Old 02-19-2015, 11:29 PM   #1
YamahaR86
JDM Vaping Stance Nation
YamahaR86's Avatar
Drives: 2013 White
Weird Question. Tree Leaves
I park my car outside as the home I am currently staying in doesn't have a garage or anything to protect it from the elements. I park it in the driveway.
There are trees around every where and I try my best to get them off of the car . Noticed they started getting into the rear trunk/tail light areas. In the front windshield wipers and below.
Any tips or links that can point me to the right direction as the important parts I need to get rid of the leaves (electrical motors or filters). Or removal guides to common parts where it builds up?
YamahaR86 is offline   Reply With Quote
Old 02-19-2015, 11:40 PM   #2
MidnightRunner
MidnightRunner's Avatar
Check out this thread:
http://www.ft86club.com/forums/showthread.php?t=49856
Every couple months I would remove TONS of random crap from there. I have a makeshift filter made from pool screening in that area. Hope that helps.
There is no great genius without a mixture of madness - Aristotle
MidnightRunner is offline   Reply With Quote
Old 02-20-2015, 11:21 AM   #3
RFB
RFB's Avatar
Drives: FRS
Tree turds accumulate in the trunk channel at the bottom.
Rain run off from the back window mixes with the tree grit and assails the tail light gaskets allowing water through.
Everyone thinks the car has a taillight condensation problem.
CEREBRUS
RFB is offline   Reply With Quote
Old 02-20-2015, 11:38 AM   #4
CEREBRUS
And the ice that gathers in there during freeze thaw cycles is amazing! The water is supposed to drain off through that channel but when the sun melts the snow on the car and the water heads into the shade of the channel the, boom, you have ice.
I check it every couple of days to make sure I keep it from building up.
Any tree, leaf or dirt in there makes it happen even worse.
Old 02-21-2015, 12:21 PM   #5
YamahaR86
YamahaR86's Avatar
Drives: 2013 White
Thanks for this. Just checked and my driver said had about a handfull of leaves. the passenger side had none.
Do you have a picture of the makeshift filter you made?
Old 02-22-2015, 08:33 PM   #6
MidnightRunner
I don't have a picture, but I'll try if I get some time.
Car vs. Tree Joakim3 Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 2 11-15-2013 11:19 AM
Window Seal Leaves Marks on Windows AsianStyle Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 13 09-22-2013 03:28 PM
Camry hits my car, leaves (car cam) cgrey Scion FR-S / Toyota 86 GT86 General Forum 144 12-21-2012 05:28 PM
AAA worker backs into my car, then leaves. davidshu0327 Scion FR-S / Toyota 86 GT86 General Forum 23 12-19-2012 07:13 PM
The ride of the falling leaves trueno86power Other Vehicles & General Automotive Discussions 0 10-20-2011 06:45 PM
