Old 03-29-2016, 09:54 PM   #1
Fred Flintstone
Drives: 2015 FR-S Asphalt, racing stripes,
Tire advice please.
Want to put a 225s on stock rim. Will this create any handling differences? Should I just put them on the rear and leave the 215s on the front. Only suspension upgrade to be strut tower brace in front. Looking for better traction. Plan to go catless header, TRD air box, ecutec tuner, and custom tune. Want to keep mostly stock.
Fred Flintstone is offline   Reply With Quote
Old 03-29-2016, 10:40 PM   #2
Mr.ac
[insert cool phrase here]
Mr.ac's Avatar
Drives: BRZ Premium
Yes it will handle better......but....... Depends which tire you get. Cheap Walmart tires will handle like crap. If you pay more then $120 for MPSS you got suckered. I know a lot of fools that love to get suckered by the dealer/tire guy because it's "brand" it came from factory and slightly better.
I would go 225 all around. Saves you the trouble down the road when you need to rotate them.
Old 03-29-2016, 11:35 PM   #3
chaoskaze
The Fail Boat
chaoskaze's Avatar
Drives: CWP S.B.
Tire advice please.
Stay 215 on stock rim if you care about feel. 225/45/17 is luxury sport feel with a good chunk of info delayed.
Go 225/40/18 if you want. Ps, if you are just putting 225 in the rear go for it. Quite a bit ppl on Asian forum run that despite what ppl will tell you here.
Old 03-30-2016, 01:30 AM   #4
Mr.ac
Mr.ac's Avatar
Drives: BRZ Premium
What are you smoking???
And what shitty tires are you running?
225/40/18? Your asking the dude to buy new wheels? Dafuck.??
What it really comes down to is tire choice. Cheap all seasons will handle like crap regardless of width. For "better" handling always go for performance summer tires. Simple as that.
The reason why everyone says to keep the same size all around is for tire rotation. This is helpful when you have directional tires. As most all performance tires are directional.
But you could have 225 in the rear. Nothing wrong with that. You'll just end up buying a new pair once one side is worn down or pay a few $$ to get your tires flipped to the other wheel at a tire shop. That's if you have directional tires.
I been down that road many times. My MR2 has staggered wheels so I speak from experience.
Old 03-30-2016, 09:32 AM   #5
Ashikabi
Ashikabi's Avatar
Ok 1 I'm guessing the 18 was a typo, 2 "most"performance tires are NOT directional, and 3 your MR2 was engineered for a staggered setup while the FRS was not. 10mm won't make much difference in performance or feel but it will when you rotate tires. Just get the same size all the way around. Look up the wheel fitment thread for more info
Old 03-30-2016, 09:39 AM   #6
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Drives: Heavily Modified FRS
I ran Nitto Invos in 225 on OEM rims they are 'ight. If you want grip get Nitto NT01's those are what I am running this summer. Also Sidewall stiffness will make the biggest difference on feel so keep that in mind after you go look at the NT01's are realise those are too much tire for you car so you go pick other ones hahahaha!
Tire size... need advice... stokeless Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 7 11-12-2015 03:57 PM
Need That Tire Advice WhiteChocolate Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 18 02-12-2015 07:39 PM
Tire advice dtrop Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 24 12-03-2014 06:36 PM
tire advice kosoku Tracking / Autocross / HPDE / Drifting 24 12-17-2013 12:51 PM
Wheel/Tire Advice mrjester Tracking / Autocross / HPDE / Drifting 1 05-19-2013 12:48 AM
