustration free.
Engine lifted on the passenger side...
You could see the work space created with the engine angled in these pics...
__________________________________________
projekt zeal86 build
zeal.eightsix Facebook
Instagram | zeal.eightsix
zeal86 is offline   Reply With Quote
The Following 11 Users Say Thank You to zeal86 For This Useful Post:
BRZoomTX (06-01-2016), DAEMANO (04-11-2016), FRSToyota86 (04-11-2016), GhostOp86 (10-11-2016), Guff (04-16-2016), hmong337 (04-11-2016), Imperius (02-11-2017), mx5 2nr (04-21-2016), nunonuna (04-11-2016), roddy (04-11-2016), tracerit (04-11-2016)
Old 04-11-2016, 05:34 PM   #62
tracerit
Drives: '13 SSM BRZ Limited 6MT
what's a resonable cost for labor to replace the spark plugs if I ask them to change them out while they fix a timing cover leak (which would require them to drop the engine)? Figured if they're taking it out, might as well do a bit more.
I'm only at 35k now but figured since it's out and if the price isn't too bad, i'd knock it out now.
tracerit is offline   Reply With Quote
Old 04-12-2016, 12:22 PM   #63
If the engine is out ........ maybe one hour (rounded up of course) of labor.
I'm guessing at around $50.
humfrz is online now   Reply With Quote
tracerit (04-12-2016)
Old 04-12-2016, 02:53 PM   #64
FRSToyota86
FRSToyota86's Avatar
Drives: 2013 Scion FRS
You have a lot of faith on that Jack. You must not be living on an earthquake zone. Thanks for the post really smart thinking I think it would be best if you had an engine support brace to double support the engine for safety.
Vortech V3 Supercharger| 12 PSI|E85 MotoEast Flexfuel kit|Crawford AOS| Mishimoto Oil Cooler|3"Perrin Resonated CBE| 3" JDL Front/Over Pipe|OpenFlash Performance Headers|Exedy Stage 2 Ceramic Clutch |Yonaka Coilovers|17x9 O.Z. Wheels| 245/40r/17|TRD Brake Pads|Perrin Master Cylinder Brace |ChaseBay SSBrake Lines|CF Side Fins|OEM Shark Fin Athena|Yospeed Console Plaque|R/T Shift Knob|Fog Lights|Backup Camera|Navigation| |TRD Quickshifter|Motul Gear Oil|
FRSToyota86 is offline   Reply With Quote
Old 04-16-2016, 01:05 AM   #65
FRSToyota86
Here is how I did it.
Sent from my SM-N915T using Tapatalk
Old 04-16-2016, 10:23 AM   #66
stevesnj
stevesnj's Avatar
This is just crazy to replace spark plugs. This is probably the biggest downfall of the boxer design.
My 2016 Build thread
The Following 2 Users Say Thank You to stevesnj For This Useful Post:
hmong337 (04-16-2016), Muaddib (04-17-2016)
Old 04-22-2016, 07:39 PM   #67
Haulin
Haulin's Avatar
Drives: 2013 Toyota GT 86
It looks like I am in for some pain. I have left it way too long (270,000KM) & now I am getting a P0350/351 code. Hopefully not a coil pack & just worn out spark plugs. One way to find out. lol
Haulin is offline   Reply With Quote
Old 04-22-2016, 09:09 PM   #68
atlbrz
Drives: Hyper Blue BRZ
While I have to agree an engine lift is safer than a jack, when I ask how they do it at the dealership, they said they just use a jack under the motor.
atlbrz is offline   Reply With Quote
Old 04-22-2016, 09:43 PM   #69
hmong337
Emperor JDM
hmong337's Avatar
Drives: '91 MR2 Gen3 3SGTE, '13 FRS
Wtf! You seriously have 270,000kms?!?!
hmong337 is offline   Reply With Quote
Old 04-22-2016, 10:03 PM   #70
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
Jesus Christ, I'm curious too, how does it drive and how has it aged at that many miles. At that mileage it's time for a full spark plug, coil pack and every fluid you can think of change.
Spark plugs for turbo whitefrs Forced Induction 88 05-05-2018 09:18 PM
boosted spark plugs? 350matt Forced Induction 9 08-09-2014 03:54 PM
Spark plugs Triumphrider Engine, Exhaust, Transmission 12 06-19-2014 10:47 AM
spark plugs subaruferrucci Engine, Exhaust, Transmission 22 04-10-2013 11:24 AM
