Old 08-12-2015, 09:10 AM   #15
philooo
Drives: 13' Scion FRS Track car
I don' have the head unit anymore
I know this is an optional connector.. must be some kind of standard. I have the wiring diagram and they name each connector very well, but they don't mention their universal shape name which makes it impossible to know where to buy these.
philooo is offline   Reply With Quote
Old 08-12-2015, 02:26 PM   #16
phobos512
phobos512's Avatar
Drives: 2014 FR-S 6MT Whiteout
I used it to power my backup camera via 96svx's harness. It was pretty convenient to just plug right into that instead of having to splice wires and find a good switched source someplace.
Matt | '14 FR-S 6MT Whiteout | '13 Sonata Hybrid | '11 CBR1000RR
phobos512 is offline   Reply With Quote
Old 08-14-2015, 11:25 PM   #17
PNW-BRZ
PNW-BRZ's Avatar
Drives: 2015 Limited
There are two of those 6 Prong plugs in my BRZ. One of them had speaker connections, the other sits by itself in the back that sits disconnected. Holding that one toward you, the upper left is a +12v, the one below that is +12v ACC, the upper right is the common (ground) and there are two others I believe that are Canbus.
PNW-BRZ is offline   Reply With Quote
Old 03-29-2016, 03:18 AM   #18
inio
Drives: 2015 BRZ Limited
Originally Posted by philooo View Post
does anybody knows where to buy a male connector for the D29 connector ?
this connector offer some great cable with constant ant switched power, plus can high and can low.
Have you had any luck tracking this down? I'd love to know the answer.
inio is offline   Reply With Quote
Old 04-01-2016, 03:28 PM   #19
philooo
I ended yo buying one from ae64.com
he buy them specially, only place I could find one
Old 04-04-2016, 04:30 AM   #20
KenTK808
Drives: White 2014 Scion FRS
If that plug has can-bus high and can-bus low as well as switched power and ground you can use it to run gauges like this http://www.speedhut.com/gauges/Freedom-CAN-BUS/36:5
If I'm not mistaken I'm pretty sure I seen a TRD gauge option that probably uses that plug.
Edit: I just thought about it but they make a DIY arduino board you can put together that turns the can signal into a USB out, im sure you could get it to connect to a carputer or something and then run a virtual gauge. idk how good the refresh rate would be though.
KenTK808 is offline   Reply With Quote
Old 04-04-2016, 04:23 PM   #21
kmbkk
First 86 Driver Baby!
kmbkk's Avatar
Drives: FR-S, Flex
This might be useful to the Brainiac design company, @Workshop12
kmbkk is offline   Reply With Quote
Old 08-04-2019, 12:48 AM   #22
Rigel
Drives: 2013 Scion FRS 10 series
I know this is very old but I found a mating connector Metra 70-1761 Radio Wiring, you can get it for $5 on Amazon. The smaller connector fits. I used these terminals https://www.hi-1000ec.com/phone/product/1332 to repin the connector if you want an oem look.
Rigel is offline   Reply With Quote
Gear Stick HELP FaNtaSy Engine, Exhaust, Transmission 12 03-17-2013 11:03 PM
NAV Install -Pulling VSS, Reverse and factory USB plug from HU 28 pin plug sikest Electronics | Audio | NAV | Infotainment 7 01-21-2013 09:38 PM
RPM stick between 3.5 - 4.5 Realm Engine, Exhaust, Transmission 6 09-18-2012 01:10 PM
Car Name; Reason why FT-86 won't stick xantonin Scion FR-S / Toyota 86 GT86 General Forum 54 07-17-2011 12:52 PM
