Old 04-07-2016, 12:12 AM   #1
owenxguo
owenxguo's Avatar
Drives: MY13 BRZ
Is LSD going to help standing start wheel spin?
Having issue with very bad wheel spin during standing start, I am running stock LSD now, and would wondering if a clutch type LSD would help?
My car is running PTuning turbo and Hankook slicks, my competitors are Hyundai Genesis and 335i, we all running same tires, and race organizer doesn't allow tire warm up during out lap (which is very stupid). I thought it might be tire too cold, but other cars seems start fine. I am very confident with throttle control over other drivers, but car just doesn't feel any traction at rear while start. I was wondering if LSD would help with this and any other recommendations on driving technic?
owenxguo is offline   Reply With Quote
Old 04-07-2016, 12:24 AM   #2
ka-t_240
What is your suspension mods? Are you getting wheel hop with that spin?
Do you have Diff/Subframe bushings in yet?
ka-t_240 is offline   Reply With Quote
Old 04-07-2016, 12:27 AM   #3
CSG Mike
CSG Mike's Avatar
Depends, are you spinning one or both wheels?
Why not just have Ptuning program you a launch control? It's well within the capabilities of EcuTek.
Old 04-07-2016, 02:24 AM   #4
owenxguo
owenxguo's Avatar
Drives: MY13 BRZ
Full RacerX arms, Eibach R2 coilover and yes diff and subframe bushings.
Old 04-07-2016, 02:29 AM   #5
owenxguo
owenxguo's Avatar
Drives: MY13 BRZ
For what I can feel both wheels
I am stilling trying different RPMs to launch, so far nothing really works well. Launch control won't really help at this point, I am guessing either the LSD or tires aren't fully warmed up. I'll see if I can get a tire warmer next race to try.
Old 04-07-2016, 04:02 AM   #6
softgrip
Drives: 2017 BRZ - Dark Grey Metallic
It helped with my astral traveling.
softgrip is offline   Reply With Quote
The Following 2 Users Say Thank You to softgrip For This Useful Post:
DustinS (04-07-2016), MTpockets (04-07-2016)
Old 04-07-2016, 10:37 AM   #7
SeanRTR
C-Street AutoX
SeanRTR's Avatar
I would just work with this...how do they enforce this? When I ran into this issue in Karting, it was mainly because they didn't want Karts zigging and zagging Nascar style on cold tires to avoid an incident...we were kids, so I guess it made sense, but I always got around this by just driving like an asshole on the warm up lap. Why can't you give the car in front of you a gap, and launch the car on to the track to get heat in the rears? Give car in front of you a run on the straight during warm up and brake hard and late to warm up tires that way. Apply the gas a bit early on exit and get the tail end a bit loose. This may or may not work...but no LSD in the world is going to make up for cold R comps that just don't want to hook up. I'd start with driving 'harder' on the on-lap.
-2013 Scion FR-S C-Street
Gearhead Homes - Homes geared towards car enthusiasts: https://www.facebook.com/GearheadHomes.RealEstate
SeanRTR is offline   Reply With Quote
Old 04-07-2016, 01:30 PM   #8
CSG Mike
CSG Mike's Avatar
Why not? It would address the exact issue you have, by modulating your engine output for you, to optimize low traction acceleration.
Look at a datalog to verify that you are indeed spinning both wheels. If you are, a LSD will not help.
Old 04-07-2016, 01:43 PM   #9
wbradley
Sarcastic SOB
wbradley's Avatar
Wide rear tires, sticky compound, maybe slightly different rear suspension calibration, those seem to be the remedy. Maybe weight on the rear axle.
I think an LSD helps with traction when cornering, particularly powering in a corner.
wbradley is online now   Reply With Quote
Old 04-07-2016, 01:53 PM   #10
xwd
It's easy to spin the rear tires, even stickier street tires, at stock power levels.
Like Mike said, a fancier traction control system is probably your best solution. The system could be electronically controlled via Ecutek, Motec, etc., or be your right foot. If you start messing with suspension to launch better, your likely trading something off where it matters more like corners.
LSD isn't really going to help you launch better.
The Following User Says Thank You to xwd For This Useful Post:
strat61caster (04-07-2016)
Old 04-07-2016, 02:25 PM   #11
Sleepless
Sleepless's Avatar
Drives: 2014 BRZ
Sand bags in the trunk
Sleepless is offline   Reply With Quote
Old 04-07-2016, 06:26 PM   #12
owenxguo
owenxguo's Avatar
Drives: MY13 BRZ
I will talk to my tuner and see if they can help, I thought those launch control with stock ecu is just to limit the rpm before car moves.
Old 04-07-2016, 06:28 PM   #13
owenxguo
owenxguo's Avatar
Drives: MY13 BRZ
Good point, time to be an asshole too
Old 04-07-2016, 07:14 PM   #14
Northwest86
Drives: Velocity Orange 86 GT
Use the brakes a ton to get heat into the tyre if allowed. On our cars we use our spare boost controller maps to limit boost in some gears for different tracks. So in this case we'd just turn the first gear boost down to wastegate pressure basically and then have second be normal.
Northwest86 is offline   Reply With Quote
Help on Launch control disable speed to control wheel spin during launching j.boy Software Tuning 8 02-01-2016 04:58 AM
WTT: White delron BeatRush spin turn knob for red aluminum Cusco spin turn knob SLVRSRFR Canada Classifieds 3 11-13-2015 03:45 PM
Standing the test of time? Saab2Frs Scion FR-S / Toyota 86 GT86 General Forum 44 10-07-2015 10:05 PM
Standing Mile _hollywood Scion FR-S / Toyota 86 GT86 General Forum 5 07-16-2012 02:33 AM
Moral Standing... Zoomie Scion FR-S / Toyota 86 GT86 General Forum 28 05-28-2012 12:39 AM
