Old 04-10-2016, 04:27 AM   #1
Rifle
EX-86 Supercharged God
Rifle's Avatar
Drives: '16 Series.HyperBlue BRZ
Weird trunk question.
Have a molded trunk from an FRS. Need to swap it with my HyperBlue trunk. Issue is, the 16 BRZs come with a back up camera, as well as the proximity sensor button and such.
I'm assuming that when I swap the garnish, I'll be able to retain the proximity sensor button.. But what about the back up camera hole?? I'm guessing I'll need to make one? I have legit no idea. Lol.
For references:
FRS trunk is something like this..
And the 16 trunk is this and this
Sprintex 210 Supercharged HyperBlue BRZ "HI MOM"
295WHP/220TQ
Rifle is offline   Reply With Quote
Old 04-10-2016, 07:26 AM   #2
MasonL1997
MasonL1997's Avatar
Drives: Man
Send a message via AIM to MasonL1997 Send a message via Yahoo to MasonL1997
Youll need to drill a hole in the garnish. If you look closely on the FRS garnish you should be able to see a small area where the camera is meant to go. Get the garnish in light and youll understand what i mean. That is where you drill the hole, then install the camera ofcourse
MasonL1997 is offline   Reply With Quote
Old 04-10-2016, 07:57 AM   #3
Joyride86
Joyride86's Avatar
Drives: 15 FR-S Firestorm MT
If you swap in the brz trunk garnish, you would already have the hole. I must be missing something here. Unless you have to use the frs trunk garnish, you would have to drill a hole on the left side. There is a slight indentation that you can use as a template. I did it for my backup camera install. Super easy.
Diode Dynamics Tail as Turn, LEDs, HIDs | Yospeed Custom Plaque and Frame | Suntek Carbon Tint | Spyder Smoked Side Markers | GrimmSpeed License Plate Relocator and Hood Struts | Five:AD Spoiler | JDM Armrest | Beat-Sonic Backup Cam | Moddiction Anvil 2 | Invidia N2 |
Joyride86 is offline   Reply With Quote
The Following User Says Thank You to Joyride86 For This Useful Post:
Rifle (04-10-2016)
Old 04-11-2016, 04:37 PM   #4
yefoo
Drives: 2016 BRZ CWP
Just did the exact same thing about two months ago. Swapped my 2016 BRZ trunk with a 2013 FRS trunk. The FRS trunk had the hole for the proximity button. Just remove the plug from the FRS trunk and switch the garnishes. The backup camera hole, on the other hand, I had to dremel out. If I can figure it out I'll post pictures of my "can't even be called amateur job". Or just send me a private message for some of my lessons learned.
yefoo is offline   Reply With Quote
Old 04-11-2016, 04:43 PM   #5
hypebrz
IG: @HypeBRZ
hypebrz's Avatar
Drives: Series.Hyperblue BRZ
Stupid question, but why do you guys swap for FRS trunks?
hypebrz is offline   Reply With Quote
Old 04-11-2016, 05:05 PM   #6
Zed
Drives: 2013 Subaru BRZ Limited GBS
Usually for trunks without spoilers, or Toyota/Scion specific spoilers
Zed is offline   Reply With Quote
The Following User Says Thank You to Zed For This Useful Post:
hypebrz (04-11-2016)
Old 04-11-2016, 09:59 PM   #7
yefoo
And the stock spoiler uses a lot of holes that need to be filled/painted.
The Following User Says Thank You to yefoo For This Useful Post:
Zed (04-12-2016)
Old 04-13-2016, 05:10 AM   #8
Ehokana
Drives: 2016 FRS
Ah, my curiousity has been satisfied.
What is up with the stock spoilers using so many mounting holes? I wanted to switch the '93 spoiler on my MR2 to a '94+ but found it would require filling some ridiculous number of holes (23, if I remember correctly)- nice to know things haven't changed after all these years
Ehokana is offline   Reply With Quote
Old 04-13-2016, 01:25 PM   #9
NyC Zn6
NyC Zn6's Avatar
Drives: 10 Series #974 6m/t
wingless ftw
Old 04-13-2016, 01:49 PM   #10
RichardsFRS
RichardsFRS's Avatar
Drives: 2013 Pearl White 6MT
I love no wing but I'd love to have a camera. Its a total mess backing out in tight spots
Back from bancation in Banopolis where I laid on the beach with a beer between my legs. I at night and ate at sun rise
RichardsFRS is offline   Reply With Quote
Old 04-13-2016, 02:45 PM   #11
yefoo
There's quite a few DIYs and options to install one.
got this from a quick search http://www.ft86club.com/forums/showthread.php?t=65777
Old 04-13-2016, 05:14 PM   #12
RichardsFRS
Yea but I don't have the nice head unit. I have the old unit with no screen
Old 04-13-2016, 11:17 PM   #13
yefoo
Maybe you can save up and get a new head unit along with back up camera?
Old 04-14-2016, 04:41 AM   #14
Rifle
Rifle's Avatar
I have a '16 with a backup camera. I just wasn't sure about the mounting holes.
295WHP/220TQ
Weird Question: KW V3 Strut Body Diameter? Stang70Fastback Suspension | Chassis | Brakes -- Sponsored by 949 Racing 4 03-24-2016 03:31 PM
Weird trunk noise FabioBRZ Issues | Warranty | Recalls / TSB 8 08-31-2015 12:22 PM
Swapping a BRZ trunk for a FRS question Skegrider Cosmetic Modification (Interior/Exterior/Lighting) 0 03-09-2015 05:40 PM
Weird Question. Tree Leaves YamahaR86 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 5 02-22-2015 09:33 PM
Question about trunk swaps MooseWRX Cosmetic Modification (Interior/Exterior/Lighting) 4 12-13-2013 10:17 PM
