Old 03-24-2016, 01:56 PM   #85
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
Originally Posted by lukey86 View Post
No need to be a "race professional", whatever that's supposed to be. Just need to be a "suspension professional", a pretty important quality to have if your job happens to involve working on suspension...
I think you miss my point.
The alignment person may just be literally saying things word for word... i.e. instead of saying "This car has no adjustment for caster correction", he said "The machine said there's no (caster correction) instructions to fix your problem"
-alex
Old 03-24-2016, 03:13 PM   #86
zussypoo
Drives:
Shouldn't "have to" but they obnoxiously don't want to try to fix it. So it looks like you're gonna have to figure out out with your own testing to prove it. How much time have you spent getting 4 alignments and going to 6 different shops?
Well my testing concludes with it being Tein's issue. I'm just documenting my entire experience here, and if someone can say with certainty it is something else I'll be happy to look into it and retract my statement of the coilovers' problems if it isn't. I've been dealing with this issue for months, and my out of pocket expenses already exceeded the value of the coilovers. As of right now the proof points towards the Teins, so I'm just waiting for fteightysix to get back to me regarding Tein's decision which they aren't doing a good job of either as I only get an update when I call in. Either way I bought a defective product, and I'll just take the proper next steps in recovering my money if they refuse to refund my money.
Originally Posted by cjd View Post
There only thing off is the caster... Are the top plates perfect mirrors? Can be checked with everything off the car easily. I suppose something could be off at the knuckle mount, but again... Compare of the car easily.
There's something being missed here.
Here are the pictures with the coilovers off. http://imgur.com/a/q2DUW When it was on the car from the earlier pictures, it seems that the top plates are identical and are both installed facing the correct direction.
zussypoo is offline   Reply With Quote
The Following User Says Thank You to zussypoo For This Useful Post:
strat61caster (03-24-2016)
Old 03-24-2016, 06:24 PM   #87
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
Originally Posted by Kaotic Lazagna View Post
Not saying it can't be the coilovers themselves, but I just can't figure out how it could be if all alignment specs are within factory allowance.
Go back and compare the alignment sheets, the alignment measurements change abnormally (notably the caster) with the Teins installed vs OE.
Factory allowance at the budget shops is basically 'tires pointed forward'
ineedyourdiddly
Old 03-24-2016, 07:41 PM   #88
Kaotic Lazagna
Drives: GR Corolla
Factory allowance has a range given on the alignment sheets. My caster didn't really change except for my passenger side.
Old 03-24-2016, 08:00 PM   #89
strat61caster
And the OP's did, indicating a problem pertaining to the Tein's.
ineedyourdiddly
Kaotic Lazagna (03-24-2016)
Old 04-03-2016, 04:57 AM   #90
shattered_memory
Drives: Satin White BRZ Limited
sorry to hear about your issues. My Tein Flex Z's do not have any issues that you are stating. I have nothing but great things to say about these coilovers. Looks like yours might be defective. Also, your caster should be identical or very close to identical.
shattered_memory is offline   Reply With Quote
Sway Bar Creaking smg1138 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 11-16-2015 01:28 PM
Creaking during turning after coilovers? Rifle Suspension | Chassis | Brakes -- Sponsored by 949 Racing 8 11-10-2015 12:51 PM
Bc racing v1 coilovers (track spec edition) knocking sounds Tsumari Brakes, Suspension, Chassis 3 08-06-2014 07:44 PM
Seats creaking Wes Issues | Warranty | Recalls / TSB 28 06-15-2014 06:19 PM
BEST of Start Up sounds!! More than 70 Exhaust Sounds! JPxM0Dz Other Vehicles & General Automotive Discussions 5 01-08-2014 02:24 PM
