Old 03-18-2016, 10:16 AM   #3025
unplugged
Master Member
Drives: Subaru BRZ
Originally Posted by Killerbee View Post
thats easy to tell
its all in mm, so +48 is 16mm more "inside the fender" than an +32
A little inside is no big deal. If I go with a 17x8 with a 48mm I just want to make sure i'm not going to hit my suspension with a ~1" drop and some negative camber. I see 48mm on the chart is no where near ideal, so it has me a bit concerned. Then again 8.0 wide rim is not that much wider to begin with compared to a 9 or 10" wide.
unplugged is offline   Reply With Quote
Old 03-18-2016, 10:36 AM   #3026
Killerbee
Killerbee's Avatar
Drives: GR86 / Supra MK5 MT / MR-S / Z4
actually, its a pretty big difference if you go for 8, 9, or 10" rim wide.
a 9" wide rim with +35 is very close to the inner struits, so math tells us that an 8" with +48 will be about as close as the 9" With +35
if you can, rather take an 8" +32, this will fit way better on our cars
Killerbee is offline   Reply With Quote
Old 03-18-2016, 11:01 AM   #3027
unplugged
Master Member
Drives: Subaru BRZ
The problem is finding rims I like that are offered in a ~30 offset. It seems everything is 45 or higher.
Old 03-18-2016, 11:06 AM   #3028
Killerbee
Killerbee's Avatar
worst case, if you buy an 8" wheel, you can always run spacers. a 10mm spacer makes an +45 to an + 35. its not ideal, but you can get it workimg
The Following User Says Thank You to Killerbee For This Useful Post:
unplugged (03-18-2016)
Old 03-18-2016, 11:43 AM   #3029
unplugged
Master Member
Drives: Subaru BRZ
I was thinking about the spacer and 10mm isn't that big of a change to be concerned about. Personally I rather just find another wheel that offers the better fitment.
Old 03-18-2016, 02:22 PM   #3030
EliteRB
EliteRB's Avatar
Drives: 2013 FRS V1
ok with a 18x9.5-25 and a 18x11-35 can i fit a 295/35,305/35,295/30,305/30 in the rear and yes i do have a rocket bunny kit v1. for the front will a 265/35, or 255/35 fit ?
EliteRB is offline   Reply With Quote
Old 03-18-2016, 03:14 PM   #3031
Killerbee
Killerbee's Avatar
agree on this, i'm personally also not a big fan of spacers
Old 03-18-2016, 05:03 PM   #3032
swarb
Everyone fits RB differently. You could fit either.
Old 03-19-2016, 10:57 AM   #3033
alvin545
Drives: 2015 Scion FR-S
I see on the wheel directory that a 17x7.5 +42 will fit on stock suspension. My question is, will fitting 205/50/17 tires (bridgestone potenzas) affect handling/speedometer significantly? Looking at a set of used rims/tires. Any help would be appreciated, thanks
alvin545 is offline   Reply With Quote
Old 03-19-2016, 11:11 AM   #3034
Killerbee
Killerbee's Avatar
about 2% more diameter, so your speedo will be -2% ( showing 98 when you drive 100)
no real affect on handling
alvin545 (03-19-2016)
Old 03-19-2016, 08:15 PM   #3035
Aire2thethrone
Drives: 2016 CBS BRZ
@swarb I tried what you said with both 3 and 5 mm spacers still did not fit without rubbing. I want to keep my mpss they are 245/35 r18 but if I went down to an 18x8.5 what offset is garunteed at that wheel size? This would be my 3rd time trying to get wheels on my BRZ ��
Aire2thethrone is offline   Reply With Quote
Old 03-19-2016, 08:55 PM   #3036
swarb
What is your current setup? And where does it rub or not fit?
Old 03-19-2016, 09:10 PM   #3037
Aire2thethrone
Well I'm back on stock now but the wheels were 18x9 +45 with 245/35r18 MPSS
Without spacers the wheel didn't clear the spring perch and rubbed the spring in the front with a 5mm spacer the tire would barely clear the perch when raised but when the car was lowered to the ground the tires didn't clear and were rubbing the springs. So the tire guy recommended to drop the offset to between 30-35 on stock suspension, is he correct? Also the wheel selection is much larger at 18x8.5 so what offset would be needed there?
Old 03-19-2016, 09:11 PM   #3038
Aire2thethrone
@swarb also these were only problems in the front.
Determining the proper width size of the tire CyberFormula Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 49 05-23-2014 09:11 AM
Correct tire width for each wheel width DarrenDriven Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 08-16-2012 02:03 PM
TIRE SIZE CALCULATOR White64Goat Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 08-15-2012 02:31 AM
Tire Width vs Wheel Width Synack Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 40 08-12-2012 11:21 PM
