Old 06-16-2012, 03:46 AM   #1
PekoPeko
Cusco Rear Strut Bar
I recently received my package from Vivid Racing containing Cusco front and rear strut bars and oil catch can. Some awesome parts for an amazing price, I just couldn't not buy them. I'm leaving the oil catch can off for now, and the front bar is a breeze to put on, but the rear took a bit of finesse so I figured I'd do a write up with pictures. I'm not 100% sure on proper terminology, but I figured I'd give it my best shot instead of using "doo-hickey" and "thing-a-ma-bob" so I apologize in advance
After pulling out the capet cover, you'll need to also remove the styrofoam pieces that hold the basic car tools on both sides of the spare wheel. They're each held in place by a single plastic clip (circled in yellow). I removed them by pulling the entire styrofoam piece straight upwards. Might have been my luck, but nothing broke, so I continued onwards. Simply bolt in the strut bar by lifting up the flaps that cover the bolts (circled in red).
The tool holders won't fit back into place without a little cutting. You can probably get away with cutting a smaller portion out from the bottom, but I cut it so that I could take the bar off and back on without having to take the styrofoam pieces out again. Remember to pop the clips back in so they don't fly around when you're driving around.
The carpet cover also needs a trim to get it back in place. The directions given calls for cutting out pretty big chunks out, but I found you only had to cut along the yellow lines. It does require a bit of shuffling around to get it back in, but looks better than how the directions would have you cut it imo.
Hope this will help others. I'm guessing this'll be the same way to install any rear strut that comes out.
PekoPeko is offline   Reply With Quote
The Following 13 Users Say Thank You to PekoPeko For This Useful Post:
Bones36 (07-09-2014), civicdrivr (06-16-2012), Fly Guy (06-30-2012), jazztennor (12-31-2012), JEFFSTYLE (06-16-2016), JMon85 (04-30-2018), Metabrz (06-16-2012), Neilus (06-18-2012), neutron256 (03-29-2013), normancw (06-16-2012), Ornelas66 (04-04-2015), tripjammer (04-09-2013), vividracing (06-28-2012)
Old 06-16-2012, 04:45 AM   #2
Metabrz
001 of 012
Metabrz's Avatar
Drives: MY12 NZDM Subaru BRZ "BRZ001"
Thanks! I plan on getting the same parts so this is great.
BRZ001: Peace Love and Wheelies @metabrz on IG
Metabrz is offline   Reply With Quote
Old 06-17-2012, 04:06 AM   #3
DarrenDriven
NW Region Moderator
DarrenDriven's Avatar
Drives: FR-S No More
Added this to the DIY Directory:
http://www.ft86club.com/forums/showthread.php?t=7365
Old 06-17-2012, 05:37 AM   #4
spiller
Drives: JZA70 Supra, Lancer Evo 5, 86 GTS
any placebo, i mean, positive effects?
spiller is offline   Reply With Quote
Old 06-17-2012, 11:30 AM   #5
Opposed
Drives: 2013 Asphalt FR-S
Also in for this...
Opposed is offline   Reply With Quote
Old 06-17-2012, 05:40 PM   #6
PekoPeko
Ha ha ha... yes and no. I now have a place to loop my bag straps so they don't magically pull the emergency release trunk handle. Story here.
As for performance, not really. It's a double wishbone rear so any stiffening should be minimal. Plus I'm still breaking the car in so I'm not pushing it anywhere near any changes should be felt. It was payday, I had some extra money, and it was a great deal. Besides, it's not like I have anyone special to spend my money on.... *sniff* LONELY DRIVERS UNITE!!!! I'm depressed now... think I'll go for a drive...
... with my BRZ
On a serious note: I'll be running stock in autocross for a few months (hence why I want to take it off and on without fiddling with the styrofoam pieces). After that, I figure I'll be able to do a review on if they do anything, unless someone already does so by then. CHEERS! :happy0180:
The Following 3 Users Say Thank You to PekoPeko For This Useful Post:
kanundrum (06-17-2012), Ornelas66 (03-15-2015), tbwoodlee (02-03-2013)
Old 06-18-2012, 04:18 AM   #7
driftartist
Kurenai Samurai
driftartist's Avatar
Drives: Red and manual
itsuki status! lol sorry initial d fanboy here. one question though. i mean it isnt like we are going to be needing to access the toold or the spare tire every day but i was just thinking, wont it be a little harder than usual to access underneath with the bar in place? or when you cut the carpet, will it be easier with how you cut it?
driftartist is offline   Reply With Quote
Old 06-18-2012, 04:18 AM   #8
driftartist
Kurenai Samurai
and also what torque did you use for those bolts just curious??
Old 06-18-2012, 10:58 PM   #9
PekoPeko
There isn't much difference between the way I cut the cover and the way they want you to cut it. If you cut it their way, it'll be a little easier to take the carpet in and out, but you'll be able to see a bit of the spare wheel well and some of the styrofoam. Either way, once the carpet it out, you have full access to all the tools and you can take the spare out without having to touch the bar. I just ran out and tested this
30ft/lbs. Hopefully the FSM comes out soon so I can retorque if necessary.
The Following User Says Thank You to PekoPeko For This Useful Post:
driftartist (06-19-2012)
Old 06-20-2012, 05:18 AM   #10
QIK86
Drives: Brabus E-Class - FT86(ordered)
got front and rear bars about a month ago lol just waiting for car 10 more days!!. cheers for the post was looking forward to seeing who else purchased cusco parts. did you get the break cylinder stopper (BCS) with the front bar? I did.
QIK86 is offline   Reply With Quote
Old 08-13-2012, 01:49 AM   #11
Spartan65
USMC Veteran Semper Fi
Spartan65's Avatar
Drives: 2010 WR Blue STi
did you install this while the car was lifted to pre load the chassis?
Spartan65 is offline   Reply With Quote
Old 10-09-2012, 05:32 PM   #12
TheSt|G
TheSt|G's Avatar
Drives: BRZ L 6MT, 128i 6MT, E39 M5, E36 M3
Hinged aspect certainly doesn't help the placebo, I mean performance.
TheSt|G is offline   Reply With Quote
Old 10-09-2012, 05:44 PM   #13
JPxM0Dz
F Z1LLA
JPxM0Dz's Avatar
Drives: Lexus IS-F Series 2
Looks great! Unlike you, I did not have to trim the tool trays at all, just the carpet. I managed to squeeze the tool holders back into place without any issues
2URGSE
JPxM0Dz is offline   Reply With Quote
Old 12-30-2012, 11:32 PM   #14
Juanito08
Juanito08's Avatar
Drives: Scion Fr-s
I know this thread is old, but I had a quick question. Does the strut bar sit flush to the spare cover? Or is there a small "gap"? Is so about how big of a gap?
Juanito08 is offline   Reply With Quote
Tanabe Pics of front and rear strut bar! PrimeMotoring Suspension | Chassis | Brakes -- Sponsored by 949 Racing 2 06-11-2012 07:02 PM
Front Strut Tower Bar Question russv Scion FR-S / Toyota 86 GT86 General Forum 29 05-22-2012 03:00 AM
Cusco Rear Diff. Jewelry Blaaaack-BRZ Engine, Exhaust, Transmission 24 05-12-2012 04:28 PM
strut tower braces made out of bamboo?!? aspera Scion FR-S / Toyota 86 GT86 General Forum 26 04-02-2010 02:27 PM
