Old 03-27-2016, 09:50 PM   #1
tslyw
Maximum Boost?
Does anyone know what the maximum boost (approximately?) that can be run on stock internals with the FRS?
tslyw is offline   Reply With Quote
Old 03-27-2016, 10:07 PM   #2
cdq85
cdq85's Avatar
Drives: 2013 Raven FR-S
10 psi on pump gas seems to be the safe limits. E85 has seen guys pushing 400-450 with upgraded fuel systems and such. Im guessing thats around 14-16 psi? Your tranny won't last long at those numbers unless you have AT
cdq85 is offline   Reply With Quote
Old 03-28-2016, 12:06 AM   #3
Stimmed
Stimmed's Avatar
Drives: Toyota 86
Has the auto actually been proven to hold more? Interested as im looking to push a bit of power soon and was worried about the trans going and there not being any real upgrade options for it in aussie
2013 Toyota 86 (IQOf86) - Coyoda Turbo Kit, Perrin 3" Exhaust, 18" CE28SL's, Custom Oil Cooler/Transmission Cooler, Tuned by Coyote Tuning, Built FA20, E85 Fuel, Turbo Kit and Oil Coolers installed by Turbo Yoda
Stimmed is offline   Reply With Quote
Old 03-28-2016, 12:09 AM   #4
Drakiv
Project Shadow
Drakiv's Avatar
Drives: 2015 BRZ Limited 6MT
I know there is a place offering auto trans upgrades on here somewhere. If you had a manual, PAR engineering is in Australia.
FBM Stage 2 Turbo Project Shadow Build
614whp/421tq on E85
Instagram: Drakiv
Drakiv is offline   Reply With Quote
Old 03-28-2016, 12:12 AM   #5
Stimmed
Stimmed's Avatar
Drives: Toyota 86
Yeah but getting them to get me shipping quotes and no responses I haven't bothered took to long. And the other place that sells it wants about 1kUS just for shipping blows the price out a fair bit sadly.
Old 03-28-2016, 12:15 AM   #6
Drakiv
Project Shadow
Drakiv's Avatar
Sorry to hear
614whp/421tq on E85
Instagram: Drakiv
Old 03-28-2016, 01:28 AM   #7
Rifle
EX-86 Supercharged God
Rifle's Avatar
Drives: '16 Series.HyperBlue BRZ
I daily 12psi(69mm pulley) on my Sprintex 210 Twin Screw.
Sprintex 210 Supercharged HyperBlue BRZ "HI MOM"
295WHP/220TQ
Rifle is offline   Reply With Quote
Old 03-28-2016, 06:34 AM   #8
xkalelx
xkalelx's Avatar
Drives: 2013 BRZ black
I just would like to add, seeing the number of buys that blow up on stock motors; if you only have 91 available, 8psi should be your maximum safe boost level. I putz around on 8psi on e85 for daily driving and 12psi is my high boost map on e85.
xkalelx is offline   Reply With Quote
Old 03-28-2016, 06:57 AM   #9
raven1231
How much psi dependings on the turbo being used, as well as other factors.
Old 03-28-2016, 08:03 AM   #10
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Drives: Heavily Modified FRS
Boost does not kill engines, Torque is what kills engines. You should be considering how much torque you will be producing and when in the power band you are making it. Too much too soon and you will bend your rods.
Old 03-28-2016, 10:43 AM   #11
Toyota86.ir
Mike Tune HKS E85 FD 4.88
Drives: Toyota GT86 AT NA Stage 2
For low quality pump gas max is 6psi
For high quality pump gas max is 9psi
For E85 max is 12.5psi
Tune is so important and in low rpm high torque of PD superchargers ( above 10psi) make alittle stress on engine.
You need good tune plus oil cooler.
Toyota86.ir is offline   Reply With Quote
Old 03-28-2016, 10:53 AM   #12
jasonojordan
Drives: 2013 satin white brz limited
So e85 it looks like is much nicer to the motors running boost is that correct?
jasonojordan is offline   Reply With Quote
Old 03-28-2016, 11:04 AM   #13
cdq85
cdq85's Avatar
yes, I'm pretty sure the AT was proven to hold a good bit more power actually. Way too lazy to search and find the threads about it even though I could have done it by the time I finished typing this.
Old 03-28-2016, 11:14 AM   #14
Tectoniic
#FiftyShadesOfBlue
Tectoniic's Avatar
Drives: 2015 FR-S
Minus the lower MPG and shitty availability in some areas it really is a bit of a "wonder fuel" for high compression engines.
It has a much higher knock resistance so you can run more aggressive timing and make more power safer. It also burns cooler which in turn keeps everything else cooler also giving more power and further decreasing the chances of knock.
Engine/Exhaust: OFT w/ E85 Tune | FT86SF Catted UEL | Invidia Q300 Catback
Wheels/Tires/Suspension: Avid.1 AV-20 18x8.5 +33 w/ 245/35/18 PSS | RCE Yellow Springs | Velox LCAs
Cosmetic: Valenti FT86SF Special Edition Tails | Diode Dynamics Full HID/LEDs | BRZ Fender Garnishes
Tectoniic is offline   Reply With Quote
What gear+rpm to experience maximum torque? SamuelDev BRZ First-Gen (2012+) — General Topics 6 11-11-2015 11:11 AM
Maximum weight in the trunk? djmm Scion FR-S / Toyota 86 GT86 General Forum 20 08-13-2015 11:40 AM
Digital boost gauge w/ vent pod grim speed boost controller Meetjoeblack Engine, Exhaust, Bolt-Ons 0 03-09-2015 01:27 PM
“Maximum Attack” Scion FR-S stugray Scion FR-S / Toyota 86 GT86 General Forum 13 02-01-2015 08:45 PM
MAXIMUM you would pay for a TRD Supercharger installed? FRiSson Forced Induction 24 11-04-2012 01:08 AM
