Drives: 2014 Whiteout FRS
Strut Hitting Fender Well, Help!
So I after I installed my camber plates and got an alignment I started hearing a loud clunk when going up curbs into driveways. Sounded like something was loose and hitting. Just got the car up on jack stands and noticed the strut/coil was rubbing the inside fender well which I am assuming is causing the noise. I can feel/hear it on the driver side predominantly but it also shows wear on the passenger side.
I had them set camber to -3.3 in the front. Anyone have any idea what I did wrong or could be causing this? Here are some pics of what I saw. ![]()
#2 |
AutoX-10/10ths every run
Are you still on factory struts? It looks like there isn't enough room to get -3.3 without contact (obviously). You might try using camber bolts and backing off the camber up top some.
#3 | |
Drives: Many types of cars in R&D.
Cusco has a extended lower arm now, which can be used to gain camber by extending the bottom king-pin location rather than at the top. Which moves the assembly outward rather than inward too, if you need to keep -3.3 or more.
Moto Miwa
R&D Driving Engineer, Product Designs Consulting for Cusco, OEM+, RS-R, Toyota Japan, and Unplugged Performance. |
| The Following User Says Thank You to Moto-P For This Useful Post: | whataboutbob (04-02-2016) |
#4 |
I am still on factory struts.
I have camber bolts in the upper perch slot as well. No one else has this problem on stock struts? or am I only the only one with stock struts at that much camber? So I guess the solution is to just dial back the camber? |
#5 |
Drives: '13 SWP ZC6 R
Nope, tub the front and add more camber.
Come on, man...
#6 |
#7 |
Drives: FRS
what wheel/tire specs are you running? just curious as to why you need -3.3 while on stock struts instead of coilovers
#8 |
One & Done (AOZORA)
Drives: '15 Series.Blue BRZ (WRB)
Did you install this yourself or have a shop professionally install this? If the shop installed this without the proper alignment....horrible job.
"I have the need....the need for speed! - Maverick (Top Gun)
#9 | |
I had installed them myself but had a shop do the alignment. I will be going tomorrow to have the alignment redone, maybe they can get more camber from the bolts and reduce the amount set from the plates. Sent from my SM-G925V using Tapatalk |
| The Following User Says Thank You to Wyattkb For This Useful Post: | 8R6 (04-04-2016) |
#10 |
Update
I went to a recommended alignment shop today to get everything setup again because I installed adjustable toe arms. Ended up being the previous shop did not even use the camber bolt adjustment and just used the camber plates maxed out. Car has a great alignment now done properly. -3.2 Camber front 0 toe front, -2.2 camber rear 1/16 total toe rear 6.8 caster Last edited by Wyattkb; 04-04-2016 at 07:31 PM. |
| Hitting rev limiter with supercharger | xsnapshot | Forced Induction | 50 | 01-14-2016 11:51 PM |
| feel like hitting the cayons today | almedarj | Southern California | 0 | 01-12-2014 10:38 AM |
| Wheel hitting tie rod? | OakmanSmalls | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 6 | 07-16-2013 05:17 AM |
| BRZs hitting Tampa, FL! | FLHC | BRZ First-Gen (2012+) — General Topics | 63 | 07-24-2012 10:20 PM |
| First newspaper reviews hitting the web.... | Sport-Tech | BRZ First-Gen (2012+) — General Topics | 12 | 05-12-2012 09:32 AM |
