Old 03-21-2016, 05:16 PM   #1
Gbaby86
Drives: 2013 Firestorm FRS 6-MT
Rock in Motor- Portland Area - Need Advise
New to the forum. Have searched a lot but just decided to sign up because i need advice from y'all who know this motor before i spend the $$ for the fix.
Long story short went to change my oil Friday. Somehow a rock got in the funnel as i was transferring it to the oil filler and it went right in. So I had the rock sitting on top of the camshaft timing intake gear (if i would have known prior about the camshaft oil control valve i could have got it). Ended up pushing the rock down next to the timing exhaust gear below. Tried removing it through control valve with no luck. It is currently sitting right below the pulley. Between the pulley and the case i would say. Pretty tough angle to get between to scoop it out with anything.
I would say i am at the point where i gotta break that case open. Not totally sure what that entails. Going to call around later today to get some quotes. If anyone on here knows a shop in the Portland/Gresham area that is familar with FA20's so i could get an accurate quote that would be appriciated!
Weather or not its going to be spendy will be the deciding factor if i take on this project myself or not. Ive got a couple buddies that know motors pretty well but not the FA20 in particular. It would be nice to get input from someone on here that knows the motor real well.
Thanks in advance for any input!
Kody
Gbaby86 is offline   Reply With Quote
Old 03-21-2016, 05:23 PM   #2
fumanchu1
Drives: 2013 Brz C38 (bought not built :P)
This post had me like WTF several times, good luck with your very weird issue
fumanchu1 is offline   Reply With Quote
The Following 3 Users Say Thank You to fumanchu1 For This Useful Post:
86kahl (03-22-2016), go_a_way1 (03-21-2016), Scenic Driver (03-22-2016)
Old 03-21-2016, 05:42 PM   #3
steve99
Drives: FT86
Maybe a mobile mechanic may have a vacuum device to suck it out. or tape a small tube to your vacuum cleaner and suck it out
fumanchu1 (03-21-2016)
Old 03-21-2016, 05:47 PM   #4
fumanchu1
That is actually outside the box thinking and may just work, just make sure the tube is big enough to suck the rock in
Old 03-21-2016, 05:50 PM   #5
HimBRZ
HimBRZ's Avatar
Drives: 2013 BRZ Limited
I like the vacuum idea.
HimBRZ is offline   Reply With Quote
Old 03-21-2016, 05:53 PM   #6
Gbaby86
Tried the vacuum method with no luck. I think it was jammed between the timing gear and the case. Couldnt get it to budge until it fell lower
Old 03-21-2016, 06:04 PM   #7
Who8myrice
Drives: Ap2
I guess fa20 is rock solid ?
Who8myrice is offline   Reply With Quote
The Following 5 Users Say Thank You to Who8myrice For This Useful Post:
go_a_way1 (03-21-2016), MasonL1997 (04-16-2016), NissanGuy (03-26-2016), radroach (04-16-2016), SlammedSilly (03-24-2016)
Old 03-21-2016, 06:04 PM   #8
I'm a bit confused as to where the rock is at the present time.......??
Is it on the inside or outside the engine block .. ??
Can you see it ..??
Old 03-21-2016, 06:19 PM   #9
fumanchu1
Humfrz coming in hot with the 1800s method to get this fixed (I'll be taking bets)
I personally says he goes with a tree branch with a piece of gum attached to it
From what I gather humfrz it's inside the block at this time
The Following 2 Users Say Thank You to fumanchu1 For This Useful Post:
Old 03-21-2016, 06:56 PM   #10
Gbaby86
Yea it is in the timing chain/belt cover between the pulley and case.
Old 03-21-2016, 06:57 PM   #11
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Drives: Heavily Modified FRS
My money is on the ol' flip it upside down and shake it trick
The Following 3 Users Say Thank You to go_a_way1 For This Useful Post:
86kahl (03-22-2016), NissanGuy (03-26-2016), SlammedSilly (03-24-2016)
Old 03-21-2016, 07:59 PM   #12
ryoma
ryoma's Avatar
do you have a grabber tool? I have this cable grabber tool where you pull on the top cable to extend and close the claws. you can probably find one similar at a car parts store. if you can see the rock, you can probably grab it with that tool
Old 03-21-2016, 08:29 PM   #13
zc06_kisstherain
zc06_kisstherain's Avatar
Drives: SWP BRZ
dammm i cant imagine myself see rock goes into engine. hope you get that sucker out!
Old 03-21-2016, 08:56 PM   #14
Sideways
BRZZZZZ
Sideways's Avatar
Drives: 2013 BRZ Whiteout
If vacuum cleaner method doesn't work, try automotive flex tool grabber. I think you can get it from your local auto tools shop.
Sideways is offline   Reply With Quote
The Following User Says Thank You to Sideways For This Useful Post:
Tcoat (03-21-2016)
Portland Area- Rock in motor need advice! Gbaby86 Northwest 19 04-16-2016 03:34 AM
E85 in the Portland Area?? Aztec Northwest 5 03-16-2015 03:02 PM
WTB RIms Memphis, Little Rock area Xdragonxb0i Want-To-Buy Requests 1 02-25-2014 01:17 AM
Portland Area Wraps? Neziah Northwest 14 08-24-2012 02:03 PM
Anyone in Portland area have access to CNC milling? DarrenDriven Northwest 2 06-09-2012 02:36 AM
