Old 03-27-2016, 05:06 PM   #15
Mr_YUzU_FRS
Drives: 2015 Scion FRS RS 1.0
Ok, so Pep Boys does free CEL code checks.
Code p2271 and code p2271 p.
I think the second once just means its pending. Looking it up now.
Mr_YUzU_FRS is offline   Reply With Quote
Old 03-27-2016, 05:11 PM   #16
Mr_YUzU_FRS
For p2271 code, it is showing this: Oxygen (O2) Sensor Signalstuck Rich (Bank 1 - Sensor 2).
Anyone had this issue before? Maybe its the aftermarket PL high-flow cat front pipe. I didn't have any issue with the pipe before though.
Old 03-27-2016, 06:28 PM   #17
steve99
Drives: FT86
Ok you have a flex fuel kit ?,
flex kits generally re-purpose the evap input or the rear 02 sensor input, as the flex sensor input to ecu.
If your kit uses the rear 02 input for flex then the tuner may have forgot to disable all the rear 02 cel codes in ecu, as the rear 02 wires will now be connected to flex kit . If your flex kit uses evap purge as input then you have genuine problem with rear 02 sensor or some other problem.
talk to the tuner.
Old 03-27-2016, 07:09 PM   #18
Mr_YUzU_FRS
talk to the tuner.
Yes hopefully its just the sensor. No CEL when i picked up the car though. It came on after about 30 miles on the way home. Hopefully its an easy fix and nothing mechanical or any to do with the tune.
Old 03-27-2016, 08:09 PM   #19
clayrush
Drives: FRS,09 370z, 00 CelicaGT-S, 85 300Z
Way back when I got my first tune from works they forgot to disable the cell that would come on from having a catless exhaust. It took like 2 days befor it threw the code.
It's been awhile since I've been there. Does works actually tune utilizing the delicious tuning flex fuel kit these days? Or was it a delicious tune?
clayrush is offline   Reply With Quote
Old 03-27-2016, 09:47 PM   #20
Mr_YUzU_FRS
I believe it was a custom tune by works using the delicious tuning flex fuel kit. They must of forgot that I have high flow cat front pipe. We will know tomorrow.
The Following User Says Thank You to Mr_YUzU_FRS For This Useful Post:
clayrush (03-28-2016)
Old 04-20-2016, 02:50 AM   #21
Mr_YUzU_FRS
Ok, took it back to Works. Got the ecu reflashed with some minor tweaks. The problem was it was overboosting, especially in cold temps under heavy load. Its fixed now. Car is running good and strong. Thanks to the great customer support from Works.
The Following 3 Users Say Thank You to Mr_YUzU_FRS For This Useful Post:
clayrush (04-20-2016), Lonewolf (04-20-2016), zc06_kisstherain (04-26-2016)
Old 04-20-2016, 03:42 PM   #22
ATaraxias
Drives: 1994 Geo Metro Hatchback
I tried resetting ecu by removing the negative on the battery, thinking it might be a hiccup but, the CEL came back again after about 20 miles of driving. Car idles fine, no stalls, nothing unusual, blue tooth app reads 42% ethanol. Will have a nearby auto shop do a CEL read tomorrow.
Dude, 42% ethanol is no bueno. Where have you been getting your corn juice from?
ATaraxias is offline   Reply With Quote
The Following User Says Thank You to ATaraxias For This Useful Post:
Old 04-20-2016, 05:51 PM   #23
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
Originally Posted by justatroll View Post
Sorry I will rephrase:
Spends thousands on a FI upgrade, not smart enough to buy a datalogger/CEL reader in advance.
Less useless?
You DO realize that it is imperative to log data on a FI setup, ESPECIALLY right after a new tune?
It cost me a whole $18 for a OBDII reader and the torque app.
And I use the OBDII reader to read & clear codes on all of my other cars.
Originally Posted by clayrush View Post
Dude.
He is obviously made a oversight on getting a reader and is a little panicked. No need to diss.
I'm with justatroll here, OP is sort of the type of person to blow his engine then blame the tuner, or subaru/toyota for building a "bad" motor.
The Following 2 Users Say Thank You to FRSBRZGT86FAN For This Useful Post:
clayrush (04-20-2016), justatroll (04-20-2016)
Old 04-20-2016, 07:07 PM   #24
FRSBRZGT86FAN
Actually e42 would mean there's a mix of 91 50%, I'm more inclined to believe that OP or whoever filled the car up did it with a half tank of either 91 or filled up the tank halfway with e85. It's unlikely that the station is at fault otherwise there would be a major influx in people with issues flooding that station. He has flex fuel so it's not the worst situation, the tune will just adjust for it.
The Following User Says Thank You to FRSBRZGT86FAN For This Useful Post:
Sportsguy83 (04-20-2016)
Old 04-20-2016, 07:25 PM   #25
Mr_YUzU_FRS
That was with a mix. I am at 75-80% ethanol when filled with e85 at my local gas station here.
Old 04-20-2016, 07:27 PM   #26
Mr_YUzU_FRS
I am not blaming anyone... WORKS Motorsports did a great job at customer support and did not charge me anything extra for the reflash and fix. Car is running good now.
justatroll (04-20-2016), Lonewolf (04-20-2016)
Old 04-20-2016, 10:39 PM   #27
FRSBRZGT86FAN
That was said before I knew you got it taken care of and read the codes, I apologize
Old 04-26-2016, 01:25 PM   #28
WORKS
WORKS's Avatar
Drives: WORKS CARB Legal Turbo BRZ
Delicious Tuning Flex Fuel for @Mr_YUzU_FRS.
E60 tune:
WORKS is offline   Reply With Quote
The Following 2 Users Say Thank You to WORKS For This Useful Post:
clayrush (04-26-2016), zc06_kisstherain (04-26-2016)
Works Axle Back Muffler Review (Works ABM) ButeraFRS Engine, Exhaust, Transmission 16 03-15-2018 06:23 PM
TJ trip echo2lv Southern California 13 07-16-2015 04:17 AM
The weather for a trip thebus Southeast 4 01-30-2014 03:02 PM
Trip to LA! 1086 Northern California 3 11-28-2013 07:57 PM
What would you consider an adventure trip in your FRS/BRZ? Tanuki Scion FR-S / Toyota 86 GT86 General Forum 47 04-07-2013 05:54 PM
