Old 11-09-2015, 05:22 PM   #1
SamuelDev
Drives: 2016 Subaru BRZ Limited
What gear+rpm to experience maximum torque?
Now that I'm more comfortable with the car and with some track time under my belt, I'm curious as to where the "sweetspot" is for this car in terms of torque? In my experimentation, 2nd gear 2000-3500RPM seems pretty nice, but is there any other spot in particular where you can really feel it?
Also I now know what the torque dip is
SamuelDev is offline   Reply With Quote
Old 11-09-2015, 05:29 PM   #2
cdq85
cdq85's Avatar
Drives: 2013 Raven FR-S
I'd say you pretty much hit it with that range. after that it drops off to the dip and recovers past 4500. Without headers and a tune, you are just going to have to avoid those certain RPM's
cdq85 is offline   Reply With Quote
Old 11-09-2015, 05:32 PM   #3
BRZoomTX
BRZoomTX's Avatar
Drives: '13 BRZ
The sweet spot is keeping the car above 5k RPM. The short gearing and 7400rpm redline allow you to keep the car within 5000~7000rpm, where you will get the most power (not necessarily "feel" it).
It comes down to nailing down heel-toe shifting to keep your RPM within that range on your exit. As long as you keep the motor above as low as 4500rpm, you're getting the most power.
'13 WRB BRZ ~470whp // Instagram // YouTube
BRZoomTX is offline   Reply With Quote
Old 11-09-2015, 05:38 PM   #4
jawn
jawn's Avatar
Drives: 2015 CWP BRZ Limited
Mathematically speaking, you'll experience more torque in first gear.
jawn is offline   Reply With Quote
The Following 5 Users Say Thank You to jawn For This Useful Post:
chaoskaze (11-09-2015), Fakk (11-10-2015), go_a_way1 (11-10-2015), kch (11-10-2015), strat61caster (11-10-2015)
Old 11-09-2015, 05:48 PM   #5
chaoskaze
The Fail Boat
chaoskaze's Avatar
Drives: CWP S.B.
The Following User Says Thank You to chaoskaze For This Useful Post:
jawn (11-09-2015)
Old 11-10-2015, 05:09 PM   #6
gled21
gled21's Avatar
Drives: White brz 2015 / 93' s13
With some track experience and drift experience I recommend 5-6k. I recently bought my brz and I am beginning to be very comfortable with the cornering and it gives you alot of confidence, almost too much. A couple days I was driving on my nearest mountain downhill and I was mostly playing around 5-6k rpm and downhill it is exceptional even with the small amount of power(I was keeping pace with a 3.8L Genesis easily). However I like to avoid running the car 6-7k rpm unless its competitive.
gled21 is offline   Reply With Quote
Old 11-11-2015, 11:11 AM   #7
Scott@HKSUSA
Scott@HKSUSA's Avatar
Drives: 2013 FR-S, HKS V2 S/C
Absolutely correct. 1st gear offers the most mechanical leverage between the crank & tire so peak torque (rpm) in 1st gear is the most torque you'll experience in any car.
Since 4th gear is 1:1 and 1st gear is 3.58:1 you can take peak torque x 3.58 = peak torque in 1st gear. (~140 x 3.58 = ~501.2 ft.lb)
Scott@HKSUSA is offline   Reply With Quote
The Following User Says Thank You to Scott@HKSUSA For This Useful Post:
jawn (11-11-2015)
rpm gear torque max
Maximum weight in the trunk? djmm Scion FR-S / Toyota 86 GT86 General Forum 20 08-13-2015 11:40 AM
“Maximum Attack” Scion FR-S stugray Scion FR-S / Toyota 86 GT86 General Forum 13 02-01-2015 08:45 PM
Guesses about Gear Ratios and Wheel Torque Deslock Engine, Exhaust, Transmission 63 08-27-2013 01:42 AM
MAXIMUM you would pay for a TRD Supercharger installed? FRiSson Forced Induction 24 11-04-2012 01:08 AM
Guesses about Gear Ratios and Wheel Torque Deslock BRZ First-Gen (2012+) — General Topics 4 12-01-2011 06:15 AM
