| Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) Everything related to the mechanical maintenance of the FR-S and BRZ |
#29 | |
Drives: anything you let me
#30 |
#31 |
Yep that is how it works! Confusing as hell ain't it?
#32 | |
#33 |
Drives: Toyota 86 GTS 2016
This is a common “flaw” with Subaru. It is just a rough gearbox. If you know how to rev match your gears you will find everything will be somewhat smoother. These cars really can get your anxiety going with all the loud winding and clucky noises they produce but it’s just how they are. I don’t think Subaru and Toyota aim for the comfort side of things when it comes to these cars. They are really just a toy track car and perfect to learn in. I don’t pretend to know anything about cars but I feel like this is accurate. This is not factual just my opinion just like so many of these replies are.
| The Following User Says Thank You to Danzo86 For This Useful Post: | jeepmor (04-15-2022) |
#34 |
Drives: 84 CJ7, 08 Duramax, 2014 FRS
Motul likes to be warm. Even PNW Willamette Valley rainy winters just above freezing make this transmission grumpy in the morning with it.
#35 |
Drives: car
@Danzo86 bit of a necro bump, seeing as its from 6 years ago.
Put in the whiteline "positive shift kit" and follow up with the "positive traction kit" and your shifts will be much better. The stock transmission mount is soft, easy enough that you can move it with your pinky, and causes deflection in the drivetrain, especially after being driven hard for 100,000 miles. |
| Change gear ratio? | Afdad120108 | Engine, Exhaust, Transmission | 61 | 08-17-2016 10:44 AM |
| Automatic Gear Ratio change | Toyota86.ir | Engine, Exhaust, Transmission | 31 | 05-10-2016 03:10 AM |
| Gear Ratio Change | Lunatic | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 34 | 06-26-2014 10:20 PM |
| This kind of explains how I feel in sixth gear | Yruyur | Off-Topic Lounge [WARNING: NO POLITICS] | 6 | 11-03-2013 12:52 PM |
| any way to change the gear ratios in manual? | SuperDave | Engine, Exhaust, Transmission | 17 | 10-19-2012 10:07 PM |
