Old 11-21-2015, 11:57 AM   #1
Toyota86.ir
Mike Tune HKS E85 FD 4.88
Drives: Toyota GT86 AT NA Stage 2
Automatic Gear Ratio change
Hi guys
I have AT GT86 and after FD swap 4.88 i am thinking about changing Gear ratio in my AT gearbox. maybe it seems dummy idea but i should add there is no MT GT86 for shopping in my country.
Is there any after market company for changing gear ratio of AT gearbox?
AT gear ratio is :
3.538
2.06
1.404
0.713
my idea :
3.50
2.50
1.80
1.35
1
Toyota86.ir is offline   Reply With Quote
Old 11-21-2015, 07:14 PM   #2
FirestormFRS
Changing ratios in an AT is probably not an option unless you have thousands of $'s.
FirestormFRS is offline   Reply With Quote
Old 11-21-2015, 10:09 PM   #3
KoolBRZ
KoolBRZ's Avatar
Originally Posted by Toyota86.ir View Post
Hi guys
AT gear ratio is :
3.538
2.06
1.404
0.713
my idea :
3.50
2.50
1.80
1.35
1
The Auto has the following ratios;
I=3.538, II=2.060, III=1.104, IV=1.00, V=0.713, VI=0.582
All the ratios you want to change are going to rev higher at a lower speed, If that's all you want, then why not just change your FD to 5.29, or even 5.71?
If I say yes, will that make you think I understand?
Old 11-21-2015, 10:25 PM   #4
Dustin
Twin Screw You
Dustin's Avatar
Drives: 2013 Supercharged Whiteout FR-S
Change your final drive. Much easier and will get you the same results. Maybe not down to the number, but close enough where no one would know the difference.
Dustin is offline   Reply With Quote
Old 11-21-2015, 11:07 PM   #5
PantsDants
Drives: Scion FR-S A/T, Whiteout
OP, I don't think anyone makes gear sets for the automatic. Other issue is no one (to my knowledge) is capable of tuning the transmission control unit, which could be a huge problem if the computer is expecting stock gear ratios for any of its calculations.
PantsDants is offline   Reply With Quote
Old 11-22-2015, 12:19 AM   #6
Toyota86.ir
how much ?
FD 4.88 is good , in my mind close ratio gears give better result than upgrading FD 4.88 to FD 5.71 because gear 1 is more usable and after shifting to next gear we loss less torque. shifting 7400rpm to 5500rpm is better than 7400rpm to 4800rpm.
i have no experience with close gears but in mathematics tell me close gears are better than higher FD.
MFactory and Cusco make close gear for MT but i did not find any close ratio kit for AT.
I have no idea about affecting closer gear on TCU.
Old 11-22-2015, 01:30 AM   #7
KoolBRZ
KoolBRZ's Avatar
Your shifting rpms will be the same as a close ratio, with the 5.71 FD, but without the transmission actually being a close ratio. The higher the number FD, the closer your shift points become. It also takes some of the strain off your FD, transmission, and engine, and puts it on your axles and tires.
Old 11-22-2015, 01:51 AM   #8
PantsDants
The purpose of changing the gears in the transmission is to change them relative to each other. This will change how much the RPMs drop/rise between shifts. It's easier to figure out where you're going to land in the rev range after a shift if the change in RPM is consistent between gears. Another benefit could be to make your 6th gear really tall for cruising but make your other gears shorter for better acceleration.
Old 11-22-2015, 06:22 AM   #9
Toyota86.ir
I think FD 5.71 make gear 1 so aggressive . Below are Approximate numbers :
5.71 * 3.538 = 20 vs 3.5 * 4.88 = 17
5.71 * 2.060 = 12 vs 2.5 * 4.88 = 13
5.71 * 1.404 = 8 vs 1.8 * 4.88 = 10
5.71 * 1 .000 = 6 vs 1.34*4.88 = 7
5.71 * 0.730 = 4 vs 1 * 4.88 = 5
Gear 1 20 vs 17
Gear 2 12 vs 13
Gear 3 8 vs 10
Gear 4 6 vs 7
Gear 5 4 vs 5
Then as pantsdants mentioned we could use gear 6 for economy
Old 11-22-2015, 06:10 PM   #10
FirestormFRS
AT's are not as simple to change ratios in. You have to change a lot of parts that do not exist.
Old 11-22-2015, 09:06 PM   #11
KoolBRZ
KoolBRZ's Avatar
What about installing a Gear Vendor Under/Overdrive? It installs on the tailshaft, so would require a shortened driveshaft. But it's outside the transmission. An Overdrive would give decent highway mpg, but in normal mode with a 5.71 FD it would really scream.
Old 11-22-2015, 09:20 PM   #12
SUB-FT86
86 Member
Drives: 2013 Toyota 86 2.0T (Asphalt)
I want to be the first guy that tried the 5.29 fd on the auto. A 29% increase sounds crazy!
SUB-FT86 is offline   Reply With Quote
Old 11-23-2015, 12:06 AM   #13
Toyota86.ir
Thank you guys
It seems changing AT gears is not logical and I should try to buy manual transmission GT 86 for the next year.
Old 11-23-2015, 02:39 AM   #14
KoolBRZ
KoolBRZ's Avatar
Nooooooo
Thank you guys
With an AT, and a 5.71 FD you could probably leave rubber in the first 5 gears, and get sideways in the first 4. Of course you'll still only be going about 30 mph, but those tires would be smokin'!
Change gear ratio? Afdad120108 Engine, Exhaust, Transmission 61 08-17-2016 10:44 AM
4.556 final drive with TRD gear ratio change - good or bad idea? nzer Engine, Exhaust, Transmission 51 12-26-2015 09:15 PM
Gear Ratio Change Lunatic Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 34 06-26-2014 10:20 PM
Change FD ratio to 4.56 by changing only pinion peachch Engine, Exhaust, Transmission 1 08-31-2013 01:25 PM
86,BRZ MT gear ratio Yobiwan Engine, Exhaust, Transmission 1 01-26-2012 02:40 AM
