Old 03-11-2013, 08:37 AM   #15
Huehuecoyotl
Drives: Perrin/VORTECH Supercharger TestBRZ
@SXE10 Great post, good cut away, and I learned something, order me a cusco filter next! thanks-GREAT stuff
gr8 post OP!
Huehuecoyotl is offline   Reply With Quote
Old 03-15-2013, 12:25 AM   #16
Draco-REX
Corner Junkie
Draco-REX's Avatar
Drives: 13 BRZ, 11 STI, 99 RS
I can't find the bypass pressure for these filters. Subaru specs a very high bypass pressure (23psi) but most aftermarket filters have bypass valves rated for about half that. I'm not confident that these filters are any different.
Old 03-20-2013, 05:19 AM   #17
SXE10
SXE10's Avatar
Drives: Altezza RS200-Z 6MT
Good luck finding any spec like that, the only company I've seen list them is WIX. Their filter for the FA20 is rated at 28psi for the by-pass valve http://www.wixfilters.com/Lookup/Par...spx?Part=57830
SXE10 is offline   Reply With Quote
Old 03-20-2013, 10:31 AM   #18
Turbowned
Turbowned's Avatar
The only way I could be persuaded into buying a filter other than OEM is if it had a permanent metal casing with replaceable filter insert. That way you could just change the filter cartridge for a few bucks and produce less waste from metal filters over the life of the vehicle.
Something that looks like this:
http://www.ft86club.com/forums/showthread.php?t=17297
But for the same $150 I'd rather just buy a few cases of OEM filters and recycle them.
Old 03-24-2013, 06:14 AM   #19
D1cker
Drives: B9 S4/ND2
Tokyo Roki Subaru OEM filter or bust.
D1cker is offline   Reply With Quote
Old 04-08-2016, 09:13 AM   #20
Jfheisenberg
Jfheisenberg's Avatar
Drives: 2015 BRZ Series Blue WRB
Does the JDM STI oil filter will be give me more power? :/
Jfheisenberg is offline   Reply With Quote
Old 04-08-2016, 11:40 AM   #21
NyC Zn6
NyC Zn6's Avatar
Drives: 10 Series #974 6m/t
yea and also jdm street cred
Old 04-08-2016, 11:45 AM   #22
Jfheisenberg
damnnn daniel ill be so jdm.
Old 04-08-2016, 12:45 PM   #23
SlammedSilly
Drives: 2015 Ultramarine FR-S
Originally Posted by AZP Installs View Post
We've done 10,000 oil changes since 2001 when we founded our business, 99% of them have been done on Subies. Of those Subies about 85% of them have been with Subaru OEM Filters. We have never seen or had issues with the OEM filters.
Now the STi Filters over the years have been hard to get but I am almost positive that putting one of those on a WRX has given us 15-25whp gain on the Dyno. It's only if you use the JDM STi filters though, any other "regular" STi filter like EDM or USDM will not yield the gains of the JDM STi Tyte Type Filter.
-Mike Paisan
11+ Years Maintaining, Modifying and Educating TriState Subaru Enthusiasts.
Call directly as We carry almost every manufacturer now, so before you buy parts call us.
Like us on Facebook! | E-mail: sales@azpinstalls.com | 725 Fairfield Ave | Kenilworth, NJ 07033 | 908.248.AZP1 (2971) | T-1 Certified Amsoil Direct Jobber |AIM: AZP Installs
"Race Tested, Enthusiast Approved!"
i know this is an old thread and all, i was just curious as to how putting a JDM STI filter on a WRX gained 15-25whp... or was it sarcasm??
SlammedSilly is offline   Reply With Quote
Old 04-08-2016, 01:07 PM   #24
driftartist
Kurenai Samurai
driftartist's Avatar
Drives: Red and manual
...................................*facepalm forever holy fuck
driftartist is offline   Reply With Quote
The Following 4 Users Say Thank You to driftartist For This Useful Post:
Cop (04-13-2016), go_a_way1 (04-08-2016), SlammedSilly (04-08-2016), tCsonfrs (04-20-2016)
Old 04-08-2016, 01:13 PM   #25
driftartist
Kurenai Samurai
its basically paper in a can, kid......it does not increase displacement nor does it increase air to fuel ratio in your intake manifold.
The Following 2 Users Say Thank You to driftartist For This Useful Post:
Old 04-08-2016, 01:25 PM   #26
SlammedSilly
NO NO, i completely know that... i was just lost haha. i was like that makes no sense whatsoever
Old 04-08-2016, 01:36 PM   #27
driftartist
Kurenai Samurai
ohh lol ok no worries then. i was about to be really sad. all good
Old 04-08-2016, 05:21 PM   #28
Norville Rogers
Drives: Subaru BRZ
Originally Posted by sid325 View Post
Tried doing a search, didn't find much info. Does anyone have any experience with this oil filter? I'm current running the stock Subaru with a Filtermag, but the Filtermag doesn't fit well, to tall for the filter. I was hoping the Cusco with the built-in magnet is at least comparable in quality/filtration to the Subaru oil filter?
Anyone?
Thanks
You can just pop a normal magnet to any spin off filter for much the same result.
Norville Rogers is offline   Reply With Quote
FT86 Suspension- D2/BC/Cusco/Megan/Tanabe/Tein/KW/Cusco/Ksport/Eibach/Perrin JM Auto Racing Brakes, Suspension, Chassis 271 03-22-2014 12:17 PM
FS: TRD Door Stabilizer Set & Sports Air Filter Psoo2010 Australia Classifieds 5 10-01-2012 09:53 AM
GTS owners... difference between 'sports' abd 'vsc sports' button? UnLeasHer AUSTRALIA 5 07-26-2012 03:22 AM
Drop In filter test! Stock, Apexi, No filter RallySport Direct Engine, Exhaust, Transmission 14 06-25-2012 02:40 PM
