Drives: Scion FR-S
machine work for forged rods with stock pistons?
in the middle of a build and heard a rumor that you need to machine down aftermarket rods to mate with the stock pistons. can anyone confirm or deny this?
#2 |
Drives: 2013 Asphalt FRS
Call Pauter they have experience with this, I heard something about a tapered rod end but I don't know the details
Instagram FT86PROJECT9S
Facebook FT86PROJECT9S 710whp |
#3 |
Drives: 2014 BRZ SCCA STU endurance car
The best bet is to start by checking with the manufacture of the rods yeah.
#4 |
Drives: Toyota 86 Turbo, Lexus NX300H
yes. every rods in the aftermarket not fit to stock piston.
you should machine rod's small end or you can ask to manufacturer to make rods for stock pistons. LT one is OE rod for zn6 , Rt one is aftermarket (skunk2)
2012 Toyota 86 6MT / 11:1 CR block by Outfront / SBD500x Turbo 17PSI@93gas /Avo 2.5 overpipe+Avo 2.5 catted frontpipe /MAP 3" CBE/ Tein Mono sport / STI brembo Front /OS技研 LSD/SSR GTX01 18x9.5
| The Following User Says Thank You to Yobiwan For This Useful Post: | FRS Justin (03-10-2016) |
#5 | |
Drives: Toyota 86
Hi,
You already read my post. Didn't you? I've asked to Skunk and they replied do it if you want to use stock pistons. Quote:
#6 |
If you are building why don't you just get pistons too? This doesn't answer your question but it seems logical to me
#7 |
Drives: '14 FR-S
Call Pauter or whatever manufacturer you're going with.
Gotta trust what some of us tell you sometimes.. |
#8 |
Drives: blue - Cosworth SC stage 3.0
yes you need to machine 90% of the rods on the aftermarket to fit the stock piston
for some reason the aftermarket designs have yet to catch up with the oem trend of a thinner top strap |
#9 |
Drives: Toyota 86 GT
#10 |
lets just say a certain UK company is planning to release a steel rod that will fit the stock piston very soon
and this rod has already completed a years racing in the Fensport car - winning the toyota championship |
#11 |
Drives: Late 2014 Subaru BRZ
If you are looking to build a high comp engine, JE does offer pistons the will support aftermarket rods. The pistons are cheap. The factory ring landings look tiny and to thin push high amounts of hp. If you going to replace things don't take corners.
They offer 9.5:1 & 10.5:1 & 13.5:1 standard bore. https://www.jepistons.com/Catalogs/S...baru/fa20.aspx
2014 Subaru BRZ
FBM Turbokit: GTX3076R - ECUTEK HRI FlexFuel tune - FBM 3" Turboback Exhaust - 550cc Injectors - Walbro 485 Fuel Pump - 4bar Map Sensor - FBM Oil Pan - ACT SB7-XTSS - AMSOIL all fluids - Forester XT Oil Cooler - Cusco engine, trans mounts - Whiteline rear differential bushings - Perrin shifter bushing - Firehawk 235/45/17 - AEM Failsafe |
#12 |
Boosted
Drives: Not a supra....yet
Why keep stock Pistons though ?
#13 |
[EUROBEAT INTENSIFIES]
Drives: 2015 Scion FR-S Steel
Some thread necromancy here...
I was also wondering about this. I was thinking of getting forged rods that fit stock pistons so I can keep the 12.5:1 comp ratio for some time and go FI in the future. Plus I also read that NA engines have had bending con rods since the stock rods are cheaply mass produced.
#14 | |
The ones on the market now are significantly heavier than stock. |
| Which Forged Rods and Pistons | sam69 | Forced Induction | 19 | 01-13-2015 09:13 PM |
| Building my motor I need help on which pistons and rods and which ones to get at a | Anthony7515 | Engine, Exhaust, Transmission | 23 | 09-21-2014 11:03 PM |
| i need forged pistons and rods any vendors have any good deals or specials | Anthony7515 | Want-To-Buy Requests | 0 | 07-28-2014 11:32 PM |
| 12.5/1 Comp Forged Rods and Pistons | Darryljr11 | Engine, Exhaust, Transmission | 1 | 10-26-2013 08:11 PM |
| Forged pistons and billet rods | paraguin | Engine, Exhaust, Transmission | 0 | 09-25-2012 10:55 PM |
