Old 04-10-2016, 11:59 PM   #29
Am I the only guy that has never had any issue at all with second? I just mentioned in the starting problems thread how I was baffled how some of these cars have issues and others do not. I have not once experienced any shifting problems even when very cold (I have zero incentive to lie about this) and am over 60K miles on the original tranny oil.
Remember, we've had this discussion. Midshaft swimming in molasses. Gotta be quick through neutral or the whole thing quits spinning fast.
Old 04-11-2016, 12:16 AM   #30
MisterSheep
Killed Scion
MisterSheep's Avatar
Drives: 2013 FR-S Whiteout
Originally Posted by tumbla.jr View Post
High pitched whine under partial load but only at speeds above 60.
Prior to changing from redline last week I could barely hear anything from my transmission.
Diff and trans were pretty dirty after 45K
Would you recommend redline? because I would like to replace the stock fluid in my trans but i'm iffy about going back to motul
Instagram: trevor.parque
Old 04-11-2016, 12:17 AM   #31
Perfectly normal photos. Mag plugs working as designed.
Whine is something, though. Which gears? I'm driving on a compromised trans right now.
Old 04-11-2016, 01:02 AM   #32
tumbla.jr
taicho
tumbla.jr's Avatar
Drives: The rEd Fr-S
Redline was perfect until I reached the 33k mark. After that I noticed that 2nd and 3rd would grind at operating temp or cold.
I like how smooth motul is but that's about it. Amazon was giving it away so I figured I would try it.
I'll give this junk 2 weeks and see.
tumbla.jr is offline   Reply With Quote
The Following User Says Thank You to tumbla.jr For This Useful Post:
MisterSheep (04-11-2016)
Old 04-11-2016, 01:04 AM   #33
tumbla.jr
taicho
tumbla.jr's Avatar
3rd 5th and 6th are notoriously loud above 4k.
Old 04-11-2016, 01:11 AM   #34
Does the pitch of the whine follow the engine, or the rear end?
When you say fifth whines, I suspect rear end. There is zero load on the transmission in fifth. The input and output shafts are coupled together so it's a straight shot from the engine into the rear end.
Old 04-11-2016, 01:54 AM   #35
tumbla.jr
taicho
tumbla.jr's Avatar
Nope it does not follow the engine. I'll get a recording of it soon as I leave for work in a few.
Ultramaroon (04-11-2016)
Old 04-11-2016, 08:25 AM   #36
Yes I remember. That is exactly why I asked the question and although I may not have worded it well it was not rhetorical. I could not see being the only one that never had an issue and now there are at least a couple of guys that go on record as agreeing.
Old 04-11-2016, 02:22 PM   #37
Yeah, I wouldn't say I had any issues at all. It isn't very forgiving but rewards the driver when operated properly.
Someone else mentioned it here. It also takes a LONG time to break in. My synchros didn't start grabbing effectively until after about 8 Kmi and kept getting better through 20Kmi.
Tcoat (04-11-2016)
Old 06-07-2016, 01:00 PM   #38
tumbla.jr
taicho
tumbla.jr's Avatar
Better late than never...
@Tcoat @Ultramaroon
Use headphones it helps
https://drive.google.com/folderview?...FE&usp=sharing
Old 06-07-2016, 01:24 PM   #39
@Tcoat @Ultramaroon
Will give a listen when at home.
Old 06-07-2016, 01:48 PM   #40
krayzie
Drive From Home
krayzie's Avatar
Drives: BRZ STI Performance
I've managed to experience the occasional grind in all 6 gears over the course of 27,000km and changed the fluid twice already in-between with Eneos Gear Oil. Much smoother operation than the stock oil.
It gets smoother if I shift gears quickly. When cold downshifting to 2nd gear requires a double clutch action otherwise it won't go in.
Everything seems normal to me.
krayzie is offline   Reply With Quote
The Following User Says Thank You to krayzie For This Useful Post:
Ultramaroon (06-07-2016)
Old 06-07-2016, 01:58 PM   #41
@Tcoat @Ultramaroon
ditto
Old 06-08-2016, 12:59 AM   #42
@Tcoat @Ultramaroon
Third recording is the best one. You have the same issue I have. One of the midshaft support bearings is toast. I have been told by an expert this is a common failure for this trans because there is no reaction to axial loading of the midshaft - no thrust bearing.
The whine does follow the engine rpm. It is present in all gears except fifth. Dead giveaway.
Anyone still have gear grinding issues? goshem Engine, Exhaust, Transmission 52 10-01-2015 06:51 PM
5th gear grinding Bernie Issues | Warranty | Recalls / TSB 1 05-15-2015 08:10 AM
6th gear grinding D-VO Issues | Warranty | Recalls / TSB 59 04-07-2015 02:26 PM
Grinding in 3rd gear...what's going on?! hozouria Engine, Exhaust, Transmission 3 08-13-2014 02:31 PM
6th Gear Grinding KpAtch3s Issues | Warranty | Recalls / TSB 0 06-18-2013 08:07 PM
