Old 04-06-2016, 11:42 AM   #29
86fun
Drives: 2013 FRS
Originally Posted by The Racers Line View Post
You failed to mention the most important aspect of your situation. You had an INSTALLATION issue too causing a lot of early issues.
Of course it is absolutely possible there is some kind of Ecutek or ECU software glitch isolated to just your car, but it is more than likely still a hardware issue.
I've got 4 Edelbrock kits on the road now, all running the CARB tune, and running flawlessly. They are 4 different year cars as well a 13' two 14's and a 15', with different ECU versions and different kit production dates. To this day, all of the issues I have seen with this kit on the forum, with people running the CARB tune, are installation errors.
You are actually incorrect about my situation. Yes, there was something that looked like a problem, but fixing the gasket, which was sealing fine anyway, didn't change a single thing with how the car ran (go reread the thread). The only thing that had an effect on the majority of the issue was setting the cam timing back to stock in the CARB tune... which is now the new standard CARB tune.. or part of it. Many people are still searching for solutions to their problems with the kit, so it doesn't work for everyone. I can think of several people off hand which have issues, but I have yet to hear a 100% clean bill of health from as many others with the kit. The fact that they are still fine tuning the CARB tune and outside vendors are creating product solutions for problems with the kit backs this up. I'm not saying it's totally screwed, it does work, it just has annoying issues with it, hesitation, poor running, inconsistency, etc. I'm sitting here contemplating having to spend a couple g's just to get a full custom tune for all running conditions, that's not something I was expecting to have to do, but it is my reality with this kit.
86fun is offline   Reply With Quote
Old 04-06-2016, 12:03 PM   #30
Kodename47
Kodename47's Avatar
Drives: UK GT86
Originally Posted by ajc209 View Post
If the charge cooling is good enough I don't seen any reason why centris are superior.
I'm not entirely sure he said that anyway.....
.: Stealth 86 :.
Kodename 47 DJ:
Old 04-06-2016, 12:10 PM   #31
Timmy_Jones
Spun
Drives: 23' Supra
Timmy_Jones is offline   Reply With Quote
The Following 11 Users Say Thank You to Timmy_Jones For This Useful Post:
ajc209 (04-06-2016), BigFatFlip (04-06-2016), CxG (05-08-2018), GPhilly (12-10-2021), Hyper4mance2k (06-11-2016), Lakitu (05-14-2018), menikmati (08-31-2016), mgarcia707 (01-13-2019), shr133 (09-18-2016), stoked_on_spool (04-06-2016), toysub (12-28-2016)
Old 04-06-2016, 12:15 PM   #32
The Racers Line
The Racers Line's Avatar
Drives: FRS, Supra, Colorado D, GLC63
Sorry, so your saying your issue is 100% with the tune, and not the kit at all?
Also, a "a couple g's for a tune". A custom tune should run you around $500.
"outside vendors are creating product solutions for problems with the kit backs this up" I'm guessing you are talking about Delicious Tunings MAP sensor kit?
The Racers Line is offline   Reply With Quote
Old 04-06-2016, 12:16 PM   #33
kch
Senior Misanthrope
kch's Avatar
I cant think of one OEM car manufacturer that uses Rotrex superchargers from the factory, but I can think of tons with an Eaton Supercharger. Namely Aston Martin, Jaguar, Mercedes, Audi......
Koenigsegg. http://koenigsegg.com/ccxr-special-edition/
The Following 4 Users Say Thank You to kch For This Useful Post:
ajc209 (04-06-2016), ATL BRZ (04-06-2016), CxG (05-08-2018), menikmati (04-06-2016)
Old 04-06-2016, 12:17 PM   #34
Ashikabi
Ashikabi's Avatar
Great charts! Guess you just pick if you want more torque at 3k or 6k
Old 04-06-2016, 12:33 PM   #35
ajc209
Drives: GT86 Cosworth
One things for sure from that graph. The JRSC has more area under the curve from 5k to 7k even if it does have the same headline power figure.
ajc209 is offline   Reply With Quote
Old 04-06-2016, 12:42 PM   #36
ZionsWrath
Thanks
ZionsWrath's Avatar
Does that steep dropoff at 7k mean you should short shift it?
Old 04-06-2016, 12:43 PM   #37
Ashikabi
Ashikabi's Avatar
I'm a scrub... What does "under the curve" mean?
Old 04-06-2016, 12:49 PM   #38
ajc209
If you look at the torque curve, from 5-7k rpm the JRSC has more of it, area if you like. More area under the curve give more power overall.
In mathematical terms you would integrate torque from 5-7k and the number you get would be bigger than that of the Edlebrock.
The Following 3 Users Say Thank You to ajc209 For This Useful Post:
Ashikabi (04-06-2016), CSG Mike (04-06-2016), CxG (05-08-2018)
Old 04-06-2016, 12:51 PM   #39
ajc209
You'd have to do a spreadsheet of tractive effort at the wheels in each gear to see if it would be worth it or not. I suspect not.
The Following User Says Thank You to ajc209 For This Useful Post:
Old 04-06-2016, 01:01 PM   #40
Ashikabi
Ashikabi's Avatar
Oh so more space between the curve and the button of the chart ie: higher value. That makes sense, just didn't understand the wording. The chart makes sense to me visually just not that phrase. Thanks!
Old 04-06-2016, 01:03 PM   #41
continuecrushing
continuecrushing's Avatar
Drives: 2013 Firestorm FRS
I'm glad this forum has so many bench-racers
we have about 10,000 threads comparing dyno power between kits and about 3 threads with 1/4 mile times.
The Following 8 Users Say Thank You to continuecrushing For This Useful Post:
AJPG (11-27-2016), ATL BRZ (04-06-2016), CSG David (04-06-2016), CSG Mike (04-06-2016), CxG (05-08-2018), jkamelo (09-24-2021), Luftwaffel (04-06-2016), ZionsWrath (04-06-2016)
Old 04-06-2016, 01:07 PM   #42
ZionsWrath
Thanks
ZionsWrath's Avatar
Such is life.
We are lucky to have those 3 threads.
Most people just whip out the spec sheet in real life to compare their car to yours.
The Following 2 Users Say Thank You to ZionsWrath For This Useful Post:
continuecrushing (04-06-2016), taiguy (04-06-2016)
CounterSpace Garage Forced Induction || Jackson Racing | Edelbrock (IN STOCK!!)|| CounterSpace Garage Forced Induction 66 08-09-2016 01:59 PM
jackson Racing engine oil cooler - modular to fit the Jackson Racing Supercharger! CSG Mike Forced Induction 24 04-27-2016 12:59 PM
Jackson Racing BRZ Parikh1234 Member's Car Journals 31 12-29-2015 09:26 AM
Jackson Racing Kit AT6 CladMonitor Forced Induction 26 06-27-2014 10:27 PM
Jackson Racing FR-S Unleashed FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 3 11-18-2012 02:29 PM
