Old 03-29-2016, 01:05 AM   #57
cnk
Drives: '13 DGM BRZ Limited
Originally Posted by zc06_kisstherain View Post
@cnk, when you receive yours, did you have to unload it yourself to your driveway?
It's like 200 lb on wooden pallet and they'll charge extra if i dont have my own equipment to unload? i am thinking about purchasing 5000 soon
The delivery guy had a palet jack so I asked him to put it in my garage. He did it so I tipped him a $20. He wasn't supposed to, but I've found it's usually dependent upon the delivery guy.
For example, just had a 325lb treadmill delivered the other week. It was also supposed to be lift gate only at the bottom of my driveway. I asked the guy to put it in my garage for $20 cash and he did it.
If your delivery guy won't do it. They have to at least put it on your property which is usually the end of the driveway. You can then just cut the straps and carry the pieces one at a time. Heaviest is each jack which weighs around 80lbs. But it has wheels on one end so it's really not bad.
Sent from my SAMSUNG-SM-N910A using Tapatalk
Old 03-29-2016, 10:17 AM   #58
zc06_kisstherain
zc06_kisstherain's Avatar
Drives: SWP BRZ
Good to know. i was like shit..do i need to buy pallet jack?
thanks. i probably going to order 5000SLX next week
Old 03-29-2016, 01:35 PM   #59
cnk
Yeah. . wish they had the longer one when I bought mine, but I guess that's what I get for being an early adopter. Works just fine though so I'm not worried.
You'll love it. . .I've had my BRZ, wife's Mazda3 hatch, a Mazda CX-5, and a Impreza wagon up with no issues. I'm a little safety conscious so I still put some jack stands underneath just in case.
Moving the jack piece by piece should be fine for 1 person. Moving that freaking treadmill with 2 people from my garage to my basement was a PITA though.
Old 03-29-2016, 01:42 PM   #60
zc06_kisstherain
Drives: SWP BRZ
if i only have BRZ, i would get 3500 but i have SUV and minivan as well and tired of jacking up one by one for SUV and minivan. so, better to invest one for making my life easier.
safety is first. i always put floor jack on side + one tire of vehicle even it's on jack stands
Old 04-01-2016, 03:19 PM   #61
Casey10s
Casey10s's Avatar
Drives: 2013 white limited BRZ
Has anyone used any rubber pads that have slots for the pinch weld to fit into? I will probably order the 5000 version in the next few weeks.
Casey10s is offline   Reply With Quote
Old 04-06-2016, 03:13 PM   #62
zc06_kisstherain
Drives: SWP BRZ
I just placed order 5000. I will post when i get it
Old 04-06-2016, 07:21 PM   #63
TRAKRAVN
Drives: 2015 Scion FRS - Raven
Even with a standard jack I use hockey pucks with a groove cut in them. If the pinch weld is too tall for one puck I screw the two halves to a second pick underneath. They are small and fit in the spare tire well.
TRAKRAVN is offline   Reply With Quote
Old 04-06-2016, 10:17 PM   #64
zc06_kisstherain
Drives: SWP BRZ
@cnk
I have another question.
when you need to put air in it, regular tire inflator is sufficient to fill 50psi?
since i dont have air compressor, thinking about to pick up $30-$40 tire inflator
Old 04-06-2016, 10:37 PM   #65
aegisdrgn
aegisdrgn's Avatar
Drives: Scion FR-S 10 Series #2263
@cnk
Spend a little more and get this baby:
[ame="http://www.amazon.com/Viair-00088-88P-Portable-Compressor/dp/B005ASY23I"]Amazon.com: Viair 00088 88P Portable Air Compressor: Automotive[/ame]
I have it, pumps my tires up to 40psi on stock battery easily (within 30 seconds), then it slows down, but once the engine is running, it pumps super fast again (gotta get up to 50 for dorifto, yo)
aegisdrgn is offline   Reply With Quote
Old 04-07-2016, 12:09 AM   #66
cnk
@cnk
I used a bike pump. Only took a few pumps to get it up to 50psi. Didn't even bother to start up my 27 gallon compressor.
Sent from my SM-T700 using Tapatalk
Old 04-07-2016, 10:10 AM   #67
zc06_kisstherain
Drives: SWP BRZ
thanks for the link. it's little out of my range but i will consider.
wow! didnt you know you can use muscle..haha
Old 04-13-2016, 09:16 AM   #68
zc06_kisstherain
Drives: SWP BRZ
got tracking# so i should get it in my hand very soon!! yay!
Old 04-18-2016, 10:21 PM   #69
zc06_kisstherain
Drives: SWP BRZ
got mine today and installed 5000 SLX
damm i followed 3 wraps on Teflon tape as instruction, and it leaked so bad..
i had retaped teflon tape all over again
here's some pictures and a video
mine has little inclined driveway but didnt have problem since i used all 4 jack stands before.
and here's quick video i took.
i cannot use my garage because i have so many stuffs inside.
also it's not big enough that any car would fit in. (only miata barely fits lol)
no more jack and jack stands!!!
it will be much easier to work on my car as well as my SUV & Minivan
The Following 6 Users Say Thank You to zc06_kisstherain For This Useful Post:
cnk (04-19-2016), DAEMANO (04-21-2016), DocWalt (04-20-2016), M1K3 (04-19-2016), soulreapersteve (05-20-2016), Sportsguy83 (04-18-2016)
Old 04-21-2016, 08:10 AM   #70
brzaapi
CAR-AHOLIC
brzaapi's Avatar
Drives: 2018 BRZ Ts - CWP
I am still between this and the EZ Car Lift. But one thing I really want from my portable at-home/track lift. Is the ability to place my RACE RAMP foam blocks under the wheels occasionally. Plus they would be great for extra protection incase of a lift failure.
But i need at least 12 inches of clearance beneath the tires to make this happen. It doesnt look like they would fit under your tire. Do you happen to know what the measurement is from the bottom dead center of your tires is to the ground when the car is fully lifted?
Here is a pick showing the Race Ramp foam blocks. They are 12(center) to 14(sides) inches tall.
http://www.ft86club.com/forums/attac...1&d=1461240616
Track Toy - 2018 BRZ Ts - CWP
Daily: Audi TT RS
DD/4WD - Colorado ZR2 Bison - Mallett Supercharger
brzaapi is offline   Reply With Quote
Car for $5000? dem00n Other Vehicles & General Automotive Discussions 35 01-08-2014 03:44 PM
FS: 2013 White out Manual FRS under 5000 mi Matt Andrews Cars for Sale/Trade 17 12-09-2013 01:00 AM
Clutch dump at 5000 RPM? fasteddy BRZ First-Gen (2012+) — General Topics 20 08-22-2013 12:55 PM
Anyone else above 5000 miles too? Superhatch BRZ First-Gen (2012+) — General Topics 32 06-28-2012 12:08 PM
5000 to spend on what? MtnDrvr86 Other Vehicles & General Automotive Discussions 29 03-18-2010 04:10 PM
