Spun
Drives: 23' Supra
How much power to gain/lose?
Current exhaust setup: Tomei UEL/Overpipe, Stock Front Pipe, N1 catback
Potential exhaust additions: Nvidia catted front pipe - what will I gain? Nvidia q300 - will I lose anything? This will be run with the v3 Vortech setup, tuned with OFT. I would like my exhaust to be a little more quiet, but don't want to lose power. I am guessing the front pipe will actually make it louder, but will it add power? |
| The Following User Says Thank You to Timmy_Jones For This Useful Post: | MisterSheep (04-07-2016) |
#2 |
#FiftyShadesOfBlue
Drives: 2015 FR-S
( ͡° ͜ʖ ͡°)
Engine/Exhaust: OFT w/ E85 Tune | FT86SF Catted UEL | Invidia Q300 Catback
Wheels/Tires/Suspension: Avid.1 AV-20 18x8.5 +33 w/ 245/35/18 PSS | RCE Yellow Springs | Velox LCAs Cosmetic: Valenti FT86SF Special Edition Tails | Diode Dynamics Full HID/LEDs | BRZ Fender Garnishes ![]() |
#3 |
nothing noticeable. you already got your best gains with the header, especially if you have a tune with it.
| The Following 2 Users Say Thank You to ryoma For This Useful Post: | 15limited (04-07-2016), MisterSheep (04-07-2016) |
#4 |
Killed Scion
Drives: 2013 FR-S Whiteout
Not much gains from a catback honestly... Better to go high flow cat with q300 catback for quieter exhaust without sacrificing anything.
Miyuki みゆき "Beautiful Snow" The Whiteout FR-S Instagram: trevor.parque |
#5 |
Drives: 10 Series #974 6m/t
Probably 2hp gain with front pipe if anything lol
| The Following User Says Thank You to NyC Zn6 For This Useful Post: | MisterSheep (04-07-2016) |
#6 |
Spun
Drives: 23' Supra
#7 |
Not Bаnned Anymore
Drives: Heavily Modified FRS
Facepalm here
#8 |
#9 |
Not Bаnned Anymore
If you have to ask this please do not put a blower on your car. Only bad things will come of it when you run into issues down the road.
| The Following User Says Thank You to go_a_way1 For This Useful Post: | mixtape (04-07-2016) |
#10 | |
Spun
Drives: 23' Supra
I do appreciate your concern, since you are assimilating asking what you would consider an obvious question, with an inability to ‘fix’ what is surely going to be a kit that blows my car. I will be sure to skip over any posts by you, in the future. |
#11 | |
A Demon
Drives: Raven GT86
| The Following 3 Users Say Thank You to ZOMFGAARON For This Useful Post: |
#12 | |
Not Bаnned Anymore
To answer your question: Your catback will have the biggest impact on the sound. The front pipe going from OEM to catless hardly changed the sound (OEM headers at the time) at all with a TRD catback in my experience so if you keep a cat there I wager to say it will sound basically the same everything else equal. The midipe with a cat in it still will not net you any real gains. The good news is your catback will not gain/lose (provided its decent) any measurable HP numbers. In conclusion save you money with the midpip unless you going for 400+hp where you truly need more flow (at what point you should be catless anyways) and pick the catback you like best. |
#13 |
Not Bаnned Anymore
#14 |
Site Moderator
Drives: ichi 86 Project
Before escalade more, here's the thing. Exhaust setup isn't just simple gain or loose hp. Catted front pipe won't gain much hp to began with & Q300 catback won't loose hp anyways. Catback is mostly for driver's ear than anything else (maybe weight fact).
Tbh don't waste your money on front pipe or OFT & get EcuTek and get actual dyno tune. Current exhaust setup is good enough. |
| The Following User Says Thank You to ichitaka05 For This Useful Post: | go_a_way1 (04-07-2016) |
| The Different between "Gain Grip by Width" & "Gain Grip by Compound"? | Figo | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 16 | 05-03-2014 02:26 AM |
| what is power gain with smaller pulley (vortechsupercharger) | 86 Legend | Forced Induction | 0 | 01-10-2014 10:22 AM |
| Invidia Q300 Hp Gain | Howardwei | Engine, Exhaust, Transmission | 8 | 07-27-2013 02:11 PM |
| Best thing to do for a little hp gain | BLKFRS | Engine, Exhaust, Transmission | 22 | 05-03-2013 05:59 PM |
| Good gain + Low decibel? | frosty86 | Engine, Exhaust, Transmission | 1 | 10-09-2012 06:32 AM |
