Old 03-19-2016, 09:57 PM   #3039
swarb
Originally Posted by Aire2thethrone View Post
Well I'm back on stock now but the wheels were 18x9 +45 with 245/35r18 MPSS
Without spacers the wheel didn't clear the spring perch and rubbed the spring in the front with a 5mm spacer the tire would barely clear the perch when raised but when the car was lowered to the ground the tires didn't clear and were rubbing the springs. So the tire guy recommended to drop the offset to between 30-35 on stock suspension, is he correct? Also the wheel selection is much larger at 18x8.5 so what offset would be needed there?
Are you on stock suspension?
8.5 vs 9 inch is 12.7mm difference. 6.35mm inside, 6.35mm outside.
Going from a +45 to a +35 would give you another 10mm inside clearance.
You are very very close to fitting those wheels, some people are able to fit 18x9 +38/+40(although still very close).
To save money, I would suggest stacking the spacerS you have on one corner, like 3mm+5mm or 5+5mm and bolting it down(make sure it's safe!), lowering the car, and see if it clears. But DONT drive on it(5mm is the max on stock studs). If it clears, I would suggest some 10-15mm bolt on spacers OR replace the studs with longer ones and use the slip on spacers.
The other choice is to buy another pair of wheels or get coilovers.
Old 03-19-2016, 10:22 PM   #3040
Aire2thethrone
Drives: 2016 CBS BRZ
I'm probably going to sell the wheels I have now and go down to 18x8.5 but what offset there is a garunteed fit? Coilovers aren't an option at this point, I lost money on the wheels I purchased and have to buy new ones, coilovers + alignment+ install is out of my price range atm
Aire2thethrone is offline   Reply With Quote
Old 03-20-2016, 04:13 AM   #3041
Killerbee
Killerbee's Avatar
Drives: GR86 / Supra MK5 MT / MR-S / Z4
8.5x18 +35 will fit with 245/35/18
Stock or lowered ln springs, both work without rubbing
However, be aware that this will look a bit offroadish when not lowered
For reference, http://www.ft86club.com/forums/showp...4&postcount=98
Killerbee is offline   Reply With Quote
Old 03-22-2016, 08:23 PM   #3042
Raven23
I'm looking into buying these wheels that only come in 17x9 +42. Would like to package it with springs with a mild 1' drop. Eyeing the RCE yellows. My question is will this setup work without any issues? Or will the front rub at all? Would I need anything else to make this setup work? Thanks in advance!
Raven23 is offline   Reply With Quote
Old 03-22-2016, 08:29 PM   #3043
swarb
Front will rub sway bar at full lock. 5mm spacers should help.
Every setup is slightly different as we are talking a couple mm's here.
Guy above you couldn't fit 18x9 +40 (+45 and 5mm spacer).
17x9 +35 is known to fit. Your setup with 5mm spacer is +37. 2mm from known fitment, and 3mm from someone who couldn't fit it.
YMMV
The Following User Says Thank You to swarb For This Useful Post:
Raven23 (03-22-2016)
Old 03-22-2016, 08:35 PM   #3044
Raven23
YMMV
Thanks for the help. Guess i shouldn't gamble and look for new wheels haha
Old 03-22-2016, 08:43 PM   #3045
swarb
Look up apex arc-8 and mach v awesome. They are both 17x9 +42. Search the threads and see how others fit them.
Old 03-25-2016, 02:11 PM   #3046
frs_94
Drives: scion frs
i am thinking of buying 18x9 +38 rims for the front and add a 10mm spacer would i clear the front bags?
any help is appreciated
frs_94 is offline   Reply With Quote
Old 03-25-2016, 02:20 PM   #3047
swarb
10mm spacer will not fit on stock wheel studs. 3-5mm max. You would need bolt on spacers or extended studs.
http://www.ft86club.com/forums/showthread.php?t=102750
http://www.ft86club.com/forums/showthread.php?t=77588
Old 03-25-2016, 03:24 PM   #3048
frs_94
Drives: scion frs
yes i know i have 10mm spacers with extended studs
Old 03-25-2016, 03:31 PM   #3049
swarb
Read those two threads, do some math and maybe ask on there. I don't know much about bag fitment.
frs_94 (03-25-2016)
Old 03-31-2016, 09:29 AM   #3050
xkayous
Drives: 2013 Subaru BRZ limited
Hey everyone, quick question! I purchased Konig Integram in 17x8 +45 with 235x45 continental dw. I brought it to a gmc dealership that my dad is friends with the owners, so they were putting them on for free but they are telling me the wheels won't fit? They haven't mounted any tires because they are stating the wheel is too close to the strut in the front without the tire on it. From everything I've read on here the 17x8 shouldn't be an issue right? Is a spacer needed? I feel like I'm missing something since so many others have the 17x8 without issue!
xkayous is offline   Reply With Quote
Old 03-31-2016, 05:12 PM   #3051
Cubix
Cubix's Avatar
Drives: 2015 FR-S
Just wondering if Enkei 16x8 + 25 with the stock tires would fit at all. I'm thinking it'll be too much stretch (?). Also want to drop an inch on Eibach Pro-Kit.
Cubix is offline   Reply With Quote
Old 03-31-2016, 05:48 PM   #3052
swarb
Will fit fine. 235/45 tires are a little tall though.
Fits. Too much stretch depends on you. People fit 215/225's on 9.5's. I've run 225/40-18 on 9.5's for over a year with no problems. Some people on here have 8.25 widths(xxr 527) with the stock tires.
Determining the proper width size of the tire CyberFormula Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 49 05-23-2014 09:11 AM
Correct tire width for each wheel width DarrenDriven Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 08-16-2012 02:03 PM
TIRE SIZE CALCULATOR White64Goat Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 08-15-2012 02:31 AM
Tire Width vs Wheel Width Synack Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 40 08-12-2012 11:21 PM
