Drives: 2016 4Runner / 2016 FR-S
Weird behaviour on cold start
I'm not really concerned, just wanted to know if anyone else experienced this:
This morning I went to start my car and right when I cranked it, the engine turned over but then it sounded like it was about to die. It didn't though, the revs went back up on its own. This all happened within the span of less than 2 seconds. I just wanted to know if anyone has an explanation for this.
I pay more per month for insurance than I pay for the FRS.
#2 | |
Drives: 2015 CWP BRZ Limited
| The Following User Says Thank You to jawn For This Useful Post: | Djratrap (04-07-2016) |
#3 |
Sometimes weird things happen. If it only happened the once and leveled out on it's own then don't sweat it. There are a thousand things that could cause a small blip like that and as long as they don't keep happening there is no problem.
#4 |
Drives: 2015 Scion FRS
Mine does that from time to time. It doesn't sound like it's about to die but trips over itself and stutters very briefly and then goes back to normal. Usually only when it's sat for a while and it's 40 degrees or less outside
Sent from my SAMSUNG-SM-G928A using Tapatalk |
#5 |
Drives: '13 Firestorm FR-S, 99 Mustang GT
I had several cold start issues with mine the first year. Running rough, taking forever to crank over, also idle surging. They flashed my ecu after I printed out the tsb so they could no longer plead ignorance and since it has been much better. I think the battery is too small though. It still cranks relatively slow below freezing compared to most other cars I've had.
#6 |
The battery size is fine and there are plenty of cranking amps to spare. It is however a much higher compression engine than most which makes the starter work way harder than other cars. This of course gets even harder when things are cold and shrunk up a hair. The thicker oil in the cold doesn't help much either but that applies to all cars.
#7 |
Drives: BRZ CSB Limited
Mine was doing that for a while also. I replaced the battery and it's fine now. 3 years and 80k on the old battery.
#8 | |
( ͡° ͜ʖ ͡°)
Drives: '13 Whiteout FR-S A/T
| The Following User Says Thank You to drewbot For This Useful Post: | Cole (04-07-2016) |
#9 |
Drives: FBRZS
why does everyone always suspect the battery? if it starts fine its not the battery. OP mentions it starts but it sounds like its going to die. I have an Optima battery just because I've been having starting issues, but i still have problems. Mine doesn't even start from time to time.
I figured the engineers really fucked up on this part. Live with it i suppose. |
#10 |
Drives: 10 Series #974 6m/t
E85 tune?
#11 | |
#12 | |
The car isn't even a month old yet, the battery is pretty much new. Besides, I doubt it's a battery issue as if it was, the car would struggle to run even after the engine turns over
E85 is out of the question, it's not available where I live. The closest E85 station near me is in a neighboring city.
#13 | |
| The Following User Says Thank You to itsAlex For This Useful Post: | Tcoat (04-07-2016) |
#14 |
Well if it puts your mind to ease at all mine is at 60K miles in a little over a year and a half of owning it (new) and never a spot of trouble with anything!
| Weird hot start issue | mike the snake | Software Tuning | 21 | 01-18-2021 07:03 PM |
| Car won't start! Making weird sounds. | B_Rad | Issues | Warranty | Recalls / TSB | 35 | 01-25-2017 05:33 PM |
| Cold Start Help | Kayysonie | Software Tuning | 39 | 03-31-2016 11:35 PM |
| Cold start | JG | Engine, Exhaust, Transmission | 8 | 08-29-2015 02:55 AM |
| White Smoke cold start up in Cold Weather (turbo cars) | whitefrs | Forced Induction | 17 | 09-25-2013 05:05 PM |
