#43 | |
Drives: 2005 Toyota Camry
New Hunter Hawkeye alignment racks have a computerized program w/ instructions on how to adjust alignment on virtually every car made. In the case of my BRZ, when I used the rack there was "no instructions" on how to adjust caster. Some guys aren't good with communication. OP's alignment guy may be one of them. -alex |
| The Following User Says Thank You to mav1178 For This Useful Post: | nickmerronesucks (03-23-2016) |
#44 | |||
Drives:
![]() ![]() Quote:
| The Following User Says Thank You to zussypoo For This Useful Post: | strat61caster (03-23-2016) |
#45 |
Junior
Drives: a car
Im assuming youve already contacted Tein, have you heard any word from them?
#46 |
Try swapping the hardware left/right and also make sure the orientation is the same.
#47 |
Drives:
Wouldn't it just cause the alignment specs(at least caster) to just interchange? I really don't have the time to do these kind of testing as it seems to be Tein's job to make sure that the product isn't faulty.
#48 |
Drives: 2017 BRZ
Yes, if the Tein is faulty. This should help demonstrate it's not the frame or the fault of the accident. Or that it is not the Teins after all, or at least not the camber plates
#49 | |
Drives: '13 FRS - STX
![]() Sucks you're in this position but such is life when customizing.
#50 | |
Are you paying professionals to perform your installation or DIYing? Were all provided spacers and washers used? Are all bolts facing the same direction? Is the height and preload set the same in both corners? Is everything being tightened by hand or by impact? If the dampers were faulty, you'd have much bigger issues than "the car pulling". You'd notice it immediately in your ride height, hear squeaks, or have a damper puking oil. |
#51 | |
Drives:
#52 | |
Drives: 2017 BRZ
#53 | |
You may have some frame/chassis damage that the stock rubber mounts are absorbing, but spherical bearings will not. |
#54 |
Drives:
The bolts connecting the top plates I cannot be certain if they were replaced, because I don't have the information for that. The knuckle was found to be damaged later on after the first alignment with the Teins on, but replacing the knuckle did not affect the alignment specs nor the way the car drove with the Teins on. I did order 2 new bolts at the knuckle because I couldn't remember if the shop replaced those bolts, and that changed nothing. Everything was checked and re-tightened multiple times.
Is Buddy Club Racing Spec coilovers one of those options? I had those on prior to putting on the Teins and the vehicle was fine. |
#55 | |
Drives: 2017 BRZ
#56 | |
Drives:
It's just frustrating that Tein's immediate response was that it is not their issue, and it is because my car was involved in an accident. Although it would be comparing apples to oranges, if I got a leaky brand new tire from the local Discount Tire, I'm pretty sure that is not because my car was involved in an accident. |
| Sway Bar Creaking | smg1138 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 5 | 11-16-2015 01:28 PM |
| Creaking during turning after coilovers? | Rifle | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 8 | 11-10-2015 12:51 PM |
| Bc racing v1 coilovers (track spec edition) knocking sounds | Tsumari | Brakes, Suspension, Chassis | 3 | 08-06-2014 07:44 PM |
| Seats creaking | Wes | Issues | Warranty | Recalls / TSB | 28 | 06-15-2014 06:19 PM |
| BEST of Start Up sounds!! More than 70 Exhaust Sounds! | JPxM0Dz | Other Vehicles & General Automotive Discussions | 5 | 01-08-2014 02:24 PM |
