Drives: RAVEN FRS
Due to shitty Canadian Roads and constant year-round construction. I managed to drive through a pot hole. I jerked a wheel a little to the right to try to avoid the hole but still hit it.
Problem: When I turn the wheel to the left a little bit while driving, there is a clunking noise coming from the wheel area. This seems to be an issue after the car is warmed up and driven for a bit. The alignment doesn't seem like its off and is normal when i drive, Did anyone have a similar issue? Could it possibly be a CV joint issue or a tie rod? btw car has a rebuilt title, so no warranty / take it to the dealer. thanks Last edited by darko; 04-01-2016 at 06:57 AM. |
#2 |
Drives: runs&drives
a first step would be jack it up, remove tires and check that everything is torqued to spec
im guessing front swaybar endlink might not be snug |
#3 |
It could be a lot of things ........
![]() I'd suggest you take your car into a alignment/automotive shop and have it checked out. OR .... we can just continue guessing ...... ![]() humfrz |
#4 | ||
Grab the tie rod and try and move it in any and every direction. If you can feel any play at all, it's shot. You should be able to twist it a bit, but that's it. Zero play up and down or side to side or front to back is what you are looking for.A simple test is to try and rock the tire/wheel, first at top/bottom, then at left and right (9and 3). Play in both locations is typically the bearing. Play only side to side is usually the tie rod end. Regardless after you possibly diagnose the issue visit two or three reputable alignment/suspension/mechanic shops compare the prices and diagnoses and then go to one.
#5 |
Drives: 2013 Pearl White 6MT
Check your seats. Mine had a wheel location clunk on turning and my back seats had came loose, just shut them and clunk gone. Okay yours may not be that but worth a shot. What I thought was a wheel suspension problem was nothing
Back from bancation in Banopolis where I laid on the beach with a beer between my legs. I
at night and ate at sun rise |
#6 |
Cognite
Drives: 2013 Whiteout FRS
i have an undiagnosed clunking noise when turning my wheels as well.
ill be watching this thread :3 |
| Tags |
| clunking, noise, tire, wheel |
| Rear suspension clunking noise. Help ): | dito | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 38 | 09-15-2016 03:09 AM |
| Clunking noise coming from the back | ft_86 | Issues | Warranty | Recalls / TSB | 6 | 03-03-2016 11:30 PM |
| kw v3 rear making clunking noise | eera | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 4 | 12-17-2015 04:10 PM |
| Clunking Noise After LCA Install | Bach415 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 23 | 07-06-2015 03:24 PM |
| clunking noise after LCA install | starron | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 2 | 05-17-2015 04:02 PM |
