Old 03-27-2016, 12:42 AM   #1
Mr_YUzU_FRS
Drives: 2015 Scion FRS RS 1.0
HELP! CEL after trip from WORKS.
So, if you guys already read my last post, I got my WORKS Stage 2 Turbo kit installed at WORKS about a month ago. I took my car back for the DT Flex fuel kit, dw fuel pump and injectors, WORKS oil regulator/cooler, and also had them put in a boost gauge for me, all installed at WORKS.
The car was driving fine on the way home for about 30 miles then suddenly threw a CEL. The car seems to be running with no problems but the CEL worries me. Should I worry and not drive the car until I talk to WORKS or have someone look at?
Anyways, the car made over 280 whp on the e85 flex fuel tune. Will put up the dyno chart tomorrow.
Can it be the new pump and/or injectors or oil cooler, or maybe tune? Well any tips will be useful for now, until I talk to them on Monday.
Mr_YUzU_FRS is offline   Reply With Quote
Old 03-27-2016, 12:53 AM   #2
steve99
read out cel code could be anything.
talk to your tuner
drive car as little as possible and slowly till you find out what problem is.
Sportsguy83 (04-20-2016)
Old 03-27-2016, 01:08 AM   #3
Mr_YUzU_FRS
I tried resetting ecu by removing the negative on the battery, thinking it might be a hiccup but, the CEL came back again after about 20 miles of driving. Car idles fine, no stalls, nothing unusual, blue tooth app reads 42% ethanol. Will have a nearby auto shop do a CEL read tomorrow.
Old 03-27-2016, 01:28 AM   #4
BigFatFlip
sleep, drive, eat, repeat
BigFatFlip's Avatar
Drives: '13 BRZ, '12 Outback
Since you now have a modded car, it would be a good investment to buy an obd2 reader to be able to read and clear and codes. I keep a Bluetooth obd2 reader around along with the torque app for Android on my phone for times like these.
Old 03-27-2016, 01:36 AM   #5
Mr_YUzU_FRS
Where can I buy these? I need it!
Old 03-27-2016, 01:42 AM   #6
BigFatFlip
BigFatFlip's Avatar
Any auto parts store should have an obd2 reader, maybe even the BT ones. I got mine from Amazon
Veepeak Mini Bluetooth OBD2 OBDII Scan Tool Scanner Adapter Check Engine Light Diagnostic Code Reader for Android Windows https://www.amazon.com/dp/B011NSX27A..._hj39wbSG29SEF
Old 03-27-2016, 10:09 AM   #7
TMW
Drives: 2013 Subaru BRZ
havent read any of your past posts, but do you have aftermarket headers or cats? might just be throwing codes for your catalytic converter. had that happen to me once, nothing bad.
TMW is offline   Reply With Quote
Old 03-27-2016, 11:42 AM   #8
Mr_YUzU_FRS
I do have a private label front pipe with high flow cat. Header is stock. There was no cel before when I had only fp and turbo kit with stage 2 carb tune.
Old 03-27-2016, 12:03 PM   #9
justatroll
justatroll's Avatar
Drives: Full race 4cyl boxer
Spends thousands on FI upgrade.
Cant afford $12 for a OBDII dongle.
Priceless
justatroll is offline   Reply With Quote
The Following User Says Thank You to justatroll For This Useful Post:
Wayno (03-27-2016)
Old 03-27-2016, 12:44 PM   #10
Mr_YUzU_FRS
Priceless
Who said I can't? Please don't post any more of these useless comments.
The Following 3 Users Say Thank You to Mr_YUzU_FRS For This Useful Post:
86kahl (03-27-2016), clayrush (03-27-2016), Sportsguy83 (04-20-2016)
Old 03-27-2016, 01:00 PM   #11
mrk1
Drives: Sterling BRZ Ltd
Auto Zone will read a code for free. Cheap code reader is a must.
The Build Thread
GT28RS - eBoost2 - 3.91 Final Drive - Supra LSD
mrk1 is offline   Reply With Quote
Old 03-27-2016, 01:23 PM   #12
Mr_YUzU_FRS
Autozone no longer do that service any more in CA. I went last night.
Old 03-27-2016, 02:00 PM   #13
justatroll
justatroll's Avatar
Sorry I will rephrase:
Spends thousands on a FI upgrade, not smart enough to buy a datalogger/CEL reader in advance.
Less useless?
You DO realize that it is imperative to log data on a FI setup, ESPECIALLY right after a new tune?
It cost me a whole $18 for a OBDII reader and the torque app.
And I use the OBDII reader to read & clear codes on all of my other cars.
The Following 4 Users Say Thank You to justatroll For This Useful Post:
ATL BRZ (04-20-2016), FRSBRZGT86FAN (04-20-2016), Lonewolf (04-20-2016), Wayno (03-27-2016)
Old 03-27-2016, 03:25 PM   #14
clayrush
Drives: FRS,09 370z, 00 CelicaGT-S, 85 300Z
Less useless?
Dude.
He is obviously made a oversight on getting a reader and is a little panicked. No need to diss.
clayrush is offline   Reply With Quote
The Following 2 Users Say Thank You to clayrush For This Useful Post:
Harvie1031 (03-28-2016), weederr33 (03-27-2016)
Works Axle Back Muffler Review (Works ABM) ButeraFRS Engine, Exhaust, Transmission 16 03-15-2018 06:23 PM
TJ trip echo2lv Southern California 13 07-16-2015 04:17 AM
The weather for a trip thebus Southeast 4 01-30-2014 03:02 PM
Trip to LA! 1086 Northern California 3 11-28-2013 07:57 PM
What would you consider an adventure trip in your FRS/BRZ? Tanuki Scion FR-S / Toyota 86 GT86 General Forum 47 04-07-2013 05:54 PM
