Old 03-09-2016, 10:42 AM   #1
Andew727
Drives: Scion FR-S
machine work for forged rods with stock pistons?
in the middle of a build and heard a rumor that you need to machine down aftermarket rods to mate with the stock pistons. can anyone confirm or deny this?
Andew727 is offline   Reply With Quote
Old 03-09-2016, 01:37 PM   #2
FRS Justin
Drives: 2013 Asphalt FRS
Call Pauter they have experience with this, I heard something about a tapered rod end but I don't know the details
Instagram FT86PROJECT9S
Facebook FT86PROJECT9S
710whp
FRS Justin is offline   Reply With Quote
Old 03-09-2016, 05:32 PM   #3
Gear_One_Performance
Gear_One_Performance's Avatar
Drives: 2014 BRZ SCCA STU endurance car
The best bet is to start by checking with the manufacture of the rods yeah.
Gear_One_Performance is offline   Reply With Quote
Old 03-09-2016, 11:31 PM   #4
Yobiwan
Yobiwan's Avatar
Drives: Toyota 86 Turbo, Lexus NX300H
yes. every rods in the aftermarket not fit to stock piston.
you should machine rod's small end or you can ask to manufacturer to make rods for stock pistons.
LT one is OE rod for zn6 , Rt one is aftermarket (skunk2)
2012 Toyota 86 6MT / 11:1 CR block by Outfront / SBD500x Turbo 17PSI@93gas /Avo 2.5 overpipe+Avo 2.5 catted frontpipe /MAP 3" CBE/ Tein Mono sport / STI brembo Front /OS技研 LSD/SSR GTX01 18x9.5
Yobiwan is offline   Reply With Quote
The Following User Says Thank You to Yobiwan For This Useful Post:
FRS Justin (03-10-2016)
Old 03-10-2016, 08:36 AM   #5
makinen
makinen's Avatar
Drives: Toyota 86
Hi,
You already read my post. Didn't you?
I've asked to Skunk and they replied do it if you want to use stock pistons.
Originally Posted by makinen View Post
One thing I have missed is thr tapered small end of stock rods and matched stock piston pin area.
Attachment 131637
Attachment 131638
But Skunk2 rods have this shape.
Attachment 131639
So I have to go to the machine shop to match the stock pistons.
Attachment 131640
makinen is offline   Reply With Quote
Old 03-10-2016, 09:59 AM   #6
Ashikabi
Ashikabi's Avatar
If you are building why don't you just get pistons too? This doesn't answer your question but it seems logical to me
Old 03-10-2016, 04:10 PM   #7
blueap2
Drives: '14 FR-S
Call Pauter or whatever manufacturer you're going with.
Gotta trust what some of us tell you sometimes..
blueap2 is offline   Reply With Quote
Old 03-10-2016, 04:15 PM   #8
Matt@Cosworth
Drives: blue - Cosworth SC stage 3.0
yes you need to machine 90% of the rods on the aftermarket to fit the stock piston
for some reason the aftermarket designs have yet to catch up with the oem trend of a thinner top strap
Matt@Cosworth is offline   Reply With Quote
Old 03-10-2016, 05:15 PM   #9
86drift
86drift's Avatar
Drives: Toyota 86 GT
Any idea who makes the 10%?
86drift is offline   Reply With Quote
Old 03-11-2016, 04:06 AM   #10
Matt@Cosworth
lets just say a certain UK company is planning to release a steel rod that will fit the stock piston very soon
and this rod has already completed a years racing in the Fensport car - winning the toyota championship
The Following 7 Users Say Thank You to Matt@Cosworth For This Useful Post:
86drift (04-04-2016), ajc209 (03-30-2016), celek (04-07-2016), JohnJuan (03-11-2016), toeout (03-12-2016), xkalelx (04-04-2016), Yobiwan (03-11-2016)
Old 03-11-2016, 09:27 AM   #11
GsxrMe
GsxrMe's Avatar
Drives: Late 2014 Subaru BRZ
If you are looking to build a high comp engine, JE does offer pistons the will support aftermarket rods. The pistons are cheap. The factory ring landings look tiny and to thin push high amounts of hp. If you going to replace things don't take corners.
They offer 9.5:1 & 10.5:1 & 13.5:1 standard bore.
https://www.jepistons.com/Catalogs/S...baru/fa20.aspx
2014 Subaru BRZ
FBM Turbokit: GTX3076R - ECUTEK HRI FlexFuel tune - FBM 3" Turboback Exhaust - 550cc Injectors - Walbro 485 Fuel Pump - 4bar Map Sensor - FBM Oil Pan - ACT SB7-XTSS - AMSOIL all fluids - Forester XT Oil Cooler - Cusco engine, trans mounts - Whiteline rear differential bushings - Perrin shifter bushing - Firehawk 235/45/17 - AEM Failsafe
GsxrMe is offline   Reply With Quote
Old 03-11-2016, 11:05 AM   #12
SmsAlSuwaidi
Boosted
SmsAlSuwaidi's Avatar
Drives: Not a supra....yet
Why keep stock Pistons though ?
Old 04-04-2016, 12:58 AM   #13
TheMedakaBox
[EUROBEAT INTENSIFIES]
TheMedakaBox's Avatar
Drives: 2015 Scion FR-S Steel
Some thread necromancy here...
I was also wondering about this. I was thinking of getting forged rods that fit stock pistons so I can keep the 12.5:1 comp ratio for some time and go FI in the future. Plus I also read that NA engines have had bending con rods since the stock rods are cheaply mass produced.
TheMedakaBox is offline   Reply With Quote
Old 04-04-2016, 09:36 PM   #14
86drift
86drift's Avatar
Would you know if said company will be making lightweight rods?
The ones on the market now are significantly heavier than stock.
Which Forged Rods and Pistons sam69 Forced Induction 19 01-13-2015 09:13 PM
Building my motor I need help on which pistons and rods and which ones to get at a Anthony7515 Engine, Exhaust, Transmission 23 09-21-2014 11:03 PM
i need forged pistons and rods any vendors have any good deals or specials Anthony7515 Want-To-Buy Requests 0 07-28-2014 11:32 PM
12.5/1 Comp Forged Rods and Pistons Darryljr11 Engine, Exhaust, Transmission 1 10-26-2013 08:11 PM
Forged pistons and billet rods paraguin Engine, Exhaust, Transmission 0 09-25-2012 10:55 PM
