Old 03-24-2016, 11:44 AM   #1
Stang70Fastback
A.K.A. Starlord
Stang70Fastback's Avatar
Drives: 2015 Series.Blue
Weird Question: KW V3 Strut Body Diameter?
Hello everyone. Simple question, but probably an odd one. Does anyone know offhand (or have easy access to a caliper to measure) the outer diameter of the lower strut housing on the KW V3. I'm looking to order some rubber end caps online that I want to slip over the base of the strut to protect the lower knob that adjusts bump, but I'm not sure what diameter to order. It's a real PITA to try to reach under the car with a tape measure to get the circumference, so I figured I'd ask if anyone else already knew, or could easily find this out for me.
Thanks in advance.
Stang70Fastback is offline   Reply With Quote
Old 03-24-2016, 11:51 AM   #2
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
Worth every penny, buy it and use it for 5+ years for random shit like this:
[ame="http://www.amazon.com/Pittsburgh-Digital-Caliper-Metric-Case/dp/B00CM8YYK0/ref=sr_1_2?s=industrial&ie=UTF8&qid=1458834657&sr= 1-2&keywords=caliper+digital"]Amazon.com - Pittsburgh 6" Digital Caliper - Metric and SAE with Case! - Jewelry Making Tools[/ame]
ineedyourdiddly
Stang70Fastback (03-24-2016)
Old 03-24-2016, 12:25 PM   #3
Stang70Fastback
A.K.A. Starlord
Used it all the time in college (aerospace engineering.) Been meaning to buy one. Don't currently have one though, so was just curious if anyone had the dimensions offhand, or knew of a schematic somewhere.
Old 03-24-2016, 12:27 PM   #4
strat61caster
What did you switch to IT?
ineedyourdiddly
Old 03-24-2016, 02:31 PM   #5
Stang70Fastback
A.K.A. Starlord
Yes, lol.
The Following User Says Thank You to Stang70Fastback For This Useful Post:
strat61caster (03-24-2016)
Weird Question. Tree Leaves YamahaR86 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 5 02-22-2015 08:33 PM
Stock Strut Brace Diameter that_guy Suspension | Chassis | Brakes -- Sponsored by 949 Racing 1 09-03-2014 11:07 AM
OEM Machperson Strut Spring Length x Inside Diameter mslerner2002 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 02-26-2014 06:29 PM
Intake Snorkel Diameter Mod Question Yruyur Engine, Exhaust, Transmission 6 07-21-2013 02:05 PM
Question about strut brace russv Suspension | Chassis | Brakes -- Sponsored by 949 Racing 10 04-04-2013 09:35 AM
