Old 06-30-2012, 02:22 AM   #15
Koji_Online
N7 Spectre
Koji_Online's Avatar
Drives: 2017 Toyota 86 (Ablaze - 6MT)
Did Tamar say the springs will still settle a bit? I was hoping for more of a drop;
As far as Swift, I wonder how that will be
GT 6/ Sport PSN: Koji_Online
Koji_Online is offline   Reply With Quote
Old 06-30-2012, 09:59 PM   #16
kinryu
kinryu's Avatar
Drives: 2004 tsx aspec manual /FRS WHITEOUT
well the gf210 has a higher spring rate and the lowest drop out of the products they have.
the df210 go the lowest with just a little more of a spring rate.
if you want to go for looks get the df210.
if you like to go for track with good stability get the gf210.
tanabe has great springs.
kinryu is offline   Reply With Quote
Old 07-02-2012, 03:24 PM   #17
Kami Speed
Kami Speed's Avatar
Drives: Scion FR-S
Send a message via AIM to Kami Speed
yes DF for looks and GF for perfromance
Kami Speed is offline   Reply With Quote
Old 07-04-2012, 02:11 AM   #18
kinryu
kinryu's Avatar
If you ever wondered how gf210 springs looks with 18x8 rims. :]
Tenzo 18x8 37 offset all around with 5mm spacers in the rear.
These wheels look greattt with the drop
The Following User Says Thank You to kinryu For This Useful Post:
Kami Speed (07-05-2012)
Old 07-04-2012, 02:59 AM   #19
poormans_LFA
FT86Club.com O.G.
poormans_LFA's Avatar
Drives: Gunmetal Gundam Wing Zero Custom
Sweet!!!
poormans_LFA is offline   Reply With Quote
Old 08-15-2012, 11:12 AM   #20
Esoteric
Esoteric's Avatar
Drives: FR-S|(2)AE86|TA22|E30M3|E36M3|BPLeg
I like how little of a drop these provide. If your not going to start modding the suspension geometry, and you are keeping the OE dampers these are looking like a very strong choice.
Right now almost everything else out there drops the car by more than an inch. The more you lower the car, the more the roll center geometry changes; this causes the car to have less natural roll resistance. (I suggest looking up "roll center geometry" if you want to learn why this is)
Also to give you guys some info:
Higher rates mean the dampers work harder. Rates can be looked at as a measurement of how much force it takes to compress the spring.
That means that if the swift are the same rate, and the same hight- they should put exactly the same stress on the dampers, no more or less.
Swift makes a good quality wire for their spring, but don't get too wrapped up in "they are magic".
Esoteric is offline   Reply With Quote
Old 08-15-2012, 02:04 PM   #21
poormans_LFA
FT86Club.com O.G.
so what springs do you recommend that would give the best overall combination of performance/value/longevity?
Old 09-04-2012, 06:45 PM   #22
Esoteric
Esoteric's Avatar
Thats a good question right?
Right now, these Grip Feeling look like a strong choice for exactly that. Price is very reasonable and quality is high being made in Japan.... Actually made in Japan (not all Japanese brands are).
I have a set of GF210, Eibach ProKit and Hotchkis coming in for customers so I will give feedback!
Keep in mind too, Eibach are the manufacture for a lot of the smaller tuner companies here in the USA.
Different rates, different hight... Same quality... thats a good thing! Price will vary quite a bit though.
Old 09-05-2012, 05:47 PM   #23
Toyobaru808
Can anyone else chime in who have these installed and comment on ride quality and handling compared to stock?
Sent from my SGH-T989 using Tapatalk 2
Toyobaru808 is offline   Reply With Quote
Old 10-20-2012, 03:59 PM   #24
Esoteric
Esoteric's Avatar
I have spent a few hundred miles with the hotchkis, and about 50 with the Eibach ProKit thus far.
The Hotchkis work very well for crisp and more "speed" oriented handling (meaning the car responds quicker with the higher spring rates, and corners flatter). The nose behaves more like a typical sports car (BMW, Porsche). I actualy won't say that either are better unless your concerned with all out speed. I still like the very benign handling of the OE setup and had no problem with any cars under 400HP on the track with the OE springs/shocks. I did add adjustable rear control arms and front camber tops + camber bolts the third event because the stock rates are soft and the car rolls onto the outside of the rubber quickly.
The ProKit is very comfortable, even on 18" rubber. I think that will become the private label for the TRD USA spring kit. It's a nice balance of everything.
Both sets cause the rear suspension to load more, and the rear bushing deflection more pronounced. It adds a little more road noise, but the Whiteline positive traction kit compliments both spring sets nicely.
If your not going to the track, thus far the Eibach ProKit is very very nice for looks- and ride quality was barely deminished.
Old 03-29-2016, 11:09 PM   #25
Rob427ford
Drives: 2016 Subaru BRZ HyperBlue
Did you need camber or other adjustments with the gf-210s?
Rob427ford is offline   Reply With Quote
Tanabe USA Part Review 86design BRZ Photos, Videos, Wallpapers, Gallery Forum 37 10-17-2013 03:08 PM
trd springs or no? FT86R Suspension | Chassis | Brakes -- Sponsored by 949 Racing 17 09-30-2012 03:52 PM
Tanabe USA R&D kinryu Member's Car Journals 37 06-30-2012 01:29 AM
Tanabe Pics of front and rear strut bar! PrimeMotoring Suspension | Chassis | Brakes -- Sponsored by 949 Racing 2 06-11-2012 06:02 PM
coilovers or springs? koyv90 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 45 04-01-2012 08:49 PM
