Old 04-06-2016, 01:07 PM   #43
Ashikabi
Ashikabi's Avatar
Originally Posted by Shutter View Post
I'm glad this forum has so many bench-racers
we have about 10,000 threads comparing dyno power between kits and about 3 threads with 1/4 mile times.
Welcome to car modifying and the internet? However I suspect many people here race but not drag, so they wouldn't have a 1/4 mile time
The Following 3 Users Say Thank You to Ashikabi For This Useful Post:
ajc209 (04-06-2016), continuecrushing (04-06-2016), CxG (05-08-2018)
Old 04-06-2016, 01:11 PM   #44
OkieSnuffBox
Drives: '23 BRZ Limited
Yes.
Because drag racing isn't affected by tires, launch RPM, driver skill, track prep, etc etc etc.
The Following 4 Users Say Thank You to OkieSnuffBox For This Useful Post:
AJPG (11-27-2016), continuecrushing (04-06-2016), Jaden (06-06-2016), trigger happy (06-15-2016)
Old 04-06-2016, 01:12 PM   #45
sidesleeper
Drives: BRZ series blue
I'm a way faster bench racer than anyone here! I'll take you all on!
sidesleeper is offline   Reply With Quote
The Following User Says Thank You to sidesleeper For This Useful Post:
Old 04-06-2016, 01:13 PM   #46
ZionsWrath
Thanks
ZionsWrath's Avatar
Originally Posted by OkieSnuffBox View Post
Yes.
Pretty sure that is the point.
If we just go by a spec sheet no one would own this car in the first place I think.
The Following 2 Users Say Thank You to ZionsWrath For This Useful Post:
continuecrushing (04-06-2016), CSG Mike (04-06-2016)
Old 04-06-2016, 01:15 PM   #47
Timmy_Jones
Spun
Drives: 23' Supra
I personally am going to go with the newest revision of the Vortech kit....why? Because my local and trusted speed shop, said so. Sure the Innovate sounds amazing, the JRSC makes a ton of power, Edelbrock has the big name, but end of the day, my #1 priority is a car that runs well. My local shop has recommended this kit and I will go with them. Who cares if I am giving up 13WTQ at 3200RPM and who cares if i am making 12 more WHP than the Edelbrock kit? I want my car to start in the am....run whenever I need it and put a smile on my face.
If you want that low end grunt...get the Edelbrock/Innovate kit, based puerly on principal. Want the high end, power that builds with RPMs? Get the Vortech/JRSC etc....
If you are really curious about WHP here and there and need big numbers....build the engine and turbo it/high boost SC setup which requires custom parts.
Timmy_Jones is offline   Reply With Quote
The Following User Says Thank You to Timmy_Jones For This Useful Post:
Old 04-06-2016, 01:18 PM   #48
ZionsWrath
Thanks
ZionsWrath's Avatar
Ok. Just because your local shop recommends it doesn't mean other kits don't do those things. If that kit meets your needs great. Just because 1 shop says its the end all be all doesn't make it so, and that is the purpose of this entire thread.
I hope it works for you. Post results.
Old 04-06-2016, 01:29 PM   #49
Timmy_Jones
Spun
Drives: 23' Supra
I don't think you understood what I was saying.....they are all great kits. All of the centrifugal kits, do generally the same thing. If my local shop has installed a bunch of kit X, safely....who cares if kit Y made 5WHP more or 10 WTQ less? Not anyone but a serious track junkie. I want my car to start everyday....my local shop would love to do another kind of kit and learn about it, but I want my car to be safe and reliable.
The Following 2 Users Say Thank You to Timmy_Jones For This Useful Post:
CSG Mike (04-06-2016), CxG (05-08-2018)
Old 04-06-2016, 01:36 PM   #50
continuecrushing
continuecrushing's Avatar
Drives: 2013 Firestorm FRS
there are pro's and con's of every kit.
Pick one of the "main" ones and dont look back! You'll be way faster than any n/a frs/brz lol.
The Following User Says Thank You to continuecrushing For This Useful Post:
MisterSheep (04-06-2016)
Old 04-06-2016, 01:48 PM   #51
OkieSnuffBox
Ahh, I read it as:
"Specs aren't as important as people showing performance on the track."
The Following User Says Thank You to OkieSnuffBox For This Useful Post:
Old 04-06-2016, 02:11 PM   #52
CSG Mike
CSG Mike's Avatar
Originally Posted by ajc209 View Post
We know the Edlebrock IAT sits about +30-35C above ambient from datalogs posted up, what is the JRSC like?
I would very much like to see some datalogs of IAT taken from a JRSC fitted car lapping a circuit.
I drove a car with HKS v1 and V2 SC kit before going with Cosworth. I just found the roots charger makes a lot more torque everywhere which I preferred.
JRSC IATs spike faster, but also drop much faster; that's the nature of the air-air intercooler. +10-15C is typical for the average driver, under track conditions. At street driving manners, IAT is ambient to maybe +5C over ambient.
@sw20kosh's data.
On a 70-75F day, with an experienced/fast driver, using the JRSC. High line = stock hood. Low line = with TrackSpec hood louvers (more flow = more FMIC cooling = lower IATs... and because air-air cooling results are very immediate, it's easy to see):
The Following 3 Users Say Thank You to CSG Mike For This Useful Post:
ajc209 (04-06-2016), CxG (05-08-2018), hmong337 (04-07-2016)
Old 04-06-2016, 02:12 PM   #53
CSG Mike
CSG Mike's Avatar
I cant think of one OEM car manufacturer that uses Rotrex superchargers from the factory, but I can think of tons with an Eaton Supercharger. Namely Aston Martin, Jaguar, Mercedes, Audi......
Koenigsegg.
Old 04-06-2016, 02:16 PM   #54
CSG Mike
CSG Mike's Avatar
Great charts! Guess you just pick if you want more torque at 3k or 6k
That sounds like choosing between different Ace headers
Old 04-06-2016, 02:18 PM   #55
CSG Mike
CSG Mike's Avatar
Bench racing is life.
The Following 6 Users Say Thank You to CSG Mike For This Useful Post:
Chimera (08-08-2016), continuecrushing (04-06-2016), CxG (05-08-2018), gtengr (12-04-2016), hmong337 (04-07-2016), taiguy (04-06-2016)
Old 04-06-2016, 02:20 PM   #56
Sleepless
Sleepless's Avatar
Drives: 2016 FR-S
That is an odd looking dyno run for the JRSC. Mine doesn't drop off like that at 6800 ...
Sleepless is offline   Reply With Quote
The Following User Says Thank You to Sleepless For This Useful Post:
CounterSpace Garage Forced Induction || Jackson Racing | Edelbrock (IN STOCK!!)|| CounterSpace Garage Forced Induction 66 08-09-2016 01:59 PM
jackson Racing engine oil cooler - modular to fit the Jackson Racing Supercharger! CSG Mike Forced Induction 24 04-27-2016 12:59 PM
Jackson Racing BRZ Parikh1234 Member's Car Journals 31 12-29-2015 09:26 AM
Jackson Racing Kit AT6 CladMonitor Forced Induction 26 06-27-2014 10:27 PM
Jackson Racing FR-S Unleashed FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 3 11-18-2012 02:29 PM
