Old 03-29-2016, 03:51 PM   #15
kkman
yeah it can be a pain sometimes haha!! it took me all weekend to findout one of my swaybar links came loose once
I have checked everythere, nothing came loose. I have reinstalled this kit 5 times already, can't find where is the problem!!! God help me!!!
kkman is offline   Reply With Quote
Old 03-29-2016, 03:56 PM   #16
infinity21
infinity21's Avatar
Drives: 2014 BRZ Sport-tech
Did you test with the front sway bar and end links removed?
infinity21 is offline   Reply With Quote
The Following 2 Users Say Thank You to infinity21 For This Useful Post:
go_a_way1 (03-29-2016), kkman (03-29-2016)
Old 03-29-2016, 04:05 PM   #17
kkman
Could you please tell me the reason, I told my merchanic to try this tonight.
If the noise disappear which means?
Old 03-29-2016, 04:28 PM   #18
Bach415
Bach415's Avatar
Drives: Whiteout FRS
If you remove the sway bar and end link and drive around, it will help you determine if the noise you are hearing is from the sway bar/end link. If the noise is still there after, then it can be your coilovers + others. If it's not there, then it's your sway bars/endlinks.
Bach415 is offline   Reply With Quote
The Following 2 Users Say Thank You to Bach415 For This Useful Post:
Old 03-29-2016, 05:19 PM   #19
kkman
many thanks!!!
Forgot to mention that my sway bars is from cusco only 1 month
I have already checked sway bar endlinks, they are in perfect situation. and nothing come loose. I doubt this it the problem.
Old 03-29-2016, 05:22 PM   #20
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Drives: Heavily Modified FRS
many thanks!!!
you check them while the wheels on on the ground? If you lift one side of the car it puts tension on it and you wont hear any noises and everything seems tight although its not.
kkman (03-29-2016)
Old 03-29-2016, 05:37 PM   #21
kkman
SO I'm confused, should I check it when its on the ground or not....many thanks !!!
Old 03-29-2016, 06:30 PM   #22
mpross
mpross's Avatar
Drives: 2015 Scion FRS
You should be able to check on the ground or in the air- as long as both front wheels are on the ground or both are in the air.
If you only lift one side in the air then it will put tension on the sway bar and you probably won't hear any noise because of that. If both front wheels are in the air there's no tension on the sway bar, and if both wheels are on the ground there won't be any tension on the sway bar.
Sent from my SAMSUNG-SM-G928A using Tapatalk
mpross is offline   Reply With Quote
The Following User Says Thank You to mpross For This Useful Post:
go_a_way1 (03-30-2016)
Old 03-29-2016, 08:29 PM   #23
Bach415
Bach415's Avatar
many thanks!!!
It's worth a try to remove the sway bar and end links to isolate the problem. Just cause you have the sway bar and the end links installed recently doesn't mean that it can't be something else that's hitting it or that the sway bar itself is loose or something near it is loose.
Old 03-29-2016, 09:26 PM   #24
x1UP
One & Done (AOZORA)
x1UP's Avatar
Drives: '15 Series.Blue BRZ (WRB)
This is troubling to hear especially since I just bought some Ohlins from someone here on the forums...
"I have the need....the need for speed! - Maverick (Top Gun)
x1UP is offline   Reply With Quote
Old 03-30-2016, 09:21 AM   #25
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
I wouldn't worry about it. Likely the sway bar end links causing the noise for the OP if it wasn't the top hats.
DocWalt is online now   Reply With Quote
The Following User Says Thank You to DocWalt For This Useful Post:
Old 03-30-2016, 12:08 PM   #26
Dihudaxia
Drives: 86
OP,
I may have had a similar problem with my Ohlins. Oddly, at the same time (2 mths before warranty expires)
Not sure what is your damper setting, but try this.
Turn it all the way to full stiff (0 click), and drive around.
If the sound disappears, your dampers are dying, or in my case almost dead.
Components inside the damper worn.
Dihudaxia is offline   Reply With Quote
The Following 2 Users Say Thank You to Dihudaxia For This Useful Post:
kevaughan (07-12-2023), kkman (03-30-2016)
Old 03-30-2016, 03:04 PM   #27
kkman
Originally Posted by Dihudaxia View Post
OP,
I double checked and installed again today.
I took swaybar and endlinks off, then drove around,found the noise is still there.
Also I borrowed an abnormal sound diagnostic equipment from local mercedes benz service center. Put the headphone on while I was driving. Now we are 95% percent sure that the noise come from the damper. So, I guess my damper is almost dead. Must be Components inside the damper worn.
in your case, what happened then ? got a new one from ohlins? or just throw it away???
Old 03-30-2016, 09:36 PM   #28
zhelinm
Drives: Toyota 86
Sorry to hear your story. I am in Shanghai now as well and have the same ohlins kit. If you are pretty sure that the knocking sound comes from the shock, you should probably remove the shock from the vehicle to check. Remove the springs off the damper and compress it with different damping settings and observe the rebound damping (time it takes to return to fully extended position). Also observe if it is smooth when you compress it. A leaking damper If you have eliminated the top mount as the problem and the droplink(2 most likely issues) then you could have a leaking strut.
The thing about inverted strut is that you cannot see the leak as the piston rod is hidden in the bottom casing. You can disassemble the bottom damping adjustment knob and bottom nut and separate the damper unit itself from the bottom casing to check. But this will void the warranty as this unit comes assembled from the factory. Warranty in China is effectively a moot point unless you buy from a local shop that get their goods directly from the main distributor. If you have bought from Taobao then its effectively gone.
Just a note, did you also check to make sure the lower bracket is tightened and secure? As well as the knuckle bolts?
If you are in Shanghai, add me on wechat using my nick and we can discuss from there.
zhelinm is offline   Reply With Quote
Rear BC BR coilover making noise PB-GT86 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 35 05-14-2016 02:58 AM
kw v3 rear making clunking noise eera Suspension | Chassis | Brakes -- Sponsored by 949 Racing 4 12-17-2015 04:10 PM
making the exhaust noise tolerable at WOT and being catless. BRZPDX Engine, Exhaust, Transmission 24 01-27-2014 12:20 PM
New rims and tires making a noise Frs32907 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 12 08-21-2013 03:01 PM
Ballast Making Noise remorse87 Cosmetic Modification (Interior/Exterior/Lighting) 7 10-24-2012 10:35 PM
