Old 03-20-2016, 06:17 PM   #15
Jmonty
Realtor/ Principal Broker
Drives: JRSC BRZ GBS LTD 2010 LTD Outback
Remember that the OEM header also has a cat, which retains a TON of heat.
Since there's interest, if anyone is willing to do this kind of thermal testing with the ceramic coating CSG offers, we'll be willing to offer you a rebate or store credit when your data is posted. PM me directly to purchase and claim.
what does the ceramic coating run?
Jmonty is offline   Reply With Quote
Old 03-20-2016, 07:24 PM   #16
Hawk77FT
Drives: GTS 86
I have owned few headers so far, and all of them have been ceramic coated. Recently, I have installed an un coated header and was blown away by the temperature difference between coated and un coated (same header). I cannot recommend the ceramic coating strongly enough, tbh. Whoever does it for you, make sure they do 1. true ceramic coating, 2. do the inside of it as well!
Ceramic vs wrap -
Wrap is probably a cheaper alternative and probably as effective. Things to consider: use titanium wrap, no need for a sealant. Make sure you sue proper metal straps (or alternatively steel wire).
Ceramic - this can only be done by a professional (not a DIY). Make sure you ask for the inside to be done as well.
If I was to chose between them two, I would go ceramic coating mainly because it protects the inside and the outside of the header.
Some info I found online
Ceramic Coated Exhaust Parts
This is a spray-on finish that’s infused with heat-insulating ceramics. It is not a DIY solution, these exhaust parts are coated at the factory, or sent to a facility with the proper equipment.
Pros
•Provides the biggest horsepower gains when compared to other exhaust insulation methods
•Reduces under-hood temperatures better than other types of exhaust insulation
•The ceramic coating is applied evenly on both the inside and outside of the exhaust pipes, preventing “hot spots” that can cause metal fatigue
•Improves the laminar flow of your exhaust gasses
•Prevents rust and corrosion of the ceramic coated parts
•Looks great—some coatings resemble chrome plating
Ceramic Coated Headers
Cons
•High-quality, ceramic coated exhaust parts are more expensive
•Manufacturers use a special process to apply the coating. While the coating is durable, the part will have to be sent back to them for repair if you manage to chip it
•Coatings may dull in appearance over time
Header & Exhaust Wraps
Exhaust Wrap
This is a fiberglass or composite fabric that wraps around, and insulates, exhaust system components. It is a DIY solution that can be added to nearly any exhaust part, stock or aftermarket.
Pros
•Adds a few extra horsepower when used on stock or performance pipes
•Reduces under hood temps, prolonging the life of fragile engine parts and hoses
•Easy to install and more affordable than buying ceramic coated parts
•Custom wrap anything you want
Cons
•Only insulates the outside of exhaust parts
•Exhaust wraps may absorb moisture from the road and cause rusting if your tubes aren’t made from stainless steel
Ceramic & wrap.
I have done a fair bit of research on this and it looks like this is a no no. The main purpose of ceramic coating retaining the heat within the exhaust gas instead of transferring it through the piping of the vehicle which will result in an increase in power. This occurs because the exhaust gases stay hotter longer which allows them to leave the vehicle at higher velocities. Ceramic coating will do that without a problem. The wrap to a ceramic coated header would do more damage than good, I believe. The temperatures in the actual header will be even higher and the scavenging effect slightly better however, not giving any room for heat to dissipate could reach the 304 steel temperature threshold which could cause greater expanding and potentially cracks. I am talking here about the ones that take the car to the track on regular basis.
Knowing that this header moves a fair amount of hot exhaust gases it might not be an issue and I could be wrong.
Hawk77FT is offline   Reply With Quote
The Following 3 Users Say Thank You to Hawk77FT For This Useful Post:
AceHeader-MT (03-20-2016), Hostile_Kittens (07-05-2016), Teseo (03-21-2016)
Old 03-21-2016, 03:47 AM   #17
CSG Mike
CSG Mike's Avatar
I'm not 100% sure, but I believe somewhere in the realm of 375-400 for both inside and outside of the Ace header. Both header and overpipe.
Jmonty (03-21-2016)
Old 03-21-2016, 01:40 PM   #18
Jmonty
I should be installing and re-tuning this weekend
Old 03-22-2016, 12:48 AM   #19
Hyper4mance2k
Alexandrino_Auto
Hyper4mance2k's Avatar
Drives: series.Blue
The header that is currently on my car was coated inside & out for $125.
Swaintech usually charges $250 for White Lightning on a 4 cylinder header.
If you're paying more than $200 (minus shipping and taxes) for a 4 cylinder header, I suggest you assert some more due diligence in your shopping.
performance coatings did all my rotary stuff for, depending on the header/manifold, between $80-120.
God I hope you haven't payed that much!!
PC charges $390 for a pair of SBC long tube headers.
p.s. I've never found a place that doesn't do inside and outside.
The Shadetree Project: I turn wrenches
Hyper4mance2k is offline   Reply With Quote
Old 03-22-2016, 01:02 AM   #20
tracerit
Drives: '13 SSM BRZ Limited 6MT
Should both header and overpipe be coated or just the header itself will be okay?
tracerit is offline   Reply With Quote
Old 03-22-2016, 01:04 AM   #21
Hyper4mance2k
Alexandrino_Auto
Drives: series.Blue
Both are under the hood. Both radiate heat. you decide.
Old 03-22-2016, 01:14 AM   #22
CSG Mike
CSG Mike's Avatar
I can't disclose what else and who else CSG's ceramic coater services due to NDA, but lets just leave it at MAJOR MAJOR race teams, including some series where, literally, every team in the series uses their ceramic coatings. These teams range from grassroots racers, all the way up to *cough* top series in the world.
It's not everyone's cup of tea, but generally speaking, CSG only uses the best, even when it's in diminishing returns territory. The same could be said about ceramic coating pistons, and WPC treating friction surfaces.
One that I can disclose, however, is SpaceX. ALL of the SpaceX ceramics are provided by our source.
Hyper4mance2k (03-23-2016)
Old 03-22-2016, 06:16 AM   #23
ajc209
Drives: GT86 Cosworth
Bare in mind, when you ceramic coat an exhaust part it pushes the heat backwards. So in the case of the ACE manifold if you coat both parts, you'll be putting more heat into the frontpipe.
ajc209 is offline   Reply With Quote
Old 03-22-2016, 11:10 AM   #24
churchx
churchx's Avatar
Drives: 2014 GT86
ajc209: hence 2ndary cat will be heated up sooner - good for car's green-ness in track prepped form, lol
Old 09-15-2017, 02:38 PM   #25
sickmint79
Drives: bmw
I think swain tech white lightning is the best coating. When I finally can afford an ACE header, I will coat it and wrap it. Wrap holds moisture against the raw metal leaving it exposed to risk of oxydation. If you ceramic coat and wrap a header you should be fine. Ceramic coating acts as a complete seal against the elements. If you manage to find a place that doesnt include coating the inside of the header along with the exterior, walk out and don't look back.
White lightning is a real ceramic coating, and not a blend like most powder coaters use.
I've used wrap on mild steel headers with only some BBQ high temp paint, and they've lasted 5+ years and showed no sings of wear when I sold them off.
I also have done ceramic coating from www.performancecoatings.com with wrap on high HP rotary builds that showed zero signs of wear after years of daily driving in Seattle, of all places.
fyi swaintech ceramic is only done on the outside. it's the paints that they will do both the inside and the outside. they also charge for multiple pieces ie. the JDL EL header is actually 2 pieces, so more $.
PointMeBy - auto enthusiast / 86 / car blog - https://www.pointmeby.com
IGoByPlane - travel/credit/auto experience blog - https://www.igobyplane.com
sickmint79 is offline   Reply With Quote
Old 09-24-2017, 04:07 AM   #26
Hyper4mance2k
Alexandrino_Auto
Drives: series.Blue
That's good to know, but I wasn't speaking about Swaintech's White Lighting. I was talking about other ceramic coating options that can, and should, be done inside and out. I should've made that more clear.
I've been using these guys in the late 90s. http://performancecoatings.com/exhaust-coatings/4392428
Old 09-25-2017, 01:13 PM   #27
Ernest72
Wondering if anyone has tried putting some flared vents in the metal splash shield. I am thinking it might pull some of the heat out of the engine bay. I have them on a Beatrush skid plate on my 04 WRX. Just thinking about how to cool it down now that I have a coated JDL UEL header installed.
ace, header, heat, temperature
What temperature do you put A/C on? FRiSson New England 23 06-13-2016 08:55 AM
Open Flash Header - Sound and Performance Comparison nlowell Engine, Exhaust, Transmission 41 05-19-2014 06:29 PM
Borla R&D: Comparison UEL v EL Header 2013 Scion FR-S/Subaru BRZ RiskyTrousers Engine, Exhaust, Transmission 155 08-16-2013 09:05 PM
Header comparison. NO E85 NickFRS Engine, Exhaust, Transmission 29 05-16-2013 04:01 PM
Header comparison itwillboost Engine, Exhaust, Transmission 1 03-19-2013 12:58 AM
