#15 | |
Realtor/ Principal Broker
Drives: JRSC BRZ GBS LTD 2010 LTD Outback
what does the ceramic coating run? |
#16 |
Drives: GTS 86
I have owned few headers so far, and all of them have been ceramic coated. Recently, I have installed an un coated header and was blown away by the temperature difference between coated and un coated (same header). I cannot recommend the ceramic coating strongly enough, tbh. Whoever does it for you, make sure they do 1. true ceramic coating, 2. do the inside of it as well!
Ceramic vs wrap - Wrap is probably a cheaper alternative and probably as effective. Things to consider: use titanium wrap, no need for a sealant. Make sure you sue proper metal straps (or alternatively steel wire). Ceramic - this can only be done by a professional (not a DIY). Make sure you ask for the inside to be done as well. If I was to chose between them two, I would go ceramic coating mainly because it protects the inside and the outside of the header. Some info I found online Ceramic Coated Exhaust Parts This is a spray-on finish that’s infused with heat-insulating ceramics. It is not a DIY solution, these exhaust parts are coated at the factory, or sent to a facility with the proper equipment. Pros •Provides the biggest horsepower gains when compared to other exhaust insulation methods •Reduces under-hood temperatures better than other types of exhaust insulation •The ceramic coating is applied evenly on both the inside and outside of the exhaust pipes, preventing “hot spots” that can cause metal fatigue •Improves the laminar flow of your exhaust gasses •Prevents rust and corrosion of the ceramic coated parts •Looks great—some coatings resemble chrome plating Ceramic Coated Headers Cons •High-quality, ceramic coated exhaust parts are more expensive •Manufacturers use a special process to apply the coating. While the coating is durable, the part will have to be sent back to them for repair if you manage to chip it •Coatings may dull in appearance over time Header & Exhaust Wraps Exhaust Wrap This is a fiberglass or composite fabric that wraps around, and insulates, exhaust system components. It is a DIY solution that can be added to nearly any exhaust part, stock or aftermarket. Pros •Adds a few extra horsepower when used on stock or performance pipes •Reduces under hood temps, prolonging the life of fragile engine parts and hoses •Easy to install and more affordable than buying ceramic coated parts •Custom wrap anything you want Header & Exhaust Wrap Cons •Only insulates the outside of exhaust parts •Exhaust wraps may absorb moisture from the road and cause rusting if your tubes aren’t made from stainless steel Ceramic & wrap. I have done a fair bit of research on this and it looks like this is a no no. The main purpose of ceramic coating retaining the heat within the exhaust gas instead of transferring it through the piping of the vehicle which will result in an increase in power. This occurs because the exhaust gases stay hotter longer which allows them to leave the vehicle at higher velocities. Ceramic coating will do that without a problem. The wrap to a ceramic coated header would do more damage than good, I believe. The temperatures in the actual header will be even higher and the scavenging effect slightly better however, not giving any room for heat to dissipate could reach the 304 steel temperature threshold which could cause greater expanding and potentially cracks. I am talking here about the ones that take the car to the track on regular basis. Knowing that this header moves a fair amount of hot exhaust gases it might not be an issue and I could be wrong. |
| The Following 3 Users Say Thank You to Hawk77FT For This Useful Post: |
#18 |
I should be installing and re-tuning this weekend
#19 | |
Alexandrino_Auto
Drives: series.Blue
The header that is currently on my car was coated inside & out for $125.
Swaintech usually charges $250 for White Lightning on a 4 cylinder header. If you're paying more than $200 (minus shipping and taxes) for a 4 cylinder header, I suggest you assert some more due diligence in your shopping. performance coatings did all my rotary stuff for, depending on the header/manifold, between $80-120. Quote:
PC charges $390 for a pair of SBC long tube headers. p.s. I've never found a place that doesn't do inside and outside.
The Shadetree Project: I turn wrenches
#20 |
Drives: '13 SSM BRZ Limited 6MT
Should both header and overpipe be coated or just the header itself will be okay?
#21 | |
Alexandrino_Auto
Drives: series.Blue
#22 | |
It's not everyone's cup of tea, but generally speaking, CSG only uses the best, even when it's in diminishing returns territory. The same could be said about ceramic coating pistons, and WPC treating friction surfaces. One that I can disclose, however, is SpaceX. ALL of the SpaceX ceramics are provided by our source. |
| The Following User Says Thank You to CSG Mike For This Useful Post: | Hyper4mance2k (03-23-2016) |
#23 |
Drives: GT86 Cosworth
Bare in mind, when you ceramic coat an exhaust part it pushes the heat backwards. So in the case of the ACE manifold if you coat both parts, you'll be putting more heat into the frontpipe.
#24 |
Drives: 2014 GT86
ajc209: hence 2ndary cat will be heated up sooner - good for car's green-ness in track prepped form, lol
#25 | |
Drives: bmw
PointMeBy - auto enthusiast / 86 / car blog - https://www.pointmeby.com
IGoByPlane - travel/credit/auto experience blog - https://www.igobyplane.com |
#26 | |
Alexandrino_Auto
Drives: series.Blue
I've been using these guys in the late 90s. http://performancecoatings.com/exhaust-coatings/4392428
#27 |
Wondering if anyone has tried putting some flared vents in the metal splash shield. I am thinking it might pull some of the heat out of the engine bay. I have them on a Beatrush skid plate on my 04 WRX. Just thinking about how to cool it down now that I have a coated JDL UEL header installed.
| Tags |
| ace, header, heat, temperature |
| What temperature do you put A/C on? | FRiSson | New England | 23 | 06-13-2016 08:55 AM |
| Open Flash Header - Sound and Performance Comparison | nlowell | Engine, Exhaust, Transmission | 41 | 05-19-2014 06:29 PM |
| Borla R&D: Comparison UEL v EL Header 2013 Scion FR-S/Subaru BRZ | RiskyTrousers | Engine, Exhaust, Transmission | 155 | 08-16-2013 09:05 PM |
| Header comparison. NO E85 | NickFRS | Engine, Exhaust, Transmission | 29 | 05-16-2013 04:01 PM |
| Header comparison | itwillboost | Engine, Exhaust, Transmission | 1 | 03-19-2013 12:58 AM |
